Old 13th October 2024, 16:16   #1  |  Link
wang1zhen
madVR rendering wrong color in HPC-HC or potplayer
Hi all, I have been trying to migrate to madvr, but now facing some really difficult problems.
First let me show the screenshot of a fresh install with K-Likte Codec Pack Full (with madvr):
And after I manually change to MPC Video Renderer, the video is correctly rendered:
Same could be reproduced in potplayer.
Althogh MPC Video Renderer works, I really wish to try madvr but having no idea if it is a bug of madvr or not.
I am using a laptop with dual GPU, Intel Iris Xe from 12500H and a 3050Ti (BTW it is connected to a monitor with lid closed)
A lot of tutorials mention that output color range should be set to Full RGB, but I do not have such settings in the control panel of GPU:
I am really gratitude if anyone could help, or tell me where could I report this issue to upstream.
wang1zhen is offline   Reply With Quote
Old 13th October 2024, 16:32   #2  |  Link
http://bugs.madshi.net/
Old 13th October 2024, 16:53   #3  |  Link
wang1zhen
Thanks, have submitted to upstream.
Old 13th October 2024, 17:35   #4  |  Link
clsid
Afaik, one of the recent Intel driver versions was buggy with Madvr. Newer Intel hardware works poorly with DirectX9 in general, and Madvr also uses DX9.
In the Windows advanced display settings, you can configure Windows to use the NVIDIA GPU for MPC-HC/Potplayer.
MPC-HC 2.6.1
Old 14th October 2024, 05:27   #5  |  Link
wang1zhen
cannot believe it, that's exactly what has been causing this problem.
Thanks so much!!
Old 14th October 2024, 16:51   #6  |  Link
just to be clear you didn't fix the issue you workaround it other system that don't have a 3050 will still be in the same boat.
the main issue here is this is a madVR issue but it comes from a GPU driver issue.
Old 15th October 2024, 02:19   #7  |  Link
wang1zhen
Yes, thank you, I agree. If the gpu driver, intel, provides a malfunctioning driver, it could be disastrous. However as a consumer, I cannot do anything to help that.
Old 15th October 2024, 08:20   #8  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
wang1zhen, may I ask which Intel driver version you were running?
I am on 31.0.101.5534 here, Intel UHD Graphics 750.
Not running madVR ATM, but would be good to know anyway.
Old 15th October 2024, 08:26   #9  |  Link
wang1zhen
It's 32.0.101.5763.
Old 15th October 2024, 09:01   #10  |  Link
Emulgator
Emulgator's Avatar
Thank you, wang1zhen.
madvr
