Old 6th January 2009, 21:43   #41  |  Link
Aktan
After turning off some options, I found that just turning off B-Frame mode (--direct none) has fixed the problem.
I'm not sure how to use --dump-yuv as the x264.exe doesn't even list it as an option. Can you give an example Dark?
I have not tried decoding with CoreAVC yet.
I will try with no --direct parameter (Spatial) and --direct temporal.
Aktan is offline   Reply With Quote
Old 6th January 2009, 21:54   #42  |  Link
J_Darnley
J_Darnley's Avatar
Sure it does: --dump-yuv <string> Save reconstructed frames
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 6th January 2009, 21:59   #43  |  Link
Aktan
oops, it was in longhelp.. I am still unsure how to use it, I tried something like this and got an error:
x264.exe --dump-yuv "C:\Temp DVD\Test.264" "C:\Temp DVD\VTS_01.avs"
x264 [error]: No output file. Run x264 --help for a list of options.
Edit:
Nevermind I think I know what I did wrong... which makes sense now
Old 6th January 2009, 22:03   #44  |  Link
J_Darnley
J_Darnley's Avatar
It is no subsitute for normal output. Use x264 as normal and add the dump-yuv option. Use NUL for the output file if you don't want one.
Old 6th January 2009, 22:04   #45  |  Link
Sagekilla
x264aholic
x264.exe "C:\Temp DVD\VTS_01.avs" --output "NUL" --dump-yuv "C:\Temp DVD\yuv_dump.yuv"
I'm not sure what extension is the proper one to use for a raw yv12 file but that's trivial.
Sagekilla is offline   Reply With Quote
Old 6th January 2009, 22:15   #46  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
If direct none fixes it, then that means direct is broken (either encoder or decoder side).
Try setting to "spatial" just to make sure it isn't temporal that's broken.
Old 6th January 2009, 22:45   #47  |  Link
Aktan
Okay, a few more tests:
direct = 1 (Spatial) (aka no --direct parameter specified at all) has no problems
direct = 2 (Temporal) (aka --direct temporal) has no problems
Old results:
direct = 0 (None) (aka --direct none) has no problems
direct = 3 (Auto) (aka --direct auto) has problems
I tried using CoreAVC decoder but it is worse off. My clip that was not encoded with B-Frames outputted with CoreAVC is not lossless in certain areas while outputting with FFDShow was. I'm not sure if it is due to a setting in CoreAVC, but I didn't think so since parts of the clip was outputted the same as the source.
The version of CoreAVC is 1.8.5 (Trial Edition)
Old 6th January 2009, 22:48   #48  |  Link
Dark Shikari
x264 developer
In the case where it "has problems", does --dump-yuv's stream have problems, or is it exactly correct?
Old 6th January 2009, 22:54   #49  |  Link
Dark Shikari
x264 developer
You're right, direct auto is bugged, the code as written assumes non-lossless.
Solution coming soon.
Edit: solution applied.
Old 6th January 2009, 23:21   #50  |  Link
Aktan
Cool thanks Dark!
Well I did the YUV Dump anyway and got a big file (which is obvious) but I have no idea how to load it into AviSynth, sorry for the OT, but any ideas?
Old 6th January 2009, 23:22   #51  |  Link
Dark Shikari
x264 developer
Originally Posted by Aktan View Post
Cool thanks Dark!
No need, as the problem has already been pinpointed and resolved. It was an x264 bug.
(You'd use RawSource if you wanted to load it into AviSynth).
Old 6th January 2009, 23:32   #52  |  Link
Aktan
Yep I already knew you've already pinpointed and resolved the issue, I was just curious as to how to load it, which you've told me how. Thanks!
