Old 12th September 2006, 14:31   #181  |  Link
Digga
User, Registered
Originally Posted by sunny2006
You're always forget about WinAmp that works with wm drm files easily!there's some patch available to use it for convert drm audio to wav or mp3.
there is quite are few media players that can handle DRM content.
converting to another format is called transcoding which will degrade quality. FU4WM goes another route with no quality loss.
Originally Posted by philippas
is there any way that u can unDRM files without being able to play them ?
that implies that you don't have a license.
if there would be a way then it wouldn't be allowed to be discussed here, please read the rules.
...today I like all colours, like Frans Zimmer.
Digga is offline
Old 12th September 2006, 17:20   #182  |  Link
Digga
User, Registered
WinAmp+DRM patch is the best solution for people who cant use fairuse4wm but need to undrm their files.for example if you rip a cd to drm wma by windows media player and need to undrm or convert it.
I guess you should leave the decision what's best for somebody up to them don't you think WinAmp fanboy, uhm, sunny2006?
without having used WinAmp for removal of WM DRM, in your previous post you said that this can be archived via transcoding (i.e. 'convert', the worst possible method).
now you mention the term 'undrm' which implies the pure stripping of the protection from the file without reencoding. can this be done via WinAmp? and if yes you might as well provide a link to the patch.
Digga is offline
Old 12th September 2006, 22:22   #183  |  Link
blutach
Country Member
blutach's Avatar
@Digga - please respect rule 4.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline
Old 13th September 2006, 14:59   #184  |  Link
kits_2004rel
Has anybody seen the source code for FairUse4WM or drmdgb? can anybody post it or upload it someplace?
kits_2004rel is offline
Old 13th September 2006, 15:10   #185  |  Link
brturn
Source code...
It is my understanding that the source code is the same as the FreeMe! program from Beale Screamer released in '01, with a nice GUI wrapper. I'm sure MS has modified the APIs slightly, which viodentia has kept up with as well.
Viodentia mentions the process in this thread (and a little lower in the same thread he reitterates it):
http://forum.doom9.org/showthread.ph...871#post860871
You can find the FreeMe! source and technical description on CrypTome:
http://cryptome.org/beale-sci-crypt.htm
--Bryan
brturn is offline
Old 13th September 2006, 17:30   #186  |  Link
expanium
WMP 10.00.00.3646
IndivBox.key 10.00.00.3646
I used FairUse4WM(automate2.0) three days ago to remove the drm from 4 wmvs and it worked fine. DLed two more wmvs from the same site yesterday, played them on WMP to obtain licences but now FairUse says that the wmvs require a different private key! What gives?
also, load the URL into an embedded IE object...
Can anyone please help me?
Thanks!
expanium is offline
Old 13th September 2006, 18:17   #187  |  Link
protectyoursources
Try extrecting the keys for those movies by clicking the back button on FU4WM .
protectyoursources is offline
Old 13th September 2006, 19:14   #188  |  Link
nike62
thanks
thanks mayang fairuse works ok
nike62 is offline
Old 14th September 2006, 13:49   #189  |  Link
Mauroo
Firstly a big Thank You to viodentia-You may not totally appreciate what true freedom or "digital rights" you have supplied to the people at large against the evil Corporation of Microsoft. Many Thanks.
Now down to business, I have used your program and it works with almost all my files except certain ones which look up the license and play. When I use the program it teels me "###.wmv does not appear to be licensed to you". This is not true because it has been obtained from a paid website. If I am doing something wrong can you or someone please enlighten me.
Mauroo is offline
Old 14th September 2006, 14:06   #190  |  Link
michabo
Has anyone tried FairUse4WM with the latest release from Napster (v.3.7.3.3) UK version?
michabo is offline
Old 14th September 2006, 14:41   #191  |  Link
johner23
More informations about FairUse4WM and fair use in itunes fields too ( QTFairUse program):
---> http://news.zdnet.co.uk/communicatio...9283147,00.htm
In case any iTunes users feel left out:
http://arstechnica.com/news.ars/post/20060913-7737.html
it didn't take developers very long—just a few hours after the announcement, actually—to compile a new working version of QTFairUse6, version 2.3, that strips songs purchased through iTunes 7 of their DRM
devil (johner)
johner23 is offline
Old 14th September 2006, 16:40   #192  |  Link
sirus20x6
Mirrored
I mirrored the new FairUse4WM 1.2 fixed on my site too
http://www.sirus20x6.com
sirus20x6 is offline
Old 14th September 2006, 16:51   #193  |  Link
optimusprime
n00b question here - has M$FT issued a patch for 1.2 yet? I'm using fairuse4wm 1.2 which was working fine on DRM'd wma files until I tried an Amazon Unbox SG1 episode to see if it would work - "recover keys" then said 2 keys recovered, and I couldn't remove the DRM. Then I went back to try more wma files and it wouldn't unDRM those anymore. Recover keys then said 3 keys recovered, but I consistently get the error from FairUse4WM - "<filename> has an unexpected content key value."
what can I do to fix this? TIA.
optimusprime is offline
Old 14th September 2006, 17:45   #194  |  Link
dirtminer
Grouchy User
FU4WM 1.2-fix works fine with Amazon Unbox - scroll back to find that version.
You need to delete or rename the blackbox-keys.txt file in your "My Documents" folder, and extract new keys.
dirtminer is offline
Old 14th September 2006, 18:26   #195  |  Link
markloveshawaii
Why do you ask? They have a 7 day free trial.
markloveshawaii is offline
Old 14th September 2006, 18:43   #196  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
SKY TV pulls down movie downloads because of fairuse4wm :-P
they won't continue their service until m$ offers a working patch against fairuse4wm...
never ending loop story - patch for/ patch against/ patch for/ patch against... loop whole :-)
BSkyB halts film downloads over software cracks
latest mix sets: http://soundcloud.com/sill
sillKotscha is offline
Old 14th September 2006, 18:50   #197  |  Link
michabo
Because Napster released a new version and I wondered if it was patched to break FairUse4WM but I can confirm all is ok.
michabo is offline
Old 14th September 2006, 18:51   #198  |  Link
sillKotscha
what's this for?
he asked because napster could have made a working solution with their latest update against fairuse4wm v1.2fix... but they couldn't ;-)
Old 14th September 2006, 19:32   #199  |  Link
mayang
Totally Newbies
mayang's Avatar
As long as microsoft can't fix the hole or release a new patch for this tool, any media providers that use DRM technology can't prevent you to make this tool not working. They all using Microsoft DRM technology, not their player or software need to be patched but DRM itself.
If microsoft release a new patch soon, Hope it can be broke within a few hours and FairUse4WM v1.3 will in your hand.
mayang is offline
Old 14th September 2006, 20:24   #200  |  Link
johner23
I hope all these attempts failure again and again !!!
God bless you, guys !!!
Keeping helping all the community.
Thanks for all your efforts and great skills !!
devil (johner)
johner23 is offline
