5th October 2008, 19:30 | #41 | Link |
Let me add that I did not "tell" that. Case of overinterpretation ... I showed two code sniplets that handle luma ranges for masking, one for 16-235 range, one for 0-255 range, and happened to place the string "BT.709" beneath string "0-255" in a small #codecomment. (Assuming that if you encounter a 0-255 source, it'll probably be BT.709...)
Tried to avoid "but what-if-" nagging by showing both possibilities, got nagging I would have made a claim. Oh well. Guilty for incautious wording. Changed to PC/TV range.
13th November 2008, 09:52 | #43 | Link |
N00B !
source :
agc + smoothlevels(pc2tv) (final script doing everything necessary ie deinterlacing , denoising and a lot of other stuff ) : p.s : did the a.r correction as i deemed appropriate for the testing , also screens taken using print screen so sorry if the pixels are off ( yeah i know prtscrn+paint+crop+save as .png sucks ) but what to do no other option input please ? to my eyes smoothlevels aka ulevels seems to darken the picture a bit up ? used chroma=0 , will test more and post results edit : i know they're annoying(the lines,but thats how the source is ) ( perhaps about time i updated my sharpening arsenal , giving lsfmod a shot in a bit , will post results ) Last edited by ankurs; 13th November 2008 at 09:55. |
15th November 2008, 11:13 | #46 | Link |
Fighting spam with a fish
If it looks good to your eyes, then it's fine. Asking everyone else for their own opinions will only cause you to filter the video to how they want it. If it looks good enough for you to watch, then what does anyone else's opinion matter?
21st November 2008, 19:00 | #50 | Link |
LaTo INV.
Update v1.0beta2 - 2008/11/21
v1.0beta2:
changed Lmode parameter (added Ecenter & strength) updated the documentation + cosmetic Update inspired from my little script LimitedGamma... Now it doesn't use anymore the same synthax as YlevelsS&G, I have made 6 new expression with ajustable strength and some tweak |
26th November 2008, 11:37 | #51 | Link |
LaTo INV.
Update v1.00
v1.00:
first stable release optimized limiting code (faster and less rounding error) added new parameters for limiting (Ecenter,Ecurve) changed strength parameter for 2 others (DarkSTR & BrightSTR) changed code of protect option (hard->soft threshold) |
14th December 2008, 16:37 | #52 | Link |
LaTo, I've probably discovered a bug. Both SmoothLevels(gamma=1.0, Lmode=1, DarkSTR=250, BrightSTR=250) and LimitedGamma2(gamma=1.0,dark_str=250,bright_str=250) create black dots on white surfaces around edges.
These pixels are pure whites (255, 255, 255) originally (looking them at in RGB colorspace), but not all of them becomes black. (Perhaps a rounding error?) |
14th December 2008, 17:37 | #53 | Link | |
LaTo INV.
ImageSource("LimitedGamma_bug_default.jpg").ConvertToYV12() #SmoothLevels(gamma=1.0, Lmode=1, DarkSTR=250, BrightSTR=250) LimitedGamma2(gamma=1.0,dark_str=250,bright_str=250) Please post your script & a sample EDIT: Be sure that MaskTools is up-to-date (v2.0a35) and use the good .dll (mt_masktools-25.dll) Last edited by LaTo; 14th December 2008 at 17:40. |
20th December 2008, 20:03 | #55 | Link | |
It seems it depends on source. Your script with ImageSource() works fine. But loading the original .D2V/.M2V file (taken from a DVD), the black dots appear again. I use AviSynth 2.5.7. The filters seem fine too, they're all the needed versions: mt_masktools-25[2.0a35].dll .................. 2008.04.19 11:02 ...... 724,992 bytes gradfun2db[1.0].dll ................................. 2006.03.15 21:49 ...... 61,440 bytes SmoothLevels.v1.00.avsi ....................... 2008.12.14 15:57 ...... 20,313 bytes RemoveGrain[1.0].dll ............................. 2005.07.31 23:07 ...... 27,648 bytes My script: Code:
LoadPlugin("mt_masktools-25[2.0a35].dll") LoadPlugin("gradfun2db[1.0].dll") Import("SmoothLevels.v1.00.avsi") LoadPlugin("RemoveGrain[1.0].dll") MPEG2Source("TD_Joy_Sales_sample.d2v") ConvertToYV12() SmoothLevels(gamma=1.2, Lmode=1, DarkSTR=250, BrightSTR=250) What's wrong? Last edited by zee944; 20th December 2008 at 20:06. |
25th December 2008, 11:20 | #58 | Link |
Sleepy overworked fellow
Hey,
Just wanted to say thanks for this nice little script! Works like wonders, especially since the first stable release. (darkstr & brightstr = ^_^)
AnimeIVTC() - v2.00 -http://boinc.berkeley.edu/- Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p) |
