3rd September 2015, 16:40 | #241 | Link |
Yes, I get the error
Failed to evaluate the script: Python exception: knlm.KNLMeansCL: VapourSynthCreate error (clBuildProgram)! Traceback (most recent call last): File "vapoursynth.pyx", line 1469, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:23703) File "/media/TEMPORAL/scrypt.vpy", line 9, in <module> clp = core.knlm.KNLMeansCL(clp, d=0, a=24, s=4, h=3.2) File "vapoursynth.pyx", line 1368, in vapoursynth.Function.__call__ (src/cython/vapoursynth.c:22272) vapoursynth.Error: knlm.KNLMeansCL: VapourSynthCreate error (clBuildProgram)! I'll search what I need to compile correctly for nvidia in Linux. |
3rd September 2015, 17:34 | #242 | Link |
I made some more test and consideration, and i noticed that after the first denoising stage the only noise left is on the low lights so i've modified the second denoising stage to use a mask
deno1 = core.mv.Degrain2(clip=input, super=super, mvbw=mvbw, mvfw=mvfw, mvbw2=mvbw2, mvfw2=mvfw2, thsad=400) def f(x): if x < 12000: return 65535 else: return 0 maskY = core.std.Lut(deno, [0], function=f).std.ShufflePlanes([0], vs.GRAY) mask = core.std.ShufflePlanes([maskY, maskY, maskY], [0,0,0], vs.YUV) deno2 = core.dfttest.DFTTest(deno, sigma=2.5) ret = core.std.MaskedMerge(deno,deno2, mask)#.fmtc.bitdepth(bits=8, dmode=7) ret.set_output() #remove the # from the line below to see the mask #maskY.set_output() |
3rd September 2015, 18:03 | #244 | Link |
@feisty2, dll is for windows. It is not easy to find binaries for Linux
Even developers usually share binaries for Windows, but only sources for Linux. But this is understandable, because each distro maintainers are responsible for putting the binaries in repositories. But for not very common applications is a bit more difficult to find them. @MonoS, In mensje #237 in the first line I have replaced "src" by "clip=ret". Is it right? EDIT: otherwise I get the following error: Code:
Failed to evaluate the script: Python exception: name 'src' is not defined Traceback (most recent call last): File "vapoursynth.pyx", line 1469, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:23703) File "/media/TEMPORAL/scrypt.vpy", line 35, in <module> input = core.fmtc.bitdepth(src, flt=True).fmtc.matrix(mat="601", col_fam=vs.YUV).fmtc.bitdepth(bits=16) NameError: name 'src' is not defined I also needed this (in case some user read this thread in the future): https://github.com/chikuzen/GenericFilters https://github.com/HomeOfVapourSynth...rSynth-DFTTest Last edited by YAFU; 3rd September 2015 at 18:13. |
3rd September 2015, 18:17 | #245 | Link |
@feisty2: i hope this is enough of a reason to not "install" something XD http://abload.de/img/clipboard02wxobh.png [AKA i've other things to do]
@YAFU: I've made hack upon hack on the initial script you linked us, now mine look like this Code:
src = core.imwri.Read("C:/Users/MonoS/Desktop/BlenderCycles-VapourSynth/images/%04d.png", firstnum=50) input = core.fmtc.bitdepth(src, flt=True).fmtc.matrix(mat="601", col_fam=vs.YUV).fmtc.bitdepth(bits=16, dmode=7) superF1 = DitherLumaRebuild(input, s0=1) superF2 = core.mv.Super(superF1, pel=2, sharp=1) super = core.mv.Super(input) mvbw2 = core.mv.Analyse(superF2, isb=True, delta=2, overlap=4) mvbw = core.mv.Analyse(superF2, isb=True, delta=1, overlap=4) mvfw = core.mv.Analyse(superF2, isb=False, delta=1, overlap=4) mvfw2 = core.mv.Analyse(superF2, isb=False, delta=2, overlap=4) deno = core.mv.Degrain2(clip=input, super=super, mvbw=mvbw, mvfw=mvfw, mvbw2=mvbw2, mvfw2=mvfw2, thsad=400) def f(x): if x < 12000: return 65535 else: