Old 29th November 2011, 04:11   #1  |  Link
infoeater
MeGUI - x264 CRF 1st pass + CRF based 2nd pass (with VBV)
Is it possible to use MeGUI to encode video with constant CRF and use data from such encode in 2nd pass? It should benefit quality if VBV is used.
Is it possible to overwrite chosen by GUI command line for x264?
infoeater is offline   Reply With Quote
Old 29th November 2011, 23:35   #2  |  Link
fantasmanegro
as far as i know that's is the way 2pass works... and i guess you can edit x264 command line
fantasmanegro is offline   Reply With Quote
Old 30th November 2011, 23:56   #3  |  Link
infoeater
It is how it's working in Xvid. In x264 by defaut ABR is used in first pass, which is reasonable if you are targeting file size, but not if you are targeting quality, but with bitrate restrictions.
ok, good news! How to do it in MeGUI?
Note: I know what I want to change in command line for x264, I just don't know how to force MeGUI to use my command line instead of one generated by MeGUI. I can view it, but it's on grey background, and I can't edit it.
Old 1st December 2011, 10:00   #4  |  Link
Marin85
You can edit it from the last tab.
Marin85 is offline   Reply With Quote
Old 1st December 2011, 13:59   #5  |  Link
infoeater
I don't know how I missed it. Thank You!
2-pass, crf, megui, x264
