Old 8th October 2025, 20:01   #501  |  Link
taurusus
If you don't change the name of the button, then I don't understand why you need to move them? 334, 404, 508, 572 are the coordinates of all 4 buttons vertically.
taurusus is offline   Reply With Quote
Old 8th October 2025, 20:23   #502  |  Link
erick
I put the name in Portuguese and removed the English descriptive . The only thing I would like to do is to make the buttons closer to each other because the English is far away.
erick is offline   Reply With Quote
Old 8th October 2025, 20:31   #503  |  Link
taurusus
Take a screenshot or use mine, open it in Photoshop, position the buttons as you need, measure the coordinates and write to the class.
Old 15th October 2025, 18:47   #504  |  Link
suan_r23
Hello, I want to edit a UHD Blu-ray with BDEdit, but it’s very hard for me to understand how to do it and how to use BDEdit. My UHD Bluray starts with a Paramount intro and then shows a menu to select the language:
and then the main menu is launched. Is it possible to make the UHD Bluray start directly with the main menu, skipping the language selection menu? I understand that it would be necessary to set the language automatically, as if it were chosen from the language menu.
I’ve uploaded the UHD Bluray files to 1fichier, without the main movie .m2ts file, which in total takes up 498 MB. Could someone please do me a huge favor and create a tutorial with BDEdit screenshots showing what needs to be done and how to do it? Thank you so much.
Bluray UHD Menu structure 1Fichier mirror
Bluray UHD Menu structure MEGA mirror
Bluray UHD Menu structure mirror 3
suan_r23 is offline   Reply With Quote
Old 15th October 2025, 19:13   #505  |  Link
taurusus
Hi suan_r23. If you want help, then upload your files to a public and not a paid file sharing service. The free download is very slow, no one will download it.
Old 15th October 2025, 20:45   #506  |  Link
suan_r23
Hi, I’ve added two more mirrors.
Old 16th October 2025, 05:14   #507  |  Link
taurusus
suan_r23
Watch the video
https://cloud.mail.ru/public/iLx6/eLVBD5QWi
Old 16th October 2025, 12:38   #508  |  Link
suan_r23
Wow, very useful. Great idea to put it in a video! This will serve me as a guide for other BD structures too. Many thanks.
Old 9th January 2026, 04:30   #509  |  Link
erick
Can someone help me? I just added a Portuguese button to the Disney UHD 4K menu. How do I link this button to play the movie? Here's the menu to analyze.
https://www.mediafire.com/file/fqsqf...s-TMT.rar/file
Old 9th January 2026, 06:33   #510  |  Link
taurusus
Hi erick. You need to edit the bluray_project file.bin, you need to add entries about your audio and subtitles to playlists 00800 and 00801.
Old 9th January 2026, 09:53   #511  |  Link
erick
Yes, I understand, but could you send an example, since there are code files there?
Old 9th January 2026, 10:32   #512  |  Link
taurusus
Here is the edited file.
Old 9th January 2026, 12:23   #513  |  Link
erick
How did you get to the exact point in the audio editing? How did you search to find the options you edited? I'm using Hex Editor Neo; I can see everything, but finding the exact option is difficult.
Old 9th January 2026, 12:37   #514  |  Link
taurusus
To search, you need to convert 800 to hexadecimal code, using the built-in converter, you get the number 0320 and you need to search for it.
Old 9th January 2026, 12:42   #515  |  Link
erick
Hmm, I understand. Thank you, friend. I'll call you again if I have any further questions.
Old 9th January 2026, 15:23   #516  |  Link
erick
I apologize for my ignorance, but if possible, could you send a video explaining how you did this? It's very difficult to understand binary code, and I want to learn how to do it for my future collections.
Old 9th January 2026, 16:24   #517  |  Link
taurusus
Editing the bin file.
https://cloud.mail.ru/public/37Kk/BoHgjog15
Old 9th January 2026, 17:21   #518  |  Link
erick
Thank you very much, friend, for your precious time.
Old 9th January 2026, 17:34   #519  |  Link
palestina
Thank you so much for the explanation, @taurusus.
I usually edit menus by modifying the *png files in the JAR folder, but learning this method will be very helpful.
Best regards.
palestina is offline   Reply With Quote
Old Yesterday, 12:31   #520  |  Link
mandeajupanu
hy to all! can u help me editing the subtitle menu from this jar file i cant find it for example English SDH thnx
https://www.mediafire.com/file/rt31v...u/JAR.rar/file
mandeajupanu is offline   Reply With Quote
