Old 15th August 2012, 07:44   #20061  |  Link
ryrynz
ryrynz's Avatar
I'm merely posting this for the curious. Any questions or comments you might have regarding MPC-BE should not be posted here. Enjoy.
MPC-BE build 802
Link removed for GPL reasons, new version stable release due out shortly, keep an eye out in the next few weeks.
ryrynz is offline
Old 15th August 2012, 09:02   #20062  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE build 802.
... and this message here should not be, you violates the GPL!
p.s.
This building has several problems, which may adversely affect the operation of your computer.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline
Old 16th August 2012, 13:16   #20063  |  Link
bozek
Right.
bozek is offline
Old 18th August 2012, 02:12   #20064  |  Link
Anonymous9377
is there a way to undock the controls and be able to drag them around the screen separate from the video like vlc?
cause i play video outside of the player and vlc 1.x cuts off video at the end, and vlc 2.x resizes the video when a new 1 is played instead of the fixed size selected
mpc doesn't have this problem but i need to undock and drag the controls independent of the screen.. seems like every video player has an achilles heel
i know its a customize niche but hey
some suggestions i have for mpc-hc
or "make mpc more like vlc"
1. option to undock controls separate from the video
need to move the controls away from the video
2. have playlist not appear in full screen like controls
when in full screen playlist is over the video
3. option to have controls appear in full screen mode
controls disappear in full screen unlike vlc
4. option to disable dragging video when you click on it
click the video for full screen etc. and accidentally moved
thank you very much
Anonymous9377 is offline
Old 18th August 2012, 02:13   #20065  |  Link
keneo
underground? or anyone?
Calling all programmers!
I am a novice programmer with no experience in Windows programming.
My vision for a modification to mpc-hc is that the user could now add custom commands (consisting of a system commandline call and an associated hotkey to trigger that custom command) to the table on the "Keys" Option page. The commandline can include insertable paramaters such as <currently playing media full path name>, <the current media play position>, <the current media length>, etc...
I have made what I consider to be a lot of progress. But now I am at the point where I need to tell my new subroutine which hotkey was pressed. As far as I know it is not possible to call a message map function that uses parameters. Unfortunately, using a parameter was my entire plan A for passing along the hotkey info.
So now I need a plan B.
My thinking is that the function that gets called from the message map could some how find out what the latest hot key pressed was. So, is there a way to know what the last hotkey pressed was? if not, maybe I could insert some code somewhere to record the hotkey so that it can now remember? (I dont really like the idea of inserting code into someone elses routines, but if that's the only way, then so be it.)
Or plan C
Bypass the message map completely. Insert code to intercept the hotkey and branch off from there if any of the custom command hotkeys are pressed. That sounds like the the most horrible idea of them all. But I am totally open to any help!
keneo is offline
Old 18th August 2012, 17:38   #20066  |  Link
jos99
Is there any way to set the size of the window in pixels when you open MPC HC?
jos99 is offline
Old 19th August 2012, 00:05   #20067  |  Link
Anonymous9377
not an expert on this but since its slow;
1. select option to make player adjust to video size
2. get or make a video the size you want
3. open video thats the size you want
4. unselect option to make player adjust to video size
or
1. if you know how do the same thing in vlc
2. stretch the screen so its the same as vlc's window
i dont remember how i did it exactly but good luck
Old 19th August 2012, 12:55   #20068  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
https://github.com/mpc-hc/mpc-hc/commit/d78ea81f39e5b6c8d3c8bfa69a37e03f409ef9bf
why remove .dat extension?
If you remove the MPC-HC will not play .dat files on the VCD discs form CD-ROM OR DVD-ROM!
http://forum.doom9.org/showthread.php?p=1178911#post1178911
betaking is offline
Old 19th August 2012, 14:55   #20069  |  Link
jos99
Thanks, that option doesn't really work as if you unselect it, it just reverts to the default small opening size & if you select it, it just saves whatever variable size of the video you just played. Any experts have any idea about how to change the default window size?
In case people didn't see the thread, there are two really nice toolbar skins from jinsk8r http://archangelx2.deviantart.com/ that I reposted
http://forum.doom9.org/showthread.ph...41#post1587541
they didn't work originally as they only posted jpgs, they have now posted BMPs & they look great
can someone add to the toolbar skin wiki page as I don't have permissions:
https://sourceforge.net/apps/trac/mp...Toolbar_images
jos99 is offline
Old 19th August 2012, 17:07   #20070  |  Link
73ChargerFan
73ChargerFan's Avatar
I'd like a right-click option to lock the window size, that holds only until the player is closed.
