Old 26th December 2008, 17:35   #1  |  Link
stpdrgstr
x264 Lossless question
Hi, good day.
I was wondering if is safe to use x264 lossless, and is comparable to Lagarith.
I mean, if I reencode this x264 lossless to x264 lossy, it's the same as to reencode a Lagarith to a x264 lossy?
And, should I be using CoreAVC or libavcodec to decode this lossless through DSS2()?
These question had been retaining my sleep these days, so I would be very gratefull if they could be answered
stpdrgstr is offline   Reply With Quote
Old 26th December 2008, 17:49   #2  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
x264 lossless has pretty much strictly superior compression to Lagarith, even in intra-only mode IIRC.
Unlike Lagarith, it only supports the YV12 colorspace.
To decode it correctly, you need a libavcodec from within the past ~2-3 weeks (as that's when support was added) or CoreAVC 1.8.5.
Old 26th December 2008, 18:19   #3  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
How to encode to lossless?
Old 26th December 2008, 18:33   #4  |  Link
J_Darnley
J_Darnley's Avatar
Atak_Snajpera, huh? --qp 0 is that what you mean?
stpdrgstr, lossless is lossless, the input to "x264 lossy" in both cases should be the same.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 26th December 2008, 18:34   #5  |  Link
Atak_Snajpera
Huh? --qp 0 is that what you mean?
yep! I meant switch. Thanks
Old 26th December 2008, 19:53   #6  |  Link
stpdrgstr
Thank you very much. Now I can keep encoding at ease
Old 27th December 2008, 17:23   #7  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Note that for frame-accurate access to H.264 streams (lossless or not) you should use DGAVCIndex/AVCSource() instead of DirectShow.
I'm not sure whether AVCSource() already has an updated libavcodec with support for x264 lossless mode though...
Old 27th December 2008, 17:37   #8  |  Link
Dark Shikari
x264 developer
Frame-accurate access should never be an issue with lossless regardless of the decoder being used... since you shouldn't be using B-frames with lossless, so there is no frame delay.
Old 27th December 2008, 17:45   #9  |  Link
LoRd_MuldeR
Software Developer
Didn't know that. Why is it like that? And does x264 automatically set "--bframe 0" when "--qp 0" is used?
(Could check the sources, but I'm too lazy right now ^^)
Old 27th December 2008, 17:47   #10  |  Link
Dark Shikari
x264 developer
It always reduces compression.
No, because x264 isn't designed to protect you from your own stupidity.
A warning might be useful though.
Old 27th December 2008, 17:48   #11  |  Link
LoRd_MuldeR
Software Developer
With "always" you mean "B-Frames always reduce compression in lossless mode". Not in general. Right?
Old 27th December 2008, 17:50   #12  |  Link
Dark Shikari
x264 developer
Yes, hence the "lossless" in the thread title.
Old 27th December 2008, 17:52   #13  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
i thought the h.264 spec declared that predictive lossless profile was to only consist of IDR frames?
Edit:
nope, confirmed against the spec... it does allow I,P,B.
what's the point of allowing B frames in the first place if it reduces the compression?
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 27th December 2008, 17:56   #14  |  Link
LoRd_MuldeR
Software Developer
I created streams with x264's mode "predictive lossless" mode using P-Frames and even B-Frames (didn't know b-frames are bad for lossless) and CoreAVC as well as recent ffdshow do handle it properly.
Old 27th December 2008, 17:57   #15  |  Link
Dark Shikari
x264 developer
What is the point of prohibiting them if it requires an extra line of text in the spec?
(Furthermore, one theoretically could improve lossless compression by doing the "every frame is a B-frame" trick and then the "duplicate frames in both reference lists", because that would allow for 8thpel MC, which would help lossless.)
Old 27th December 2008, 18:01   #16  |  Link
LoRd_MuldeR
Software Developer
Reduce the number of cases a decoder needs to be prepared for ...
Old 27th December 2008, 18:06   #17  |  Link
Dark Shikari
x264 developer
What, by making things even more complicated by not making High 4:4:4 Predictive profile a strict superset of High Profile?
Old 28th December 2008, 14:49   #18  |  Link
vmrsss
so what's a sensible command line for lossless?
vmrsss is offline   Reply With Quote
Old 28th December 2008, 14:55   #19  |  Link
Dark Shikari
x264 developer
Ultra-fast: --subme 1 --no-cabac --partitions none --me dia
Normal: --subme 5 --partitions all
Slow: --subme 6 --8x8dct --partitions all --ref 2
Slower: --subme 8 --8x8dct --partitions all --ref 4 --me umh --mixed-refs
Slowest: --subme 8 --8x8dct --partitions all --ref 16 --me esa --mixed-refs
Note that no-cabac loses about 10-15% compression but massively speeds up playback. Other things that hurt compression the most are subme=0 (vs other values) and partitions=none.
Old 28th December 2008, 16:20   #20  |  Link
vucloutr
vucloutr's Avatar
no --subme 9 for Slowest ?
typo or is there actually something to it ?
vucloutr is offline   Reply With Quote
