Old 13th May 2010, 15:56   #21  |  Link
kolak
Originally Posted by mp3dom View Post
Infact it's mentioned in the tab
I would like to add that even if it's allowed to have a fullHD secondary video, it's better to prefer SD secondary video because not all the standalone players are able to handle 2 fullhd stream at once.
I see it now
Old 13th May 2010, 17:32   #22  |  Link
sub24ox7
Audiophile
sub24ox7's Avatar
What we still need are the exact specifications for 100% blu-ray compliant video I have a good idea or at least I am 99% sure I already know all the specifications I just want to be 100% sure.
Now that x264 can produce a 100% compliant blu-ray video I
think it would be a great Idea to have a sticky with he exact encoder settings.
never give up or at least die trying
sub24ox7 is offline   Reply With Quote
Old 13th May 2010, 17:40   #23  |  Link
ajp_anton
ajp_anton's Avatar
Originally Posted by shon3i View Post
Not exactly because situation looks like this:
1. 15000 is max for DVD
2. 15000 is max i you want use 2 sec GOP besides you use DVD or BD
3. you can still use 1 sec gop.
so if you don't use 2 sec GOP that mean you will use 1 second instead. I will somehow fix this.
@all, be patient
What I suggested means
DVD, 1s GOP: 15000
DVD, 2s GOP: 15000
BD, 1s GOP: 40000 / 24000
BD, 2s GOP: 15000
You could make it even more clear by adding "1 sec GOP" to the 40000/24000 maxrate.
Or is this wrong?
Old 13th May 2010, 20:32   #24  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Yes you right, i will fix this somehow.
shon3i is offline   Reply With Quote
Old 13th May 2010, 21:20   #25  |  Link
kolak
Keep in mind that x264 was mainly tested with 1920x1080 24p sources. If you start using other possible combination you may find some problems.
Losts of people use 40Mbit as max bitrate- this would be the first thing which I would avoid Encoding for BD is not exactly the same as for PC playback.
Andrew
Old 16th May 2010, 18:11   #26  |  Link
laserfan
Aging Video Hobbyist
Thanks shon3i for the charts.
Question: I've been using --keyint 24 and 15000/15000 for all "BD"-on-DVD work, and given my bitrates are typically in the low 3500-7000 range should I really be using --keyint 48 instead to minimize "pulsing" at GOP changes?
laserfan is offline   Reply With Quote
Old 16th May 2010, 19:05   #27  |  Link
poisondeathray
I can't see any reason NOT to use the longer gop size if you are <15Mbps.
Old 16th May 2010, 19:45   #28  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I agree, longer gop, better compression efficiency, is not that marginal but probably will reduce some pulsing.
Old 16th May 2010, 19:53   #29  |  Link
laserfan
Thanks for confirming!!!
Old 18th May 2010, 17:58   #30  |  Link
MadMonkey57
Duh!
MadMonkey57's Avatar
And what about --min-keyint ? Does it have to be set with regards to --keyint or x264 default (auto) is blu ray compliant ?
MadMonkey57 is offline   Reply With Quote
Old 18th May 2010, 20:55   #31  |  Link
Santa
I'm pretty sure to have a 25p or 30p bluray disc with some demo movies from panasonic.
is it sure that the only allowed progressive framerate for 1920x1080 resolution is 23.976 or 24p and not 25p or 30p?
i'll take a look on that bluray disc as soon as possible.
Santa is offline   Reply With Quote
Old 18th May 2010, 21:17   #32  |  Link
kieranrk
It is possible using PAFF mode.
kieranrk is offline   Reply With Quote
Old 18th May 2010, 21:37   #33  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
There are many disc that out of specs even retail's, that disc probably is not done by any "expensive" authoring software, that follow BD Specs, which clearly not allow 25p or 30p as combination.
As kieranrk says, it's possible to encode as 50i or 60i using some of interlace modes, which not skrew PQ
Old 18th May 2010, 23:12   #34  |  Link
kieranrk
It doesn't say that per se. It says frame_mbs_only must be zero. This makes it possible to write progressive frames (i.e. all frames are progressive in PAFF mode)
Old 18th May 2010, 23:40   #35  |  Link
poisondeathray
But has anyone seen it actually work in a hardware player? (encoding 25p/30p as 50i/60i)
Old 19th May 2010, 00:58   #36  |  Link
TinTime
I've come across a couple of blu-rays that are nominaly 50i but are sped up films and so 25p. "Brick" and "The Reader" are both like that, in the UK anyway. Both were MBAFF I think.
TinTime is offline   Reply With Quote
Old 21st May 2010, 15:21   #37  |  Link
kieranrk
The new fake-interlaced mode should encode 25p and 30p streams in a Blu-Ray compliant manner.
Old 21st May 2010, 15:26   #38  |  Link
poisondeathray
Interesting; is this a new patch ?
Can you provide more details on which switches or syntax to use to activate it?
Old 21st May 2010, 15:30   #39  |  Link
rack04
http://git.videolan.org/gitweb.cgi?p...9e6fd01db238bc
--fake-interlaced
Flag stream as interlaced but encode progressive. Makes it possible to encode 25p and 30p Blu-Ray streams. Ignored in interlaced mode.
rack04 is offline   Reply With Quote
Old 21st May 2010, 15:31   #40  |  Link
poisondeathray
^ thanks for the clarification
