#101 | Link | ||
![]() Last edited by burfadel; 2nd May 2015 at 10:27. |
#102 | Link | ||
#104 | Link |
I spoke too soon about the benefits of multithreaded Avisynth+
The speed benefits are there, but it is hardly stable. With Prefetch=3 or above, it invariably crashes in a few minutes. With prefetch=2 it is usually stable, however last night I launched a long encode and found that after a couple of hours it had crashed. Maybe I am doing something wrong, or avisynth+ MT is not mature yet, or am using the wrong MT_MODE for some filter. Anyhow, I am back to Staxrip with avisynth+ single-threaded, doing two encodes at the same time to fill CPU. Rock solid. |
#105 | Link |
I am trying out the beta you posted for this, it works well so far! The issue with QAAC64 is of minor annoyance only (having that command window pop up). On the other hand, it starts encoding the video while the audio is still encoding, so you have accidental mutlithreading there!
So there's no way of just outputting just the title bar information, and hiding the window? |
#106 | Link |
Files extrem Big
I test the new Version thanks for that.
But why the Files are so big? I have the same options and the File on the Old version are 300-350 MB (for 23min DVD File on X264) now i have 750 MB. on the Old Version i have this Filters here centrodiperditadipeso.info FieldDeinterlace Crop Boarders DeGrainMedian now i have the standart Filters: TDeint Crop Remove Grain Are the Filters not work the same like the Old one or why the Files are so big now? All other Settings are the Same CRF 19 and B-Frames and R-Frames 16 on Present Slower Tune Film Last edited by thomy22; 23rd February 2019 at 09:55. |
#107 | Link |
I notice that even though tfm is listed in the filter menu, the plugin isn't included. I believe tdecimate is also in the same package as tfm, so there should be an option in the filter menu for inverse telecining and decimation (which can be done with these two filters). Without inverse telecining and decimation, people will be doing a lot of bad encodes of telecined material!
#109 | Link |
@Stax
(from the private PM, glad the qaac issue was super simple to fix!) I came across the flash3kyuu deband filter, and am extremely impressed with the results on a poor quality video I had. The compression is good too, I used dither_algo=2 as suggested (it's better for standard bitrates, algo 3 is better for high bitrate outputs). Anyways, the doom9 page is here: http://forum.doom9.org/showthread.php?t=161411 Both x64 and x86 versions are available. Help file is inside. Now, I've come across a more updated version of it, still from the same sources as in the linked doom9 post, just that post hasn't been updated! Topic here: https://www.nmm-hd.org/newbbs/viewtopic.php?f=7&t=239 The version I used was the 2.0pre+b98d6bc x86/x64, inside which has the x64 and x86 dll's. It's up to date too! 2015-05-02, so only 2 days old. If anyone is wondering, I see the removing the banding and other issues present in poor quality videos as important. Some say it's pointless because you may introduce banding with encoding anyway, but that is rather an old thought on the manner. If there is banding present in the source, when you encode you are going to encode the banding as well! If you have a debanded source, with a very mild light dither, modern encoders (especially 10-bit versions of x265 etc) will produce markedly better file outputs. EDIT: Done a few more encodes, not only do I get a better quality output, but the output file size is actually smaller! I guess it makes sense since it's not using bits encoding the banding artifacts. I think it's well worth it going from 8-bit sources to 10-bit x265. It's also fast ![]() Last edited by burfadel; 4th May 2015 at 11:41. |
#110 | Link |
I made further findings on Avisynth+ MT issues.
I found that problems arise (encode crashes) ONLY when Qtgmc AND SelectEven() are both enabled. So: Script with only Qtgmc --> MT works fine, even with Prefetch(4) Script with only SelectEven() --> MT works fine Script with Qtgmc AND SelectEven() --> encode crashes What's going on ? I have no clue. Is this a problem with Avisynth+ or with Staxrip ? |
#111 | Link | |
QTGMC() SelectEvery(2, 0) # identical to SelectEven() #SelectEvery(2, 1) # identical to SelectOdd() |
#113 | Link |
@luigizaninoni
There is a similar report in the AviSynth+ thread, please post a full script, I want to test it too. @burfadel Thanks for the plugin suggestion and the help with qaac, I can add many more plugins, no problem. Regarding TDecimate, there is a crash in Win8/Win10 it seems so I removed the plugin and forgot to remove the filter. Some plugins have some CPU related parameters I need to try, overall there were many issues on Win8/Win10 not happening on Win7 so I decided to migrate to Win10 preview as main OS to investigate all problems. @thomy22 if the quality looks good then filters cannot make such a big difference in file size, it's most likely related to source complexity and crf. @Patman Thanks for the tip about the new DLL. |
#114 | Link |
I just tried the StaxRip_2015.05.04_20-32 beta, and it errors as a result of AssumeFPS(%fps%) on existing projects. Even completed projects it says invalid argument because of this.
Just noticed that I reclicked the source filter I was using, saved the template, and recreated the projects that were in the queue, and they are encoding fine now. I guess assumefps(%fps) was a change between the last beta and this one ![]() Last edited by burfadel; 4th May 2015 at 20:23. |
#115 | Link |
I've removed all those macros because they are not needed any longer, instead of always using the frame rate from MediaInfo with macros I add AssumeFPS dynamically now only if correction is needed, the correction logic is following:
if frame rate from AviSynth is approximately 2 times more then frame rate from MediaInfo then StaxRip adds SelectEven().AssumeFPS(fpsFromMediaInfo) this corrects a bug where ffms2/ffmpeg duplicates interlaced frames the second correction fixes wrong PAL frame rates, NTSC I leave now which might improve or worsen things, I don't know too much about NTSC. |
#116 | Link |
Here is the script:
Import("C:\Users\admin\Desktop\Video\Stax beta\Tools\Plugins\QTGMC\QTGMC.avsi") LoadPlugin("C:\Users\admin\Desktop\Video\Stax beta\Tools\Plugins\masktools2\masktools2.dll") LoadPlugin("C:\Users\admin\Desktop\Video\Stax beta\Tools\Plugins\mvtools2\mvtools2.dll") LoadPlugin("C:\Users\admin\Desktop\Video\Stax beta\Tools\Plugins\nnedi3\nnedi3.dll") LoadPlugin("C:\Users\admin\Desktop\Video\Stax beta\Tools\Plugins\RgTools\RgTools.dll") LoadPlugin("C:\Users\admin\Desktop\Video\Stax beta\Tools\Plugins\ffms2\ffms2.dll") SetFilterMTMode("DEFAULT_MT_MODE",2) SetFilterMTMode("FFVideoSource",3) FFVideoSource("C:\Users\admin\Desktop\Interceptor (1979) temp files\Interceptor (1979).m2v", cachefile = "C:\Users\admin\Desktop\Interceptor (1979) temp files\Interceptor (1979).ffindex", fpsnum = 25, fpsden = 1) QTGMC(Preset="Slow") SelectEven() Crop(2, 70, -2, -70) Prefetch(4) |
#118 | Link |
The new method of 1.3.1.1 works fine with interlaced H.264 files and ffms2, just like the previous 1.3.1.0, but the new method is a lot faster I think.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
#120 | Link |
there is a dropbox folder where I often upload bug fixes, it's here:
https://www.dropbox.com/sh/xiyz10pgh...srbITYDBa?dl=0 |
