Old 28th February 2025, 18:46   #421  |  Link
erick
Originally Posted by taurusus View Post
Do you choose Espanol in this menu? Which subtitles do you want to replace, also Espanol?
yes spanish subtitles
erick is offline   Reply With Quote
Old 28th February 2025, 19:36   #422  |  Link
taurusus
If you just replace the subtitles button, it's enough to replace ESPANOL with PORTUGUES, in the USA_Shared_Composite 1.png file, in this case, you don't need to change anything in the classes.
taurusus is online now   Reply With Quote
Old 28th February 2025, 19:44   #423  |  Link
erick
OK, but I want to replace the audio and subtitles button inside the menu
Old 28th February 2025, 19:56   #424  |  Link
taurusus
The Spanish button is big enough, it can also be replaced without any problems.
[IMG][/IMG]
Old 28th February 2025, 20:07   #425  |  Link
erick
[IMG][/IMG]
Thank you friend, can you share your jar folder with me for this edition?
I have a question, which font are you using?
Old 28th February 2025, 20:18   #426  |  Link
taurusus
Jar folder
https://cloud.mail.ru/public/QWTQ/eryioX3pe
font "Albertus Nova Regular"
Old 28th February 2025, 20:30   #427  |  Link
erick
Jar folder
I edit some Java Disney menus and I always can't edit the png due to the spaces in the png. Can you make a video on how to edit the codes and the spaces so I can't reduce the font size in the png? I don't have in-depth knowledge of Java codes.
Old 28th February 2025, 20:34   #428  |  Link
taurusus
To edit classes, I use the programs "DJ Java Decompiler 3.12" and "JByteMod-1.8.2", which programs do you use?
Old 28th February 2025, 20:38   #429  |  Link
erick
Jar folder
The one you made and sent me broke one there on the select button, it was above the name
https://ibb.co/B5rwZTPw
Old 28th February 2025, 20:41   #430  |  Link
erick
I have these 2 programs Decompiler 3.12" and "JByteMod-1.8.2 here, I just don't understand Java
how to edit the correct code command there, just the Disney menu, that's why I wanted to learn
Old 28th February 2025, 21:03   #431  |  Link
taurusus
I didn't know there were marker dots, that's the only thing that needs to be edited. It's too late now, I'll make an example tomorrow.
Old 28th February 2025, 21:08   #432  |  Link
erick
Okay, thanks friend, have a good night.
Old 7th March 2025, 16:41   #433  |  Link
erick
I have an image in SDR, how do I put the colors of this image in HDR? Would there be a correct setting for a static image in Adobe Photoshop or another program that does this?
Old 7th March 2025, 16:55   #434  |  Link
taurusus
Hi, I sent you a video on how to edit classes, did you get it? The SDR to HDR translation can be done in Color Space Manager, which is a utility in UHD Scenarist.
Old 7th March 2025, 17:13   #435  |  Link
erick
https://www.mediafire.com/file/nl84j...isney.mp4/file
follow the link
Old 7th March 2025, 17:17   #436  |  Link
taurusus
Yes, this is the video that I sent.
Old 7th March 2025, 17:23   #437  |  Link
erick
yes this is the video you sent me I learned a lot about the lesson
Old 7th March 2025, 17:45   #438  |  Link
taurusus
As I have already written, UHD Scenarist is needed for this, I do not know of any other programs.
Old 7th March 2025, 18:55   #439  |  Link
taurusus
File "png"
Old 7th March 2025, 19:12   #440  |  Link
erick
File "png"
Thanks friend, it worked