return 0 maskY = core.std.Lut(deno, [0,1,2], function=f).std.ShufflePlanes([0], vs.GRAY) mask = core.std.ShufflePlanes([maskY, maskY, maskY], [0,0,0], vs.YUV) ret = core.std.MaskedMerge(deno,core.dfttest.DFTTest(deno, sigma=2.5), mask)#.fmtc.bitdepth(bits=8, dmode=7) you don't need anymore GBlur, some testing showed me that it lower the final quality and destroy a lot of small details, so no need to use generics [and AFAIK they'll be included in the next main version of vapour] If feisy said that dfttest is not the ideal solution, trust him, he surely made more extensive testing than me on that, so better link KNLMeansCL |
5th September 2015, 15:17 | #250 | Link |
I'm Siri
xxx sup = MSuper(last,chroma=False) bv1 = MAnalyse(sup,isb=True,blksize=16,overlap=8,delta=1,search=3,truemotion=True,dct=1,chroma=False) fv1 = MAnalyse(sup,isb=False,blksize=16,overlap=8,delta=1,search=3,truemotion=True,dct=1,chroma=False) bv2 = MAnalyse(sup,isb=True,blksize=16,overlap=8,delta=2,search=3,truemotion=True,dct=1,chroma=False) fv2 = MAnalyse(sup,isb=False,blksize=16,overlap=8,delta=2,search=3,truemotion=True,dct=1,chroma=False) bv3 = MAnalyse(sup,isb=True,blksize=16,overlap=8,delta=3,search=3,truemotion=True,dct=1,chroma=False) fv3 = MAnalyse(sup,isb=False,blksize=16,overlap=8,delta=3,search=3,truemotion=True,dct=1,chroma=False) MDegrain3(last, sup, bv1, fv1, bv2, fv2, bv3, fv3, thsad=2000, thscd1=10000) converttoy8 () Code:
import vapoursynth as vs core = vs.get_core() clp = xxx clp = core.std.ShufflePlanes(clp, planes=0, colorfamily=vs.GRAY) clp = core.fmtc.bitdepth(clp, fulls=False, fulld=True, bits=32, flt=True) clp2 = core.fmtc.bitdepth(clp, fulls=False, fulld=True, bits=16) sup = core.mvsf.Super(clp) bv1 = core.mvsf.Analyze(sup,isb=True,blksize=16,overlap=8,delta=1,search=3,truemotion=True,dct=1) fv1 = core.mvsf.Analyze(sup,isb=False,blksize=16,overlap=8,delta=1,search=3,truemotion=True,dct=1) bv2 = core.mvsf.Analyze(sup,isb=True,blksize=16,overlap=8,delta=2,search=3,truemotion=True,dct=1) fv2 = core.mvsf.Analyze(sup,isb=False,blksize=16,overlap=8,delta=2,search=3,truemotion=True,dct=1) bv3 = core.mvsf.Analyze(sup,isb=True,blksize=16,overlap=8,delta=3,search=3,truemotion=True,dct=1) fv3 = core.mvsf.Analyze(sup,isb=False,blksize=16,overlap=8,delta=3,search=3,truemotion=True,dct=1) clp = core.mvsf.Degrain3(clp, sup, bv1, fv1, bv2, fv2, bv3, fv3, thsad=2000, thscd1=10000) sup2 = core.mv.Super(clp2) bv12 = core.mv.Analyse(sup2,isb=True,blksize=16,overlap=8,delta=1,search=3,truemotion=True,dct=1) fv12 = core.mv.Analyse(sup2,isb=False,blksize=16,overlap=8,delta=1,search=3,truemotion=True,dct=1) bv22 = core.mv.Analyse(sup2,isb=True,blksize=16,overlap=8,delta=2,search=3,truemotion=True,dct=1) fv22 = core.mv.Analyse(sup2,isb=False,blksize=16,overlap=8,delta=2,search=3,truemotion=True,dct=1) bv32 = core.mv.Analyse(sup2,isb=True,blksize=16,overlap=8,delta=3,search=3,truemotion=True,dct=1) fv32 = core.mv.Analyse(sup2,isb=False,blksize=16,overlap=8,delta=3,search=3,truemotion=True,dct=1) clp2 = core.mv.Degrain3(clp2, sup2, bv12, fv12, bv22, fv22, bv32, fv32, thsad=2000, thscd1=10000) clp2 = core.fmtc.bitdepth(clp2, fulls=True, fulld=True, bits=32, flt=True) fnl = core.std.StackHorizontal([clp,clp2]) fnl.set_output () @jackoneill guess I just fixed dct 1-4 (fftw modes) in my floating point branch tried to fix it on uint16_t, your original version, but failed maybe you could try to fix it yourself more details at https://github.com/IFeelBloated/MVTo...er/DCTFFTW.cpp |
7th September 2015, 13:30 | #251 | Link |
Hello. I've been doing some experiments.
