Old 25th May 2015, 09:35   #161  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by MonoS View Post
and for reading?? if all the frames have different width there should be a frameLen in the file, also i don't see any function for creating varying dimension clip for then writing to it
I don't think the width varies in a clip. The output of Analyse has unknown dimensions simply because they are not known until a frame is returned, not because they could change from one frame to the next. Anyway, I'll leave all that as exercises for the reader.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 25th May 2015, 10:20   #162  |  Link
MonoS
Then it should be a trivial task to do via scripting.
i'll try to.implemebt as soon as i return home.
@feisty2: i return home at about 15 utc, if you expect to write it yourself let me know so we don't write it twice
MonoS is offline   Reply With Quote
Old 25th May 2015, 10:41   #163  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I approve of this insanity. My idea for solving the reading (not tested but works in theory):
import vapoursynth as vs
c = vs.get_core()
src = c.ffms2.Source("rule6.avi")
superclip = c.mv.Super(src)
analysis = c.mv.Analyse(superclip, delta=1, isb=True)
vf = open("/stored/vectors.bin")
vector_width = analysis.get_frame(0).width
vector_template_clip = c.std.BlankClip(analysis, height=1, width=vector_width)
def vector_read(n, f):
  vf.seek(n * f.width)
  vector_data = vf.read(f.width)
  fout = f.copy()
  view = fout.get_write_array(0)
  for x in range(fout.width):
    view[0,x] = vector_data[x]
  return fout
vector_clip = c.std.ModifyFrame(clip=vector_template_clip, clips=vector_template_clip, selector=vector_read)
vector_clip.set_output()
Myrsloik is offline   Reply With Quote
Old 25th May 2015, 11:00   #164  |  Link
feisty2
I'm Siri
feisty2's Avatar
@MonoS
gonna try to do it myself, but will let u know if I failed
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 25th May 2015, 15:07   #165  |  Link
feisty2
I'm Siri
feisty2's Avatar
the writing part worked, the reading part popped out an error when I tried to preview it, soon after the error, vaporsynth crashed
Old 25th May 2015, 15:09   #166  |  Link
Myrsloik
Myrsloik's Avatar
line 16 should be:
Old 25th May 2015, 15:18   #167  |  Link
feisty2
I'm Siri
feisty2's Avatar
still error, now it's
"Error getting the frame number 0:
Object is not writable."
Old 25th May 2015, 15:31   #168  |  Link
MonoS
I humbly suggest to add an extra parameter to vector_read for selecting which file to read from.
Something like
vecFile = "/tmp/vectors.bin"
def vector_read(n, f, file):
    vf= open("file", "rb")
    # etc...
    return fout
vector_clip = core.std.ModifyFrame(clip=vector_template_clip, clips=vector_template_clip, selector=functools.partial(vector_read, file=vecFile)
Old 25th May 2015, 15:40   #169  |  Link
feisty2
I'm Siri
feisty2's Avatar
yeah, uh, organizing kinda stuff like this can wait I guess, right now, I can't get it to work, I got "Object is not writable" error
Old 25th May 2015, 21:57   #170  |  Link
Myrsloik
Myrsloik's Avatar
I updated my previous post with a fixed script.
It's basically how you write a raw source filter using only python. Actually you probably could replace most of this with chikuzen's raw source...
Old 26th May 2015, 07:25   #171  |  Link
feisty2
I'm Siri
feisty2's Avatar
so I decide to take the easiest way
simply this works
vw = vec.get_frame(0).width
vecr=core.raws.Source(r"D:\test\vectors.bin", vw, 1, src_fmt="Y8")
vecr.set_output()
edit: replaced "vw" with a log file, no need to create a template anymore now
writing part
log = open(r"D:\test\log.txt", "w").write (repr (vw))
reading part
w=int (open(r"D:\test\log.txt", "r").read ())
vecr=core.raws.Source(r"D:\test\vectors.bin", w, 1, src_fmt="Y8")
vecr.set_output()
Old 26th May 2015, 09:35   #172  |  Link
MonoS
Every time i create the vector file with the same parameters and clip i get a different md5, is this to be expected??
Old 26th May 2015, 09:51   #173  |  Link
feisty2
I'm Siri
feisty2's Avatar
guess ur source filter is the one to blame here, not mvtools, I remember Myrsloik said something like "Don't expect FFMPEG to be bit exact" or whatever similar.
Old 26th May 2015, 09:54   #174  |  Link
Myrsloik
Myrsloik's Avatar
The answer is mostly not but with a bit of yes. Some formats can have +-1 differences due to rounding I think. Try it with something lossless like utvideo or huffyuv as input and see if it's still different.
Old 26th May 2015, 10:48   #175  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Compare the contents.
Edit: Nevermind. I think it's just a little unused memory that never gets initialised.
Old 29th May 2015, 16:33   #176  |  Link
feisty2
I'm Siri
feisty2's Avatar
Do "thsad" and "thscd1/2" have a varying range related to bit depth like "limit" in mv.degrain or they stay in some fixed certain range (always "400" as default whatever input depth is) ?
Old 29th May 2015, 17:00   #177  |  Link
jackoneill
unsigned int
jackoneill's Avatar
The ranges for thsad and thscdX do not vary with the bit depth. They are scaled internally as needed.
Old 30th May 2015, 00:49   #178  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
I'm convinced this is the proper mode of operations for all filters, which should take fractional values instead of requiring the user to know what bit depth they're in anytime a filter is called. I'm glad havs does the heavy lifting for the filters that don't scale input. (Although it's going to have to be done all over again for anything that wants 0...1.0 in float. rean has the right idea there.)
Old 16th June 2015, 14:00   #179  |  Link
feisty2
I'm Siri
feisty2's Avatar
any plan to get mvtools to work on float point clips?
Old 16th June 2015, 14:34   #180  |  Link
jackoneill
unsigned int
jackoneill's Avatar
No.    
