18th October 2009, 14:32 | #541 | Link |
Software Developer
I see. So I should keep all those defines for my Win32 builds. Thanks for info
BTW: I wonder why we need both, NDEBUG and _DEBUG. Shouldn't the absence of _DEBUG already indicate that we are in "release mode" or vice versa Doesn't #ifdef NDEBUG have the same meaning as #ifndef _DEBUG in practice? Or are there "historical" reasons?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th October 2009 at 16:44. |
18th October 2009, 15:48 | #542 | Link | ||
Life's clearer in 4K UHD
For transport multiplexes with multiple video streams. Is it not possible to list the video streams information separately, like you do now with audio and subtitle streams?
18th October 2009, 16:01 | #543 | Link |
Software Developer
Oh, please don't rename things. There are people who have existing code to parse the output
Just had to adjust my code, because the "Format" of all WMA files is just "WMA" now, instead of "WMA1", "WMA2" and "WMA3"
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th October 2009 at 17:04. |
18th October 2009, 16:44 | #544 | Link | |||
But as LoRd_MuldeR said, some users don't like I change too much. Legacy is important for other people. I still plan to estimate the change when I do a bigger API update. Not a bad idea. I don't promise to modify it, I will estimate the pro and cons when I change the API ("Container" is maybe not common enough, there is sometime tags or technical info like sattelitte positions and so on... Your point of view is maybe not the point of view from other users) Quote:
If you think about video related stuff (new DAR...), I don't think this is a good idea (see below) Quote:
2/ For multiple video streams, this adds a complexity of the interface (another level). This complexity is too much compared to gains (gains would be for 0.01% of videos, complexity for 100% of videos) Again, I must manage different kind of users, from beginners to expert, from basic AVI file to very complex MPEG-TS with multiple programs files, from people who parse the CLI output to people using th DLL interface, and creating an understable output for all of them is not so easy as taking your advice directly.
Want to know all about your media files? http://mediaarea.net/MediaInfo |
21st October 2009, 21:33 | #545 | Link | |
brontosaurusrex
keywords: osx, mac, droplet, mediainfo whatis: drop some media files on the icon and it will return some mediainfo values. download: http://forum.doom9.org/showthread.php?p=1528488 (now part of the ffdrop collection) install example: click to unpack that zip, drag the app to Applications folder and from there to dock, finder window, desktop. The new version will also accept new files to be droped to the allready opened window. (tested on Lion only) bugs reported: spaces in file names are not handled (can't reproduce) -------------------------- source: Code:
#!/bin/sh cmd=$1/Contents/Resources/mediainfo shift for argument in "$@" ;do echo $argument $cmd "$argument" echo "----------------------------------" done echo "droped files:" for argument in "$@" ;do echo $argument done video, usage http://youtu.be/qu2-mygpN5A
certain other member Last edited by smok3; 19th December 2011 at 20:05. |
22nd October 2009, 09:00 | #546 | Link |
Thanks for this feature.
Do you see any problem if I include it in my official package?
22nd October 2009, 10:59 | #547 | Link |
Sample: http://www.megaupload.com/?d=B7YJAWF0
General Complete name : F:\Test\Button.flv Format : Flash Video File size : 3.58 MiB Duration : 18s 0ms Overall bit rate : 1 670 Kbps Video Format : H.263 Duration : 18s 0ms Bit rate : 62.5 Kbps Width : 704 pixels Height : 400 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Bits/(Pixel*Frame) : 0.009 Stream size : 137 KiB (4%) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Duration : 18s 0ms Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 211 KiB (6%) The total file size is 3.58 MB but the reported size of the streams is 137 KiB (4%) for the video and 211 KiB (6%) for the audio so there is something wrong. Suggestion: for MP3 audio it would be nice if MediaInfo could report if the audio stream is Stereo or Joint Stereo. |
22nd October 2009, 14:51 | #549 | Link | ||
videodatarate value is 62500 bps. Code:
00000009 Meta - onMetaData - 12 elements (283 bytes) 00000009 Header (15 bytes) 00000009 PreviousTagSize: 0 (0) 0000000D Type: 12 (18) 0000000E BodyLength: 10C (268) 00000011 Timestamp_Base: 0 (0) 00000014 Timestamp_Extended: 0 (0) 00000015 StreamID: 0 (0) 00000018 Type: 2 (2) - SCRIPTDATASTRING 00000019 Value_Size: A (10) 0000001B Value: onMetaData 00000025 Type: 8 (8) - SCRIPTDATAVARIABLE[ECMAArrayLength] 00000026 ECMAArrayLength: C (12) (...) 0000005E videodatarate - 62500 (24 bytes) 0000005E StringLength: D (13) 00000060 StringData: videodatarate 0000006D Type: 0 (0) - DOUBLE 0000006E Value: 62.500 (...) I added an integrity check on bitrates (bitrates must be coherent, or metatag info is trashed), next version will have: Code:
Video Format : H.263 Duration : 18s 0ms Bit rate : 1 499 Kbps Width : 704 pixels Height : 400 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Bits/(Pixel*Frame) : 0.213 Stream size : 3.22 MiB (90%) Quote:
Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Format settings, Mode : Joint stereo / MS Stereo Duration : 18s 0ms Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 211 KiB (6%) Thanks for feedback.
