Old 16th July 2023, 07:34   #101  |  Link
Barough
Barough's Avatar
AviSynth+ v3.7.3
https://github.com/AviSynth/AviSynthPlus/releases
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 16th July 2023, 09:04   #102  |  Link
seagate
L-SMASH-Works-20230716
seagate is offline   Reply With Quote
Old 1st August 2023, 18:30   #104  |  Link
Barough
Barough's Avatar
Vorbis-tools v1.4.2-7168723 (New build due to Newer Dependencies)
https://www.mediafire.com/file/vsy42sblz1ym163
Old 5th August 2023, 07:18   #105  |  Link
kedautinh12
Can Vorbis-tools v1.4.2-7168723 replace oggenc2.exe in Megui??
Old 5th August 2023, 09:54   #106  |  Link
tebasuna51
tebasuna51's Avatar
Yes, there are some differences with parameters but MeGUI never uses these parameters, the new encoder don't have (or not documented):
-S, --converter Specify the resampling engine to be used.
--scale n Scale input data to n (n = between 0.00 and 1.00)
--FLAC-scale n Scale input data using FLAC Replaygain Tags
And the new encoder don't support 32 bits int like input then don't have the parameter:
-F, --raw-format=n Set format for raw input. Default is 1 for Standard PCM; use 3 for IEEE Float.
Now is enough the parameter:
-B, --raw-bits=n Set bits/sample for raw input. Default is 16, 32 assumed for IEEE Float.
Without problem with AviSynth, the decoders never output 32 bits int, unless you use the explicit conversion ConvertAudioto32bit()
A conversion without sense at all.
Old 6th August 2023, 17:36   #107  |  Link
seagate
L-SMASH-Works - 20230806 1129.0.1.0
Old 8th August 2023, 22:30   #108  |  Link
seagate
VisualCppRedist AIO v.0.74.0 (Visual C++ 2022 Redistributable - v.14.38.32919.0)
Old 9th August 2023, 15:51   #109  |  Link
seagate
VisualCppRedist AIO v.0.75.0 (Visual studio tools for Office runtime - v.10.0.60910.0)
Old 30th August 2023, 01:32   #110  |  Link
kedautinh12
x265 mod by Patman r3.5.0.106
https://github.com/jpsdr/x265/releases
Old 16th September 2023, 02:53   #111  |  Link
kedautinh12
MediaInfo 23.09
https://mediaarea.net/en/MediaInfo/Download/Windows
Old 19th September 2023, 18:51   #112  |  Link
Barough
Barough's Avatar
AOM AV1 v3.7.0-423-g57be81b0fd
https://www.mediafire.com/file/4swa75r64sc77md
x265 v3.5+111
https://www.mediafire.com/file/4i3i5a4l4ud7rai
Old 23rd September 2023, 03:01   #113  |  Link
kedautinh12
ffms2_r1369
- AviSynth: fixed GetParity (rffmode > 0) and _FieldBased. (bugs introduced in the previous version)
- AviSynth: added support for audio channel mask.
- AviSynth: fixed fps (rffmode > 0). (bug introduced by the new FFmpeg API from the beginning of 2023)
- ffms2@cf7c4b2;
- ffmpeg@9310ff;
- zlib 1.3;
- dav1d 1.2.1;
- libxml2 v2.11.5.
Old 27th September 2023, 17:19   #114  |  Link
Barough
Barough's Avatar
DGDemux 1.0.0.72 (2023-09-27)
https://www.rationalqm.us/dgdemux/binaries
Old 29th September 2023, 19:48   #115  |  Link
Barough
Barough's Avatar
exhale v1.2.0.1-0b683be9
https://www.mediafire.com/file/cf501ne5z8ap30s
Old 30th September 2023, 02:13   #116  |  Link
kedautinh12
two link is the same exhale
Old 1st October 2023, 21:13   #117  |  Link
seagate
x264-r3144-5a9dfdd
Old 3rd October 2023, 18:30   #118  |  Link
seagate
L-SMASH-Works 20231003 1141.0.0.0
Old 4th October 2023, 05:40   #119  |  Link
seagate
VisualCppRedist AIO v.0.76.0 (Visual C++ 2022 redistributable - v.14.38.33126.1)
Old 4th October 2023, 13:58   #120  |  Link
kedautinh12
MediaInfo 23.10
