30th November 2005, 05:30 | #423 | Link |
Thanks for the great interpolator.
Please describe parameter 'nt'. It's not in the README. EDIT: I tried it on some natural video and it looks great there too; much better than a Lanczos resize. Last edited by Guest; 30th November 2005 at 15:08. |
30th November 2005, 07:58 | #424 | Link | ||
3rd December 2005, 16:54 | #426 | Link |
brainless
here my small contribution to produce artifact free motion adaptive deinterlacing:
function securedeint(clip i, int th, int l) { function staticmask(clip e, int th, int l) {e0=e.motionmask(thy1=0,thy2=th,thc1=0,thc2=th,thSD=255) e1=e0.trim(1,0) e2=e0.trim(2,0) e3=e0.trim(3,0) e4=e0.trim(4,0) e5=e0.trim(5,0) e6=e0.trim(6,0) e7=e0.trim(7,0) ea0=logic(e0,e1,"OR") ea1=logic(e2,e3,"OR") ea2=logic(e4,e5,"OR") ea3=logic(e6,e7,"OR") eb0=logic(ea0,ea1,"OR") eb1=logic(ea2,ea3,"OR") ec=logic(eb0,eb1,"OR") (l==0) ? ec. greyscale().duplicateframe(0).duplicateframe(0).duplicateframe(0) :\ (l==1) ? eb0.greyscale().duplicateframe(0) :\ (l==2) ? ea0.greyscale() :\ e0.greyscale() } i.converttoyv12(interlaced=true).separatefields() e=selecteven().staticmask(th, l) o=selectodd().staticmask(th, l) interleave(e,o) m=doubleweave().blur(0,1).binarize(upper=false) b= getparity(i) ? i.separatefields().eedi2(field=3) : i.separatefields().eedi2(field=2) d=i.doubleweave() overlay(d,b,mask=m) } creating two separate motionmasks for odd and even fields each. then combining them. so it is possible to identify static areas for sure. but this will reduce detail in static areas, where a moving object recently has passed by. parameters: th = deinterlacing threshold: 0 -> stupid bob 6 -> a good value to start with the higher the more residual combing l = length of the combmask: 0 -> 16+2 fields are used for motion masking 1 -> 8+2 fields 2 -> 4+2 fields any other value -> 2+2 fields this large radius (l=1 or l=0) effectively helps against holes for linear moving, patterned structured, short shutter videos, that show deinterlacing holes with all other traditional deinterlacers. (zilogjones, this one is for your games )
Don't forget the 'c'! Don't PM me for technical support, please. |
3rd December 2005, 21:27 | #427 | Link |
@scharfis_brain
Nice function. Your motion masking effectively does what my motion masking for TDeint2 does, though it doesn't have a sliding window and I do some spatial denoising prior to testing temporal differences in order to deal with noisy clips. Somehow I could bet yours runs faster . @All So here come some releases. First is [link removed], changes: Code:
TDecimate: + speeded up some of the mmx functions that were added in the last release + modes 0, 1, and 3 now pre-compute metrics for the next needed cycle while delivering frames for the current cycle in order to evenly distribute cpu usage TFM: + Added mmx versions of the isse scenechange routines + Optimized combed frame detection routines Code:
+ Added edeint parameter see this post for setting combinations or for a combo of eedi2/tdeint for deinterlacing frames for tivtc you can use: 1.) tff interp = separatefields().selecteven().EEDI2(field=1) deinted = tdeint(edeint=interp,order=1,field=1) tfm(clip2 = deinted,order=1) 2.) bff interp = separatefields().selecteven().EEDI2(field=0) deinted = tdeint(edeint=interp,order=0,field=0) tfm(clip2 = deinted,order=0) Also, I noticed a mistake in the EEDI2 readme. Values 2/3 of the field parameter are switched. 2 actually starts with bottom and 3 actually starts with top. Finally, I have been playing around with some possible ways of detecting junctions and corners in an image, which is where EEDI2 usually has problems, and a slightly modified version of the harris corner detection algorithm seems to do the job nicely. It completely avoids detecting plain diagonal lines while triggering on junctions and very complex areas. I'm probably going to add it as an optional step for avoiding artifacts. Last edited by tritical; 19th December 2005 at 03:45. |
4th December 2005, 15:17 | #428 | Link |
XviD User
Hmmm...Tdecimate is causing Vdub and VdubMOD to exit at the end of my scripts for some reason. This is the latest TIVTC v1.0 Beta 3. Using decimate() instead of tdecimate() resolves the issue on 2 film sources. Anyone else or do I have something strange going on?
