Old 28th May 2018, 10:24   #1  |  Link
martanius
FFmpegSource2 audio encoding
Hello. I recently started using FFmpegSource2 insted of DirectShowSource since it takes like 10 minutes less (or even more with longer videos) to load the video files.
Now encoding video works well but when I try to encode audio, the progress window shows up, it says it's opening file, and shortly after that the window close itself. When I look into the megui log it says it doesn't know that function.
This is what I use:
FFmpegSource2("video.mp4", vtrack = -1, atrack = -1, timecodes="G:\ReCentral\timecodes\timecodes_video.txt")
Anyone know how to encode audio with it? I have to rewrite it to DirectShowSource to be able to encode audio. Even tho it takes much longer.
martanius is offline   Reply With Quote
Old 28th May 2018, 16:02   #2  |  Link
poisondeathray
ffmpegsource2 is a helper function that comes with ffms2.avsi . Place ffms2.avsi in the plugins directory to autoload, or Import() it explicitly, or copy the function to the script
Old 28th May 2018, 16:09   #3  |  Link
sneaker_ger
No, ffmpegsource2() should be part of the dll since 2.22.
Old 28th May 2018, 22:13   #4  |  Link
martanius
Thank you! I placed all dlls and .avsi script in ...\MeGui\tools\avs\plugins and now it works perfectly.
Old 28th May 2018, 22:28   #5  |  Link
sneaker_ger
So you had an old ffms2 version?
Old 28th May 2018, 22:43   #6  |  Link
martanius
The dlls weren't in the plugins folder at all. I have ffms2-2.23.1-msvc.
audio, encoding, error, ffmpegsource, ffms2
