#1 | Link |
How to cut video frame accurate without encoding?
How can I cut video by frame number? when I cut the video
With ffmpeg it skips to next keyframe I want to cut video with specific frame number or specific time I set how can I do this? İs there a free program for this? Or how can I do this with ffmpeg? Last edited by For Fun; 4th November 2020 at 17:27. |
#2 | Link |
If your video is MPEG2 elementary streams (DVD format) then you can use Cuttermaran. No longer maintained, but very reliable.
For other formats the only free solution I am aware of is VidCutter. But it is not very reliable. A commercial software for frame accurate cutting is Smart Cutter, it works nicely most of the time, but it costs $. |
#4 | Link |
Without re-encoding, you can only cut on keyframes in h264/h265.
Partial re-encoding might be what you are looking for, aka "smart rendering", but AFAIK no free program does it.
bShaders: realtime Effects/filters for video players |
#5 | Link | |
Life's clearer in 4K UHD
It's quite a faff but it works ![]()
#6 | Link |
What do you think about this program:
https://github.com/mifi/lossless-cut/ I did only a few tests by myself and therefore cannot decide, if it would fit your needs. |
#7 | Link | |
Lossless Cut is nice, but just like other free solutions it only cuts at key frames. From the readme:
TSDoctor (commercial, but has a 30 days trial period) has an option for AVC streams to cut not only on key frames, but also on P-frames. I did not expect good cuts from this option, but surprisingly it worked really well in most cases. Of course you cannot say that this is frame accurate, but still much better than only cutting on I-frames. |
#8 | Link | |
Lossless-cut is another lossless cutter (cut sequence must start on a keyframe).
ffmpeg gui, ffmpeg x264 mp4 quicktime, ffmpeg.mkv, video converter help |
