Old 27th October 2009, 01:38   #81  |  Link
vamsiklak
the day befroe yesterday i got 10pack for 15.00
thats 1.49 apiece its optimum i burnt two discs it works good sofar
vamsiklak is offline   Reply With Quote
Old 27th October 2009, 17:28   #82  |  Link
VistaVick
Those are some improved prices, but I am too used to printing on the labels with my canon.......need some deals on printables.
VistaVick is offline   Reply With Quote
Old 31st October 2009, 15:24   #83  |  Link
Willobee
Where did you buy them? What brand?
Willobee is offline   Reply With Quote
Old 31st October 2009, 15:49   #84  |  Link
JJB
vamsiklal bought the same ones I did at Fry's. They are branded Optimum but are made by cmc according to the ID code. I have used 6 that were verified by imgburn and all have played back from start to finish with no problems. Fry's also carry's Memorex with a Ritek ID at everyday price of $24.99 for 15@ a disc price of $1.67. I have had no problems with verify or playback with those either.
JJB is offline   Reply With Quote
Old 31st October 2009, 18:05   #85  |  Link
Willobee
@jjb
Thanks for the info. I was buying the Memorex BD-R 25's at Newegg for alot more $. These Memorex BD-R's work great. I burn them at 8x on my Pioneer BDR203. No coasters so far.
Old 31st October 2009, 19:13   #86  |  Link
vamsiklak
Nice
ineed some of those
Now i can burn my 38gb-45gb files from my Hd on 2 bd-r25gb since these are getting lower
I hope i can get these puppies for dollar on black friday
Old 3rd November 2009, 03:40   #87  |  Link
PhilippeB
Optical Quantum
I had used only 2 brands so far, one Verbatim for BD-RE, and Optical Quantum (rated 4x but burns @ 8x on my LG BH08).
It is quite a fun to watch a disc burn at 36.xxx Mb/sec = )
The Verbatim BD-RE detected only at 1x on my burner (what a pain) even if it is sold as 2x. So far, Verbatim sucks.
Absolutly no problem with the discs so far. They are available at cheap price. Check NewEgg (got mine 74$ CAD for printable surface, but you can get the same discs LOGO for 64$ / 25 qty).
Also, they have a printable to hub version, my favarite, but also the most expansive so far. Check them out they sold pretty everywhere.
PhilippeB is offline   Reply With Quote
Old 3rd November 2009, 14:10   #88  |  Link
jdobbs
Interesting you'd mention the 1x problem. I had the same problem with my Sony BD-REs. I reformatted them (long format) and they then started working at 2X.
Website: www.jdobbs.net
Old 3rd November 2009, 14:49   #89  |  Link
Capsbackup
Same here. After a full format, which takes a very long time for me ( almost 2 hours ), now they burn at 2X.
Capsbackup is offline   Reply With Quote
Old 14th November 2009, 16:54   #90  |  Link
PurpleMan
Anybody knows where can I get inexpensive BD-R printable media from a website that ships internationally (outside the US) ?
PurpleMan is offline   Reply With Quote
Old 15th November 2009, 01:19   #91  |  Link
JJB
http://lmgtfy.com/
Old 22nd December 2009, 17:31   #92  |  Link
Capsbackup
I recently had purchased a 10 pack spindle of Optimum brand 4x BD-R 25GB media for $14.99. It looked like a pretty good deal!
Disc ID: CMCMAG-BA3-00.
Well, only 8 out of 10 discs worked properly, and those 8 also verified correctly with IMGBurn.
Two of the discs would not even start to burn, throwing out an error message. If I ejected the discs and tried again, IMGBurn reported the discs as empty/recordable, but as soon as you clicked burn, it would error out again. They will not write.
I do not believe I will use this brand again, since I have never had a problem with the Memorex/Ritek brand after 45 plus burns.
Old 22nd December 2009, 19:33   #93  |  Link
JJB
What burner? I have used about 4 of the 10 packs from Frys. All have burnt and verified OK with Imgburn. I use a Pioneer BD-205.
Old 22nd December 2009, 19:47   #94  |  Link
Warbucks81
Verbatim BD-R
For any canucks in this thread, Newegg Canada has the 10 pack of Verbatims 4x for $34.99. I picked up a couple packs when they had a free shipping promo.
Warbucks81 is offline   Reply With Quote
Old 22nd December 2009, 19:57   #95  |  Link
jdobbs
I bought some of these Ritek BD-Rs for $2.22 ea (box of 25) and have had good luck so far (I've burned about 20 of them).
Old 22nd December 2009, 21:49   #96  |  Link
laserfan
Aging Video Hobbyist
Originally Posted by Capsbackup View Post
I recently had purchased a 10 pack... It looked like a pretty good deal!
Originally Posted by JJB View Post
What burner?
Yeah and have to checked to verify that your burner supports CMCMAG-BA3-00.
laserfan is offline   Reply With Quote
Old 22nd December 2009, 22:42   #97  |  Link
Capsbackup
My burner is a Matshista UJ-225S, which came with my Dell XPS M1530 Laptop.
I'm not sure how to tell if that burner supports what different media, but 8 out of 10 leads me to believe it does, and the media is suspect.
Old 22nd December 2009, 23:49   #98  |  Link
laserfan
You're probably right, but OTOH maybe that's why 2 have failed.
I dunno if MediaCodeSpeedEdit works with your drive, but it looks at firmware to see if specific disc types are supported:
Old 3rd January 2010, 17:03   #99  |  Link
laserfan
Verbatim LTH
I noticed these on Amazon for something like $38 bucks for qty 20, and wonder if anyone here has tried them. I found this document
http://www.verbatim.com/userfiles/fi...tibility_2.pdf
which suggests they should work with my LG BD burner, but it's not as clear whether they'll be read by my BD player (which is not on their list).
Anyone here try them? I dunno if the "organic AZO layer" is inferior in some way to the regular "inorganic" type heretofore available, but they are significantly cheaper (best deal I can find on Verb BD-Rs is $29 at newegg for 10).
Old 4th January 2010, 04:20   #100  |  Link
datman
I just ordered 20 I'm betting you can't beat it.
datman is offline   Reply With Quote