22nd October 2009, 18:14 | #550 | Link | |
I didn't notice that because the file was playing fine in many different players I've tried.
Remuxing it with Mencoder fixed it for good. Quote:
Might be very usefull. Nice, thanks |
22nd October 2009, 18:20 | #551 | Link | ||
This is only an "hint" for players. Quote:
This is possible, implementation may be done later if I find a sponsor (--> $) for this. Currently, I implement in priority what can be called a bug or quick feature requests (as Joint Stereo request). You're welcome.
25th October 2009, 02:52 | #552 | Link |
契約者
Hi!
Lets say I have an mkv file with h264 stream in it. This stream has coded frame size 848x480, there is no SAR information on stream level. On container level display dimensions are 853x480. Mediainfo shows DAR -> 16x9; Original DAR -> 16x9. As I understand Original DAR is a stream level information so shouldn't it print something like "unspecified" instead? Otherwise this can be a bit of misleading... EDIT: Ah, one more thing. Why mediainfo always shows "Resolution: 24 bits" for h264 streams produced by x264? I believe x264 can do only YV12, which is no way 24 bit... EDIT2: Also how about printing Container level and Stream level FPS info about h264 video in MKV (and maybe other containers) in cases when FPS is constant? (not sure how things works with non-constant fps, I'm not doing such files) Last edited by Keiyakusha; 25th October 2009 at 04:04. |
25th October 2009, 16:33 | #553 | Link | |||
There is already a discussion about colorspace here: http://sourceforge.net/projects/medi.../topic/3413408 I will add a "Color space" field in all cases (currently, it is displayed only if this is not YUV 4:2:0 for AVC), like this: - Color space = YUV 4:2:0 - Color space = YUV 4:4:4 - Color space = RGB - Color space = RGBA - ... For "resolution" field, I hesitate: I currently put "24 bits" for RGB for example, this seems right, this is 8 bit per color component (R, G, B...) But this is not right for YUV stuff. Which value should I put in this field from your point of view? 'bit depth'? I have no precise idea about this, because 'bit depth' should be maybe by YUV component (8 or 10 bit), but in this case I should maybe change the RGB handling and put "8 bit" too. So... how would you handle the "Resolution" field with for example normal AVC, "High 10" AVC profile, RGB codecs, RGBA codecs? Quote:
General Format : Matroska (...) Video Format : AVC Codec ID : V_MPEG4/ISO/AVC Frame rate : 25.000 fps Original frame rate : 12.500 fps (...)
25th October 2009, 17:38 | #554 | Link | ||
契約者
Anyway it will be good to have SAR value separated from frame size, because 848x480 SAR 1:1 and 848x480 SAR 160:159 is two different things. I think only in second case Original DAR 16:9 should be reported by mediainfo. Quote:
If the file muxed with latest mkvtoolnix I difinitely can see Frame rate and original frame rate. Thanks for explanation but I'm afraid I can't answer to this question. Last edited by Keiyakusha; 25th October 2009 at 17:45. |
25th October 2009, 17:59 | #555 | Link | ||
My goal with this field is to display how a decoder would handle a "non-value". And all decoders I know handle non-value as 1.000 SAR, so I don't see any reason to display "unspecified" for my goal. This is a conscious decision. Quote:
But for the "normal" view, I display "16:9" for DAR between 1.700 and 1.850 (so a DAR of 848/480=1.767 is displayed as 16:9. If you want the precise value, you need to create your own custom view(if you create your own custom view you can display 1.767 instead of a rounded to known value) I already saw some tools removing SAR/DAR from raw stream during the muxing.
25th October 2009, 18:47 | #556 | Link |
Thankfully the issue about where aspect ratio signalling should be placed, ie: within the stream (stream level signalling) or within the container (container level signalling), has been made a lot easier now that Mosu's MKVmergeGUI no longer removes the aspect ratio signalling from the stream by default
25th October 2009, 20:56 | #557 | Link |
This reminds me, on MP4 files the %FrameRate_Mode/String% option works and displays either Constant or Variable. MKV and FLV files, on the other hand, don't display this field - MKV certainly can be VFR, and I thought FLV could too. Are there plans to add support for those, or is it something that can only be easily done with MP4?
25th October 2009, 21:47 | #558 | Link | |
MKV has no index, and has a FrameRate field defined as "Number of frames per second. Informational only" --> I am not sure this field would not be filled with average FPS if the film is VFR. I don't have such a kind of file, I can not see what is the implementation of muxers. I need to parse the whole file to be sure (this would be an option later, not currently implemented). So I prefer not to indicate CFR/VFR value. FLV has no index, and has an optional only framerate metatag, not precise too (what is the content of this value if this is a VFR file? I have no official info about it). So I prefer not to indicate CFR/VFR value (for FLV, I have a better detection implementation, I parse the 30 first frames, if theses frames are VFR, I display "VFR" because I am sure this is VFR, but having the first 30 frames in CFR does not mean all file is CFR, so I don't display it)
26th October 2009, 08:33 | #560 | Link |
Currently the API has not changed for a while, so no problem from my point of view. But each software has its own rules, I have no power on other software.