Old 10th April 2024, 14:21   #53  |  Link
damian101
damian101's Avatar
Originally Posted by Dark Shikari View Post
Ultra-fast: --subme 1 --no-cabac --partitions none --me dia
Normal: --subme 5 --partitions all
Slow: --subme 6 --8x8dct --partitions all --ref 2
Slower: --subme 8 --8x8dct --partitions all --ref 4 --me umh --mixed-refs
Slowest: --subme 8 --8x8dct --partitions all --ref 16 --me esa --mixed-refs
Note that no-cabac loses about 10-15% compression but massively speeds up playback. Other things that hurt compression the most are subme=0 (vs other values) and partitions=none.
--partitions all
is usually harmful on noisy camera content, especially with subme < 6
Also,
--8x8dct
should be default anyway with all presets except ultrafast.
damian101 is offline   Reply With Quote
Old 11th April 2024, 00:33   #54  |  Link
benwaggoner
In her defense, Dark Shikari's answer was from over fifteen years ago.
Ben Waggoner
My Compression Book
Old 15th April 2024, 09:08   #55  |  Link
Tlen
Just for the records,
because i had to make a lossless compression of a 4 hours film
I always used Lagarith as default,
so i tried x264 lossless to see what happens.
4 Hour, 1920 * 1080 YV12
x264 (qp 0 very slow)
210 GB @ 13.4 fps
Decoding speed ok (no frame lost) on a Low TDP CPU (i5) but CPU stuck at 100%
Lagarith
264 GB @ 120 fps
Decoding speed ok (no frame lost) on a Low TDP CPU (i5) - CPU 88%
Ssso I think that the only pro of x264 would be a compatibility side
(you can use Lag only on PC while you could teorically be able to run x264 on a NAS too)
and a little better compression but that costs an incredibly huge amount of time.
So all in all Lags remains the choice (generally).
Tlen is offline   Reply With Quote
Old 15th April 2024, 12:34   #56  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Lagarith is ok but it's getting older and it doesn't support high bit depth which you don't need in this case as you're working in yv12 but if you'll ever need it then you're gonna be out of luck.
x264 is of course much slower in encoding time, but it does compress better and it also supports 10bit, while x265 supports up to 12bit and it's gonna be much slower again.
As to x264 vs x265, going back to summer 2013, the x265 lossless mode wasn't very optimized and it sometimes produced larger files compared to x264.
A lot of time has passed since then (11 years) so it probably improved but I haven't done a significant benchmark for a long time (although I feel like I should).
Another one that supports up to 10bit is UTVideo which has been a good alternative for a while.
If you need something that supports high bit depth up to and including 16bit planar, you can use HuffYUV which is my de facto choice for lossless encoding nowadays.
HuffYUV is still maintained and it's ridiculously fast on modern CPUs to both encode and decode.
If you want something that has the same bit depth support as HuffYUV (i.e up to 16bit) but has a better compression efficiency there's always FFV1 which is very very good and has CRC checks per slice.
I'll probably make a new comparison if I have time.
Old 15th April 2024, 15:58   #57  |  Link
jpsdr
HuffYUV is still maintained...? I'll search... I thought it stopped a looong time ago at version 2.1.1
There is also MagicYUV.
My github.
Old 15th April 2024, 16:05   #58  |  Link
Tlen
I remember that huffyuv was way beyond compression ratio than lagarith although very much faster,
but for archival needs, compression ratio has more weight in the equation.
I remember testing FFV1 long time ago and not remembering why i discarded ahaha
Same as MagicYUV which i tested but didn't choose.
Next time pheraps I'll re-evaluate MagicYUV which I vaguely remember had good ratio and high speed.
Concerning high bit depth, yes atm I don't deal with that so it's out of the requirements.
Old 15th April 2024, 21:05   #59  |  Link
benwaggoner
IDR-only HEVC lossless is more efficient than anything you’ve listed, and has HW decode support.
Sent from my iPhone using Tapatalk
Ben Waggoner
My Compression Book
Old 15th April 2024, 22:38   #60  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
yeah, the original version did stop at 2.1.1 and it's 8bit only, but it got forked several years ago and led to the creation of ffvhuff which supports 8bit, 10bit, 12bit, 14bit and 16bit planar and it's still maintained to this very day.
