#1 | Link |
Chroma ghosting on deinterlaced animation
Difficult to see at native resolution/size, but when made full screen or viewed frame by frame, I'm experiencing some chroma ghosting when processing a particular interlaced NTSC animation source. This persists across a few different deinterlacers; per this post, after trying QTGMC (at both 'slow' and 'slower'), I used other deinterlacers - TDeint, EEDI2+TDeint, Yadifmod2 - but they all exhibit the same problem, besides being not nearly as smooth as QTGMC is.
Here's are few clips containing the first two minutes of the episode using each method (all at 'double rate' - tried with single-rate as well but results didn't look encouraging enough to try an encode) without audio. QTGMC (Preset="Slow",SourceMatch=3,EdiThreads=4,ShowSettings=False) TDeint (mode=1) TDeint (mode=1,edeint=eedi2ed) yadifmod2 (order=1,mode=1) Here is the original source for the above clips (only the last minute's worth, but that should be enough). So, I'm not sure if I'm using the latter filters wrong, or if there is some kind of anti-ghosting solution available. There are some listed at the wiki but Ghostbuster doesn't process chroma and LGhost seems completely opaque. I'm not sure to proceed or if anybody has 'solved' this issue, since there doesn't seem to be much information about it. Last edited by bilditup1; 9th June 2016 at 20:55. Reason: fixed tag |
#4 | Link |
original source files,
cut with eg DGIndex, mark using '[' and ']', then 'Save Project' and supply result m2v. Choose section with some motion (about 20-30 secs should be enough).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 9th June 2016 at 17:50. |
#6 | Link |
Yep, guess I shoulda checked name in DGIndex, good job we got you to keep me on the right path
#7 | Link |
OK, here it is (actually it's the last minute of the above encoded videos, since I think the first minute won't tell us too much, being mostly black and white and all.)
I will also add it to the OP. I can also reencode this or recut the original files I put up, if you propose to try to do a frame-by-frame comparison or something. Last edited by bilditup1; 9th June 2016 at 22:11. |
#10 | Link |
![]() Join Date: Oct 2001
My thoughts:
It shouldn't be encoded at 59.94fps as that just accentuates the chroma blending and is the wrong framerate anyway. It's been telecined (the sample was) and the correct framerate is 23.976fps. You'll never be able to remove that chroma mess automatically as there's just too much of it. Since most of it seems to occur with duplicate frames, manual work after the IVTC will get rid of most of it. About all I was able to do was: TFM(Clip2=Nnedi3,chroma=true)###or set up SRestore as the deinterlacer Tdecimate() Others might have better ideas about what to do. Also, it was made by idiots. Not only is the chroma blending a serious issue, but it was encoded as progressive (the sample, anyway) which means most of the DVD players around won't even deinterlace it so you'll see all the interlacing. Last edited by manono; 10th June 2016 at 01:09. |
#11 | Link |
I was trying with upconv=1,icc=true in mpeg2source and telecide()
but still there is some chroma blending coz a chroma plane, I think U, isn't linked to the luma and sometimes anticipate or posticipate of one field.
powered by Google Translator |
#12 | Link | |||
I was experimenting with TFM's internal deinterlace modes before, but this resulted in combing in addition to color ghosting. Specifying chroma=true helped but - because of course it did - it left behind, as you said, an awful chroma mess. Specifying a very low cthresh of 2 or 3 + chroma = false almost completely got rid of the combing and chroma mess some of the time (not perfect but still harder to see), but not nearly often enough. Quote:
Anyway. Thanks for chiming in! I look forward to taming this beast. |
#13 | Link | |
Interesting...I'm going to try that and see what it looks like. |
#14 | Link |
I don't understand. Except for having to get NNEDI3 if you don't already have it, that's the exact script to use.
It can't be done properly without some serious manual work of replacing the remaining chroma-blended frames with 'clean' versions. Just bob it and have a look - you can go 3 and sometimes 4 frames of blending in a row. There's no way a field-matcher can handle that. Even bob/srestore can't. And it did a poorer job than did field-matching. But, as I said, maybe others can see things to do that I don't know. I don't work with cartoons much. |
#15 | Link | ||||
AssumeTFF() Bob() Quote:
#17 | Link | ||
#18 | Link |
Boom.
Yup, I was about to say, that post leads to this:
http://forum.doom9.org/showthread.ph...50#post1582950 And that script by sp00kyfox is made for *exactly* this problem, for animation DVDs from *exactly* the same period, by the *exact* same studio even. Brilliant! Let's try it! Combing appears to be gone, ghosting appears to be gone. Everything looks...slightly less sharp maybe? And kinda jerky? But I could be imagining that. There is definitely...some 'rainbowing'. I don't know the proper term. And there's some weird...not gridding, I don't know how to describe it. But it was in the source, and it's for another thread, I think. Anyway, comparison clips, again (no sharpening, cropping, degraining or anything like that) TFM(clip2=nnedi3,mode=2,chroma=true).TDecimate(mode=1) Sp00kyfox's script Note: script only appears to work with the old versions of Srestore and Average, at least for me just now. From the code comments, it appears that what it does is use tfm to process luma and vinverse+srestore to process chroma, then compares the two, builds a mask with masktools, and combines them on the basis of this mask. I wish I understood exactly how masktools works and what this script is really doing though, because it's pretty amazing. Anyway. Thanks for pointing this out GMJCZP. Wow. This thing should be stickied on the AVS wiki. And perhaps people smarter than I can even help improve it? |
#19 | Link | |
| Tags |
| animation, deinterlacing, ghosting, ntsc |
| Display Modes | |
