Old 7th June 2007, 05:50   #1201  |  Link
pcdthebum
does anyone know how to update the program so that we can incorporate the new drmdbg? or is it just a waiting game?
pcdthebum is offline
Old 7th June 2007, 12:30   #1202  |  Link
SalSimp
Originally Posted by mysekurity View Post
MilOtis: do you know how to disable the "upgrade now" dialog? I've tried setting wmp to never check for updates, but that doesn't work. I've also tried hacking with the dlls, but nothing really came of that. Do you have any ideas? Or is it just a minor annoyance that I'll have to put up with every now and then?
Look at the quote below from my prior post.
Originally Posted by Oneill5491
I don't know if there was a post about this earlier, but is there a way to stop WMP from asking you if you would like to install the available update (from beta 2 to final)?
Yes there is. . . .
1. Reboot Windows in SAFE Mode
2. Go to Program Files>Windows Media Player
3. Find setup_wm.exe
4. Rename it to anything else (e.g. setup_wm0.exe)
5. Reboot Windows
Works also by deleting setup_wm.exe, but renaming is better just in case you want o put it back. There may be other ways of avoiding the nag, but this one works for me.
Note: You have to be in SAFE Mode or else the Windows File Protection feature will put a new setup_wm.exe in the directory.
SalSimp is offline
Old 7th June 2007, 16:24   #1203  |  Link
mysekurity
Petrus2: thanks!
And di3111: I downloaded it, but it didn't seem to do much. I'm running 11.0.57, but I'll try it on a machine with 11.0.6 to see if that might be the issue. Before fairuse came out, I used drmdbg with mixed results. Hopefully someone can port it into fairuse, but I won't hold my breath.
mysekurity is offline
Old 7th June 2007, 17:37   #1204  |  Link
hicux
hey people. Im working on solving the problem for windows vista and Windows Xp. I will upload FairUSeWM 1.4 for Windows Xp and Vista as soon as possible. Thanks to Viodentia that he helped me in some codes. See u soon!
hicux is offline
Old 7th June 2007, 17:38   #1205  |  Link
hicux
New update FairUseWM 1.4
hey people. Im working on solving the problem for windows vista and Windows Xp. I will upload FairUSeWM 1.4 for Windows Xp and Vista as soon as possible. Thanks to Viodentia that he helped me with some codes. See u soon!
hicux is offline
Old 7th June 2007, 17:53   #1206  |  Link
CER22
Awesome! Thanks!
CER22 is offline
Old 7th June 2007, 20:51   #1207  |  Link
froggger
sounds great!!
does anybody still have a copy of fairuse4wm commander??
i can't find a link anywhere!
froggger is offline
Old 8th June 2007, 03:33   #1208  |  Link
mysekurity
froggger: I do. Check your pm box.
Old 8th June 2007, 15:14   #1209  |  Link
Ren
Originally Posted by Ren View Post
milOtis,mysekurity> Thanks for hints, just installing XP to VPC. I tried it on W2003R2, I guess it was the problem. I'll report results ASAP.
WinXPSP2 + WMP 11.0.5721.5145 It don't ask for KB891122 anymore but when I'll individualize from link in this topic, components gets upgraded to 6000=unsupported. But it shouldn't be problem if I don't do individualization, right?
Ren is offline
Old 9th June 2007, 01:54   #1210  |  Link
Episodio1
Is this topic only about drm in audio files?? All that I read is that you still need a valid license to decrypt the video file.
Episodio1 is offline
Old 9th June 2007, 02:08   #1211  |  Link
mysekurity
Episodio1 (and I assume Ren as well): Earlier in the thread, there was talk of DRM removal in WMV files, but I haven't tested it myself. You should just need a valid (playable) license to unDRM it. Either that, or you can use the tools FU4WM is based on (like drmdbg, drm2wmv, etc.), which I know were designed to remove WMV DRM.
Old 9th June 2007, 03:15   #1212  |  Link
mackie
Where can I get a version of WMP 10.0? I have 9 installed, but would rather have 10. Or the beta of 11.
Nevermind, I found it here:
http://www.microsoft.com/windows/win...Downloads.aspx
mackie is offline
Old 9th June 2007, 03:33   #1213  |  Link
mackie
I have another question.
On another computer, I am able to right-click on a song and select convert. Then a Microsoft program would open, and I would be able to convert the wma file to an mp3.
I can't do it on a different computer. Why?
What do I need to do this?
mackie is offline
Old 9th June 2007, 06:57   #1214  |  Link
mysekurity
Mackie (in response to your second post): Your first computer most likely had software that your second computer did not. You say it was a Microsoft program, and without further clarification, I'm going to assume you are talking about either Plus! Audio Converter, which came with the Plus! Digital Media pack for Windows XP or Windows Media Encoder.
To replicate this functionality on other computers, you can install either of the aforementioned Microsoft products (which I wouldn't recommend, having used both for audio conversion), or a number of inexpensive and/or free alternatives available (installing a LAME plugin to dbPowerAMP, for example). Basically what allows you to right-click a file and select it to convert is the result of allowing a process to add itself to the "shell", the user interface between you and the operating system. Any conversion software should have an option to allow itself to be added to the shell, and if not, there are several registry tweaks to facilitate this.
Please let me know if any of this was confusing or if you have any further questions.
Old 9th June 2007, 16:15   #1215  |  Link
mackie
Not confusing at all.
I forgot my original computer had the Media Center version of XP. I have other converters, it was just more convenient to highlight all my songs then right-click and select convert audio format.
Thanks anyway for your reply.
mackie is offline
Old 9th June 2007, 17:42   #1216  |  Link
pcdthebum
Cant wait for the update
yes i edited what i said because it needed to be changed :P
Old 9th June 2007, 19:38   #1217  |  Link
mysekurity
As far as I'm concerned, hicux can take as long as he needs to make sure it works properly. I'd rather have a well-tested release that works on Vista (one of the only reasons I have for not updating yet) than one that doesn't work at all.
Though I do have a few feature requests:
1) Scrubbing of the unique content identifier. I don't like the thought of being tracked by my software.
2) Implementing FairUse Commander right into the shell (making it even easier to use than before)
3) Removal of Zune DRM (not likely, but just thought I'd throw it in)
4) An explanation of what they did to break the tool. I read over the way WMA DRM works, and I'd like to contribute to the project, but I'm wondering what exactly happened to make it stop working...
EDIT: Thanks for reconsidering
Last edited by mysekurity; 9th June 2007 at 23:49. Reason: he edited it, so will I.
Old 9th June 2007, 19:54   #1218  |  Link
KenD00
@pcdthebum: If you think its so easy, no one stops you from doing it by yourself
KenD00 is offline
Old 10th June 2007, 14:21   #1219  |  Link
SalSimp
Of most concern should be number one on the wish list. A lot of users may not be aware of the 'unseen' information that is in the WMA tag. This information even transfers to ID3 tags with most converters and is not evident (seen by programs like Tag&Rename, dBPoweramp, MP3Tag, etc). It will track you as the downloader. All you can do now is strip the tag completely and recreate it with clean information.
So, if you have been sharing. . . .
SalSimp is offline
Old 10th June 2007, 15:27   #1220  |  Link
Danj
This should not be a part of FairUse4WM itself, since it would firmly place it in the position of being a tool of piracy, instead of the legal grey area it currently inhabits. If information is needed to be stripped out of converted files it should be done by a third party tool, so that no blame attaches to FU4WM.
Danj is offline
