Old 19th September 2025, 21:48   #481  |  Link
taurusus
Originally Posted by erick View Post
When I play Disney movies from the beginning, the first image appears with the languages, and on this first page I want to add a Portuguese button, and I'll send you the playback files.
You can add a button, but all these buttons are linked to the files "class, png and resources.xml ", each language has its own files. If you add a button, you will need to create all these files for it, and this is very difficult, it's easier to rename existing buttons.
taurusus is offline   Reply With Quote
Old 19th September 2025, 22:52   #482  |  Link
erick
but when I rename the French button and put Portuguese, the menu will enter French, how do I do it?
erick is offline   Reply With Quote
Old 19th September 2025, 23:28   #483  |  Link
taurusus
It's hard to explain if you've never done it. To do this, I need a working menu.
Old 20th September 2025, 00:26   #484  |  Link
erick
follow the functional menu
https://www.mediafire.com/file/j633d...MTeam.rar/file
Old 20th September 2025, 05:14   #485  |  Link
taurusus
Now, when you click on the French button, the menu will be English. You only need to replace the name of the button.
https://mega.nz/file/TnIEnLoS#FYGiUb...Yd_R6WU6hseF28
Old 20th September 2025, 08:21   #486  |  Link
erick
Can you give me a hint which files were modified?
Old 20th September 2025, 09:04   #487  |  Link
taurusus
I deleted all the French-related text and png files and changed dl.class .
Old 20th September 2025, 12:02   #488  |  Link
erick
I understand, thank you very much
Old 20th September 2025, 12:07   #489  |  Link
erick
the last question which research did you use to discover this class
and what changed in this class
Old 20th September 2025, 12:36   #490  |  Link
taurusus
I haven't done any research, I know that there is such a class in this menu. As for the changes, you can compare my class with the original one. I have removed the control unit for the French menu.
Old 20th September 2025, 14:25   #491  |  Link
erick
I saw it here, I understood it once again, thank you
Old 26th September 2025, 21:16   #492  |  Link
El Capitain
Is there any "typical" solutions for some "studio" menus editing?? For ex. Paramount, Warner, Columbia...
I've got a Warner disc and want to remove uneccessary audio and subtitles buttons (keep only first 2 of 5 in audio/video menu)
https://dropmefiles.com/Iw7zD - here are the archive with whole folder ex. m2ts - which jar-pages do I need looks for?
El Capitain is offline   Reply With Quote
Old 27th September 2025, 02:27   #493  |  Link
taurusus
Hello El Capitan, from the beginning we are looking for a class with the coordinates of the buttons in png, by the name of the png itself. In the found class, find the desired button and by its letter name (The name consists of the name of this class and a dot through the letter or combination of letters assigned to this button), we search for the class with the coordinates of this button in the menu itself and remove the buttons that are not needed. Further in this menu, Warner has another class, it shows all the buttons in the playlist, it also needs to be edited, we are looking for it by the name DOLBY_AC3_AUDIO, it is always present in this class. It is better to search using the luyten-0.5.4 program, and you can edit it here with two programs, DJ Java Decompiler 3.12 and JByteMod-1.8.2.
If you can't find the right classes using this description, I can just tell you their names.
Old 8th October 2025, 14:04   #494  |  Link
erick
Hi, I'm working on a Disney menu. I'd like to know where the class for the height and width position button is for the English initial language menu.
I would like you to show me the complete path of how to do this class search please
Because I have a little knowledge of Java, I looked for the png USA_QuickStart_Composite1_bt2020_HDR and found a class, but I don't know how to find the other classes and how to change them.
https://www.mediafire.com/file/217lj...s-TMT.rar/file
Old 8th October 2025, 15:19   #495  |  Link
taurusus
Hi, which menu do you want to edit? The initial menu is the selection of the menu language.
If the initial menu is English, then usa_shared_composit1_bt2020_hdr this png does not apply to it, this png is for audio and subtitle buttons.
Old 8th October 2025, 15:32   #496  |  Link
erick
the first image
Old 8th October 2025, 17:05   #497  |  Link
taurusus
I do not know which program you are looking for classes with, but it is better to search using luyten-0.5.4. If you have already found di.class , then copy the combinations of letters in the name, I highlighted di.d for example.
This is how you can find any class.
Old 8th October 2025, 17:23   #498  |  Link
erick
In this class, I edit the height of the English button up and down using the number 0 in the case of di.d di.c di.b
and I have more things to do besides these classes
There are 2 classes, how do you know how to find the right class?
https://imgur.com/OvxKH9K
https://imgur.com/aMpTS8l
Old 8th October 2025, 17:39   #499  |  Link
taurusus
In this class, you can only edit the location of the button in the menu, from top to bottom to right to left. If you need to resize the button, this is done in png and then in di.class . What number 0 are you writing about? You need to edit these coordinates.
Old 8th October 2025, 18:30   #500  |  Link
erick
If I edit the class you selected, the button will go up and down w.class? Example: 334, 404, 508, 572