Apparently what mainly produces banding is this line at end in the original script: Code:
ret = core.fft3dfilter.FFT3DFilter(ret,sigma=2.5, bt=5, bw=32, bh=32, ow=16, oh=16, sharpen=0.7) I have understood that this line is to reduce fine grain noise, right? I found a good way for those banding are not very noticeable. Basically, create a lossless video with the original script, but without that line. Then apply the script to the resulting video, but in superF1 replacing with the values of that line that was removed: Code:
import vapoursynth as vs core = vs.get_core() ## ##ffmpeg with ffms2 core.std.LoadPlugin('/usr/lib/x86_64-linux-gnu/libffms2.so.3') ret = core.ffms2.Source(source='/PATH_TO_VIDEO_HERE/encoded.mkv') ## input = core.fmtc.bitdepth (clip=ret, bits=8) superF1 = core.fft3dfilter.FFT3DFilter(input,sigma=2.5, bt=5, bw=32, bh=32, ow=16, oh=16, sharpen=0.7) superF2 = core.mv.Super(superF1, pel=2, sharp=1) super = core.mv.Super(input) mvbw3 = core.mv.Analyse(superF2, isb=True, delta=3, overlap=4) mvbw2 = core.mv.Analyse(superF2, isb=True, delta=2, overlap=4) mvbw = core.mv.Analyse(superF2, isb=True, delta=1, overlap=4) mvfw = core.mv.Analyse(superF2, isb=False, delta=1, overlap=4) mvfw2 = core.mv.Analyse(superF2, isb=False, delta=2, overlap=4) mvfw3 = core.mv.Analyse(superF2, isb=False, delta=3, overlap=4) ret = core.mv.Degrain3(clip=input, super=super, mvbw=mvbw, mvfw=mvfw, mvbw2=mvbw2, mvfw2=mvfw2, mvbw3=mvbw3, mvfw3=mvfw3, thsad=400) ret.set_output() I guess that I've done it can be done from a single script without the intermediate step by creating these first video, but I have no idea about how to create this script. How could I do it? The noise reduction in the kind of noise that renders from Blender 3D generate using this method/script is amazing. It is a pity that Fft3d not support 16 bits because the result could be even better. Do you know if that filter is still under development and whether it plans to support 16-bit? Last edited by YAFU; 7th September 2015 at 13:38. |
7th September 2015, 16:41 | #252 | Link |
Hello HolyWu.
It seems that in the HAvsFunc thread there are no instructions for Linux. Where should I copy havsfunc.py in Linux? Regarding suggestions of MonoS, I was able to build this script with parts of code from his different messages, I do not know if I have done well: http://www.pasteall.org/61017 For now I get better noise reduction with the original script using FFT3DFilter. |
7th September 2015, 19:24 | #253 | Link |
Just in case this is useful to someone else, I explain:
I have installed at least three versions of python (I guess they have been left of different system updates). So I have different paths to "/pythonX.Y/site-packages" both in "/usr/local/lib" and "/usr/lib". So from linux terminal: Code:
whereis vapoursynth I will study this little script and do some testing with these images that I have shared in previous posts in this thread. |
7th September 2015, 20:00 | #254 | Link |
If you don't want to deal with root access every time you want to update/install a new module:
# echo "/home/your-user/some-path-to-a-directory-with-all-your-modules" > /usr/local/lib/python3.4/site-packages/vapoursynth_modules.pth |
8th September 2015, 19:03 | #256 | Link |
If someone don't come up with some suggestion, this is my "final suggestion"
The video outputted is this one http://www.mediafire.com/watch/mws7c9hgwwrsqjm/test.mkv The script used this [i wrote some comments for you] Code:
import vapoursynth as vs import havsfunc as has core = vs.get_core() #Load imwri core.std.LoadPlugin("C:/Program Files (x86)/VapourSynth/plugins64/imwri/imwri.dll") #Read images src = core.imwri.Read("C:/Users/MonoS/Desktop/BlenderCycles-VapourSynth/images/%04d.png", firstnum=50) #converting input RGB images to YUV444 input = core.fmtc.bitdepth(src, flt=True).fmtc.matrix(mat="601", col_fam=vs.YUV).fmtc.bitdepth(bits=16, dmode=7) #This should improve motion estimation for darken zones superF1 = has.DitherLumaRebuild(input, s0=1) superF2 = core.mv.Super(superF1, pel=2, sharp=1) super = core.mv.Super(input) #Do motion compesated denoising mvbw2 = core.mv.Analyse(superF2, isb=True, delta=2, overlap=4) mvbw = core.mv.Analyse(superF2, isb=True, delta=1, overlap=4) mvfw = core.mv.Analyse(superF2, isb=False, delta=1, overlap=4) mvfw2 = core.mv.Analyse(superF2, isb=False, delta=2, overlap=4) deno = core.mv.Degrain2(clip=input, super=super, mvbw=mvbw, mvfw=mvfw, mvbw2=mvbw2, mvfw2=mvfw2, thsad=400) #After first denoising stage the majority of the grain is on the darker zone, create a mask of only the dark zones def f(x): if x < 12000: return 65535 else: return 0 maskY = core.std.Lut(deno, [0,1,2], function=f).std.ShufflePlanes([0], vs.GRAY) mask = core.std.ShufflePlanes([maskY, maskY, maskY], [0,0,0], vs.YUV) #Do a second pass of spatial denoising only on the masked zones ret = core.std.MaskedMerge(deno,core.dfttest.DFTTest(deno, sigma=2.5), mask) #Delete # below to output a 8bit clip #ret = core.fmtc.bitdepth(bits=8, dmode=7) ret.set_output() #Delete # below to output a video showing the difference between the the first and second denoise pass #core.std.Interleave([deno, ret]).set_output() #Delete # below to output the mask #mask.set_output() EDIT: i've thrown inside the script the jpg you sent us at the beginning, FAAAAR better result if you ask me http://www.mediafire.com/watch/ypwrf...fy/testjpg.mkv Last edited by MonoS; 8th September 2015 at 19:24. |
8th September 2015, 21:01 | #257 | Link |
@MonoS, Thank you very much for your scripts and suggestions. I had not tasted much your scripts because I did not know how to create a functional script from what you said in each message, I really know very little about these issues and I am learning. With time I'm going to analyze what each filter do and learning how it works.
Edit: The comments you made into the last script are really helpful to learn, thanks. In the BlenderArtists forum, "brothermechanic" has done new tests and he found a way to minimize banding: http://www.blenderartists.org/forum/...=1#post2933482 For now we are stuck with "fft3dfilter", it seems to be the best handling this kind of noise generated by Blender/Cycles. But I will continue testing to find the best 16 bits solution. You see the example with "hard-denoise" filter. Similar that way should look material in cubes if they have no noise in render. However, in other situations it would be necessary to preserve details, without much noise reduction. Thanks. Last edited by YAFU; 8th September 2015 at 21:50. |
14th September 2015, 04:04 | #258 | Link |
Pig on the wing
Is there any possibility to get the functionality of MShow included? I use it quite often to adjust thscd1 and thscd2 to match the source better.
EDIT: Also, is it OK to simply resize to double the dimensions of the clip fed to Super as pelclip? In Avisynth 2.6, you need to do some shifting.
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 14th September 2015 at 18:13. |
15th September 2015, 16:54 | #259 | Link |
Pig on the wing
OK, I got some more odd behaviour. It could be MVTools acting up but it's still quite interesting.
This one works properly, that is, Degrain1 does what it is supposed to do: Code:
import vapoursynth as vs import havsfunc as has core = vs.get_core() core.avs.LoadPlugin(r'c:/program files (x86)/avisynth/plugins/dgdecodenv.dll') clp = core.avs.DGSource('c:/x265/hotfuzztest.dgi') #clp = core.fmtc.bitdepth(clp, bits=16) feed = has.DitherLumaRebuild(clp) pelmdg = core.resize.Spline(clp,width=clp.width*2,height=clp.height*2) pelprefilt = core.resize.Spline(feed,width=clp.width*2,height=clp.height*2) superanalyse = core.mv.Super(feed,pel=2,chroma=True,rfilter=4, pelclip=pelprefilt) supermdg = core.mv.Super(clp,pel=2,chroma=True,rfilter=4,levels=1, pelclip=pelmdg) bv1 = core.mv.Analyse(superanalyse, dct=5, blksize=16, overlap=8, isb=True) fv1 = core.mv.Analyse(superanalyse, dct=5, blksize=16, overlap=8) finalclip = core.mv.Degrain1(clp, supermdg, bv1, fv1, thsad=400, thsadc=400, limit=5, limitc=6) org = clp final = core.std.Interleave(clips=[org,finalclip]) final.set_output()
15th September 2015, 17:08 | #260 | Link |
I'm Siri
all 10 modes of dct are broken in the current binary, dct 5-10 have been fixed in the source code, but no binary available yet, dct 1-4 are just broken
I fixed all dct stuff in my floating point branch tho, if u wanna try it Last edited by feisty2; 15th September 2015 at 17:19. |
