Old 26th April 2011, 22:58   #1  |  Link
wiggaz
DTS conversion from 24 to 23.976
Hello.
How can I convert a DTS from 24 fps to 23.976, using eac3to, preserving the best quality?
I know the 2 basic eac3to line-commands "slowdown" and "speedup" for the 23.976->25 / 25-> 23.976 conversion, but starting from 24, I don't really know where to begin.
Thanks in advance.
Bye
wiggaz is offline   Reply With Quote
Old 27th April 2011, 00:29   #2  |  Link
tebasuna51
tebasuna51's Avatar
eac3to input output -24.000 -changeTo23.976
Old 29th April 2011, 22:05   #3  |  Link
Anacletus
Anacletus's Avatar
This procedure will involve a re-encode of the audio track, besides the video track is probably 24 fps too, so you shouldn't need to do this at all if you are going to encode a BD.
Anacletus is offline   Reply With Quote
Old 4th May 2011, 14:47   #4  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Indeed. If your final target format supports it, I'd avoid re-encoding DTS -> DTS, and go DTS -> AAC... just my two cents.
Old 4th May 2011, 15:15   #5  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by wiggaz View Post
Hello.
Are you 100% sure your DTS audio source runs at 24fps?
If the DTS audio has been extracted from an (NTSC) DVD or Blu-ray disc movie, the chances are it's running at 23.976fps already!
23.976, conversion, dts