I often have a playlist of short cartoons of varying resolutions, off to one side of my screen while I'm reading a web browser on the other side (gotta love wide screens!) Every 5 minutes, when the next cartoon starts, the player resizes and I have to fix it.
This would be VERY handy.
73ChargerFan is offline
Old 19th August 2012, 18:00   #20071  |  Link
VipZ
I think disabling auto zoom in options should do this for you.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline
Old 19th August 2012, 19:59   #20072  |  Link
jos99
Yeah that does work, you'd need to keep re-enabling it if you wanted to watch in full size but not full screen tho'. It would be nice if you could have various window size presets you could select by right clicking i.e. auto zoom, default, preset 1, preset 2, preset 3 etc that are remembered even on restart.
jos99 is offline
Old 19th August 2012, 20:39   #20073  |  Link
VipZ
Disabling auto zoom and then using alt+2 (100% zoom, there are other presets as well) if you want to set video to 100% size. Personally I like to set my own window size at let media fill that size so I can do similar to you, watch and read stuff at same time.
VipZ is offline
Old 19th August 2012, 21:39   #20074  |  Link
jos99
Thanks, it was mainly for aesthetic reasons though that I wanted MPC-HC to start at a certain size each time, if I resize at all it just remembers that setting. Anyway, I've worked out what I want to do now, default starting size is simply determined by the size of the logo, I wanted mine about 535 pixel square, the top controls are about 50px, bottom 95px, sides 7px each on Windows 7 so the logo needs to 521 x 390 px.
jos99 is offline
Old 19th August 2012, 23:29   #20075  |  Link
v0lt
I've seen a real VideoCD only once. He did not impress me compared to DivX 3.11. Most users do not know what a VideoCD.
.dat extension of very often used to store anything, but not for video. We have suffered for almost ten years. Now we are well, we're happy.
.dat playback nowhere gone. If you want the association, then it is done manually (added manually to "Other" group) or by means of Windows ("Open as...").
You can also rename the .mpg.
v0lt is offline
Old 20th August 2012, 21:31   #20076  |  Link
tetsuo55
MPC-HC Project Manager
VideoCD is still really popular in asian countries.
New VideoCD's get released about as often as DVD/Bluray.
There are even many videos that where only ever released on VideoCD ( i have a 100 disks myself)
I agree that it is unfortunate mpeg chose a common extention like .dat
My preference would be for your reverting the .dat part of the commit.
tetsuo55 is offline
Old 21st August 2012, 03:30   #20077  |  Link
jos99
Modified MPC logo that was on jinsk8r's (http://archangelx2.deviantart.com) screenshot to MPC-HC
http://dl.dropbox.com/u/35202345/mpchclogogreenmask.png
you can paste that as a layer onto any image and save as a bmp or png (merge/flatten layers if asked) & use any image as the MPC-HC logo background.
jos99 is offline
Old 22nd August 2012, 14:06   #20078  |  Link
jos99
Cleaned up the text a bit
http://dl.dropbox.com/u/35202345/mpc...greenmask3.png
logo on black
http://dl.dropbox.com/u/35202345/mpchclogogrnonblk.png
MPC-HC on mars
http://dl.dropbox.com/u/35202345/mpchcmarscurios.png
jos99 is offline
Old 22nd August 2012, 18:21   #20079  |  Link
ney2x
This is the logo I am using
ney2x is offline
Old 23rd August 2012, 16:19   #20080  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
VSfilter 1.6.2 & 1.6.3 Incompatible
I'm experiencing a strange incompatibility about how VSFilter handles the advanced SSA tag {\frx}.
In VSFilter 1.6.3.5818, for example {\frx-10} works like {\frx+10} in 1.6.2.4902, at least sometimes. As if the sign of the parameter had been reversed between v1.6.2 and v1.6.3.
Samples:
"{\fnVerdana\fs32\b1\frx+30}Test frx+30" with 1.6.2
"{\fnVerdana\fs32\b1\frx-30}Test frx-30" with 1.6.3
"{\fnVerdana\fs32\b1\frx-30}Test frx-30" with 1.6.2
"{\fnVerdana\fs32\b1\frx+30}Test frx+30" with 1.6.3
Well, though it may be just me, this could be a serious problem for SSA/ASS typesetters. Did I do anything wrong? I'm still on Windows XP if that's a sin...
EDIT: I'm using VSFilter from the standalone_filters package, via Avisynth.
EDIT2: Maybe a problem in Transform_SSE2, enabled in Revision 5569, as opposed to the classic Transform_C?
Liisachan is offline
dxva, h264, home cinema, media player classic, mpc-hc
