Old 1st August 2016, 15:19   #1541  |  Link
Blight
Software Developer
Blight's Avatar
Which thread priority does mediainfo use and is it somehow controllable? (I want to use it in idle thread priority so it has the least affect on UI performance)
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 8th August 2016, 01:38   #1542  |  Link
filler56789
SuperVirus
filler56789's Avatar
Hi Zenitram,
¿don't you think the "descriptive string" «Convenient unified display etc Etc ETC» is too long and annoying?
¿Why not say simply 'MediaInfo'?
filler56789 is offline   Reply With Quote
Old 8th August 2016, 08:29   #1543  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Originally Posted by filler56789 View Post
Hi Zenitram,
Or even 'MediaInfo: Media file meta-data analyzer'
Old 2nd September 2016, 07:26   #1544  |  Link
filler56789
SuperVirus
^ Never mind, just use Resource Hacker for the win
Old 2nd September 2016, 08:01   #1545  |  Link
Groucho2004
Groucho2004's Avatar
Hi Zenitram,
Similar issue here. Few devs know that Windows pulls the text from "FileDescription" instead of "ProductName".
Groucho's Avisynth Stuff
Old 13th September 2016, 18:46   #1546  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
New MediaInfo builds (version 0.7.88), CLI and GUI, are now available:
https://github.com/lordmulder/mediai...ases/tag/v2.21
Old 14th September 2016, 12:32   #1547  |  Link
Brazil2
Thanks
Brazil2 is offline   Reply With Quote
Old 15th September 2016, 22:00   #1548  |  Link
ggtop
shell integration
Hi LoRd_MuldeR,
something I observed using 2.21 on Win7 x64:
Everytime MediaInfo is started I have a new entry MediaInfoXP in Windows Explorer context menu though it is disabled in preferences. I have to enable and disable it for removal. MediaInfoXP is started from a portable drive.
Thanks for looking into the behavior in advance
ggtop
ggtop is offline   Reply With Quote
Old 16th September 2016, 17:42   #1549  |  Link
Brazil2
Yes same for me and it behaves the same on Windows XP so it's not OS related.
Old 27th September 2016, 17:22   #1550  |  Link
I have basically always found it necessary to toggle Explorer preferences on/off/on in any version of MediaInfo (XP32SP3).
(with gui close between toggles, that though is to switch something on, not off)
StainlessS is online now   Reply With Quote
Old 27th September 2016, 18:29   #1551  |  Link
MediaInfo v7.88, Access Violation on mp3 (XP32SP3):- EDIT: LINK REMOVED
With Settings, Explorer Tooltip enabled, hover over pretty much any mp3 file and get Access Violation.
I ended up have to delete original faulting mp3 via command line as just kept crashing explorer when approaching with mouse.
Going to any old mp3 folder, hovering over the 2nd of many mp3's, same again, so example mp3 is probably not really necessary.
EDIT: Disable Tooltip and no Access Violations.
@Zenitram, please say when taken sample file, so I can delete.
EDIT:
General
Complete name                            : C:\TEMP\Test.mp3
Format                                   : MPEG Audio
File size                                : 1.72 MiB
Duration                                 : 2 min 30 s
Overall bit rate mode                    : Constant
Overall bit rate                         : 96.0 kb/s
Album                                    : Something Something Something
Track name                               : Something
Track name/Position                      : 48
Performer                                : Somebody
Genre                                    : Pop
Recorded date                            : 2002
Cover                                    : Yes
Cover MIME                               : image/jpg
MusicMatch_Situation                     : Background
MusicMatch_Mood                          : Morose
Audio
Format                                   : MPEG Audio
Format version                           : Version 2
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : Intensity Stereo + MS Stereo
Bit rate mode                            : Constant
Bit rate                                 : 96.0 kb/s
Channel(s)                               : 2 channels
Sampling rate                            : 22.05 kHz
Replay gain                              : -0.06 dB
Replay gain peak                         : 0.480973
Stream size                              : 1.72 MiB (100%)
MP3Gain, Min/Max                         : 135,180
EDIT: I know, its difficult, hard, impossible, to use MusicMatch after(And I think including) IE7. (I tag with W2K OS and MusicMatch, nothing I like better for that)
Old 28th September 2016, 09:37   #1552  |  Link
manolito
manolito's Avatar
For me this only happens when the meta data of the MP3 contain cover information. See this post:
http://forum.doom9.org/showthread.ph...73#post1759773
The last MediaInfo version without this issue is 0.7.81.
Cheers
manolito
Old 28th September 2016, 18:19   #1553  |  Link
Cheers Mani, love that smile [You should be in movies]
Old 28th September 2016, 20:58   #1554  |  Link
manolito
manolito's Avatar
He still has a very nice smile, doesn't he?
http://www.henrydarrow.com/
Old 29th September 2016, 13:59   #1555  |  Link
Yep.
Also from your link
He was also the lead guest star on a still-beloved program called "Bonanza", produced by the man who would later give us "The High Chaparral"
Seems that Gavino is right, even when he thinks he is wrong:- http://forum.doom9.org/showthread.ph...31#post1574331
EDIT: Deleting given mp3 link in about 24 hours.
Old 4th November 2016, 21:18   #1556  |  Link
LoRd_MuldeR
Software Developer
In latest "All inclusive" package there still is a weird problem with the zlibstat project:
No matter what I do, the individual source code files in that project simply don't apply the settings (e.g. /MT vs. /MD switch) that I have set up in the "main" project properties - even if I explicitly apply "inherit from project defaults"
Had to remove the zlibstat project from the MediaInfo solution and add the normal zlib project instead, which seemed to fix this weirdness. Not sure why they exist both, anyway...
Old 3rd December 2016, 22:16   #1557  |  Link
manolito
manolito's Avatar
The latest MediaInfo v 0.7.91 fixes the issue from this post:
http://forum.doom9.org/showthread.ph...41#post1781741
Thanks Zenitram...
Cheers
manolito
Old 29th January 2017, 19:16   #1558  |  Link
stax76
stax76's Avatar
here is a new MediaInfo cmdlet for PowerShell:
https://forum.doom9.org/showthread.php?t=174267
Old 24th March 2017, 21:01   #1559  |  Link
LoRd_MuldeR
Software Developer
MediaInfoXP v2.24 (MediaInfo v0.7.93)
* https://github.com/lordmulder/mediai...ases/tag/v2.24
* https://sourceforge.net/projects/mul...8CLI%2BGUI%29/
* https://www.mediafire.com/folder/wps...k8qv/MediaInfo
Old 1st April 2017, 16:46   #1560  |  Link
manolito
manolito's Avatar
Thanks for the new version 0.7.94...
For the 32-bit CLI executable I found a small cosmetic bug (running under WinXP). For every file I throw at it I get this STDERR output:
E: File read error
E: is the drive where Windows is installed, MediaInfo.exe is called from a different drive. So this new version seems to try reading a file on the OS drive which probably does not exist...
The STDOUT output seems to be be correct, and since the error message does not cause a crash, I consider it cosmetic. The previous version had no problem. Also the 32-bit DLL 0.7.94 works fine.
Cheers
manolito
