Old 20th July 2013, 14:02   #1  |  Link
infoeater
What cause phase shift of color signal in NTSC?
As I understand there is colorburst signal before each line in NTSC. So chroma QAM signal is resynced many times per field. If so how it's possible that color shift occurs. How it is possible that color shift is equal in many thousands of consecutive whole fields (so manual tint compensation is possible)?
infoeater is offline   Reply With Quote
Old 20th July 2013, 16:21   #2  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
One, operator error or equipment miscalibration. Color burst and sync are regenerated at many points in the signal chain and it's possible to get the phase wrong - especially when mixing signals (delay errors) or playing back a consumer video tape.
Two, differential phase. Burst is at zero IRE, visible chroma signal goes from -20 to +120 IRE, IIRC. Phase distortion can creep in.
Three, burst phase detection itself can be in error. It's a complex bit of circuitry.
Four...?
raffriff42 is offline   Reply With Quote
Old 21st July 2013, 15:07   #3  |  Link
Ghitulescu
Ghitulescu's Avatar
Originally Posted by raffriff42 View Post
Four...?
Never the same color.
Born in the USB (not USA)
Old 21st July 2013, 20:25   #4  |  Link
infoeater
Thank you very much raffriff42. Now I understand. Most articles described NTSC color distortion as coming magically from "transmission" during bad weather.
color shift, colorburst, distortion, ntsc, phase shift
