Old 12th August 2010, 11:28   #1  |  Link
vineet
Severe banding in videos
Hey,
I came across this particular video my friend had encoded as MJPEG, when I try to encode it using x264, it gets severe banding in 40 frames in middle of the video and colors totally blow out.Same is true with ffmpeg. I inquired further and understood that he had compiled some png images from different sources. Now when I try to make some png's from different encoders into a movie with ffmpeg, i get the same artifacts. Any clues how to overcome this?
vineet is offline   Reply With Quote
Old 12th August 2010, 11:54   #2  |  Link
nm
Try using a batch image encoder to convert the images to compatible PNG files first. This is a lossless process if no scaling/cropping is required. ImageMagick's convert tool is one possible alternative.
If you'd like to get the potential ffmpeg bug fixed, post your image files (as a package) and the command-line that you are using so we can replicate the issue.
Old 12th August 2010, 14:16   #3  |  Link
poisondeathray
I'm guessing there is a levels issues with your mjpeg decoder and the actual content. Can you post a sample? Try converting to PC or TV levels
banding, ffmpeg, x264