I just went back to beta 2 and the script works fine. Perhaps the MMX speedups has caused this somehow in beta 3? Edit-typo
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2 |
4th December 2005, 20:58 | #430 | Link |
It is more likely the pre-buffering in modes 0, 1, and 3, cause the mmx speedups only effected ssd routines (requires ssd=true to be used) and one yuy2 luma difference routine. Plus, those mmx routines, if they are being used, get used on every frame so they would cause an error long before the end of the script. Also, I tested out all of the mmx routines on multiple clips, but didn't test a full encode (all the way to the end) with the pre-buffering . Will take a look.
EDIT: Yeah it was the pre-buffering. I am guessing you both must be running windows xp sp2 cause TDecimate actually isn't crashing, it is throwing an avisynth error. Using a modified version of avisynth that doesn't have the little seh/c++ exception handling crash problem on sp2, this error reported in vdub: "TDecimate: internal error during pre-buffering (%d,%d,%d)!" Will put up a fix in a few minutes. EDIT 2: Here is a fixed version: [link removed]. Only change was one line of code to fix the end of clip processing in modes 0, 1, and 3. I will try to test things more thoroughly in the future . Last edited by tritical; 19th December 2005 at 04:28. |
4th December 2005, 23:23 | #432 | Link |
Hi-
I don't know if I got the same thing or not. I didn't think much of it at the time, and didn't write down the error message VDubMod gave me, but after seeing the 2 other posts I thought I'd better report. This was with the new TDeint, using it as a bobber: TDeint(Mode=1) RePAL(Quality=3) The message was something about VDubMod not responding and having locked. Can't really remember. The encode had completed, and near as I can tell, the video was complete. Using Win XP SP1. Last edited by manono; 4th December 2005 at 23:25. |
5th December 2005, 02:17 | #433 | Link |
XviD User
Thanks tritical, that was very speedy indeed :-)
In all my cases Vdub/VdubMod was just exiting at the end of every script no matter how small or large the source file. Unfortunately my AVS version doesn't throw the exception here on XP SP2 :-\
5th December 2005, 07:12 | #434 | Link |
@manono
I tried to reproduce your problem but wasn't able to... using tdeint(mode=1) both with and without repal in yv12 and yuy2. What was the rest of your script? and what was the source? @All I did notice another bug with TDeint though... it doesn't handle the edeint option correctly when mode=1. It checks for the edeint clip to have the same number of frames as the input clip, which is correct for mode=0, but should be 2x for mode=1. @MacAddict It actually does throw the exception... its just that due to a bug in one of xp sp2's dlls, mixing seh/c++ exception handling will cause a hard terminate. Avisynth no longer uses such a mix when the script is initially loaded (so any errors detected and reported by a filter in its constructor will be reported correctly in vdub), but still uses such a mix when requesting frames from the chain of filters (so any avisynth errors thrown by a filter during it's getframe() processing will cause vdub to hard terminate on xp sp2). |
5th December 2005, 07:24 | #435 | Link |
interlace this!
@ manono: it didn't say "possible livelock" by any chance?
that's more a warning than an error - means at some point during the encode virtualdub didn't use any CPU cycles. this'll happen if some other program maxes out your CPU (and you don't have hyperthreading or something similar) for 10 seconds or more. i get it a lot when i use virtualdub to export the audio out of an avs, and encode to mpeg-2 at the same time.
sucking the life out of your videos since 2004 |
5th December 2005, 13:13 | #436 | Link |
Yes, that may have been it, Mug. I'll pay more careful attention the next time it happens. It happened after the encode had finished, I think. I wasn't around, and when I came back, the uncompressed Lagarith AVI was done and this message was sitting on the VDubMod screen. For what it's worth, here's the script:
LoadPlugin("F:\DivX Stuff\GKnot\DGDecode.dll") LoadPlugin("F:\DivX Stuff\GKnot\TDeint.dll") LoadPlugin("F:\DivX Stuff\GKnot\RemoveGrain.dll") LoadPlugin("F:\DivX Stuff\GKnot\RePAL.dll") LoadPlugin("F:\DivX Stuff\GKnot\Undot.dll") mpeg2source("K:\March Of The Penguins\5-1\5-1.d2v") Trim(0,94874) TDeint(Mode=1) RePAL(Quality=3) Undot() RemoveGrain() Damn R1 March Of The Penguins has an extra that's a mix of 30fps interlaced footage and PAL2NTSC blended 25fps footage. I decided to RePAL the whole thing and see how it turned out. |
6th December 2005, 17:12 | #437 | Link | |
Huh?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. Last edited by Chainmax; 6th December 2005 at 17:45. |
6th December 2005, 19:55 | #438 | Link |
You can't, because it can only double the height. But you can first use eedi2 to get to 160x224. Then resize with Lanczos. It should be at least better than just using Lanczos.
6th December 2005, 22:59 | #439 | Link |
Clouded
How about turnright().eedi2(...).turnleft()?
a.k.a. Clouded. Come and help by making sure your favourite AVISynth filters and scripts are listed. |
6th December 2005, 23:01 | #440 | Link | |
Huh?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
tdeint, tivtc |
