12th August 2018, 14:38 | #5563 | Link |
There is no such option.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
18th August 2018, 18:18 | #5564 | Link | |
19th August 2018, 02:54 | #5565 | Link |
StreamBuffRe reject connection from internal filters(in latest version), all questions to the author.
P.S. For twitch need install LAV Filters.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 19th August 2018 at 03:12. |
20th August 2018, 23:51 | #5566 | Link | |
EDIT: I don't want to have to install external filters just to be able to play Twitch VODs (streams work fine except for the fact that they disconnect on me often). Last edited by Zero3K; 20th August 2018 at 23:56. |
21st August 2018, 02:52 | #5567 | Link | |
I have tried advanced settings in LAV Splitter with !d and !f in the string but the player just seems to ignore those settings. I can see no way to permanently set mpc-be to automatically prefer an external subtitle file, if available. If it is set manually, it only appears to apply to the specific file where it is set, and not to other files. |
21st August 2018, 07:11 | #5568 | Link |
It works here with srt subs, using lavfilters as well, but the sub management is done by mpc-be (uaing latest beta).
You have to name the subs properly.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
21st August 2018, 07:59 | #5569 | Link | |
The issue I have is that, if there is an internal default subtitle stream in the video file, then mpc-be will select that regardless of the setting in the player "Prefer external subtitles over embedded subtitles". The external subtitles can be selected manually from the drop-down menu while the file is playing (or paused) but that setting only applies to that file, not any other file. If there are no internal (embedded) subtitles then the external subtitle file is picked up by the player as the default (only) option available. |
21st August 2018, 10:33 | #5570 | Link | |
Good. Although I use these: "foo.EN.srt", "foo.DE.srt", etc.
I wrote a small guide for MadVR - MPC-HC/BE here: https://forum.doom9.org/showthread.p...39#post1820039 Although I don't see anything interesting in it that you haven't mentioned yet. Is it maybe a lavsplitter setting? Can you post yours? (I can check mine in the evening.)
21st August 2018, 11:20 | #5571 | Link | |||
Thanks for the response.
I am talking specifically about when using the internal subtitle renderer. When using VSFilter/xy-VSFilter or XySubFilter it does appear to honor the flag "Prefer external subtitles over embedded subtitles", however subtitle font sizes have to be edited to suit different video resolutions. Ideally I would prefer to use the internal subtitle renderer, and to have mpc-be honor the flag "Prefer external subtitles over embedded subtitles". I have tested this both with 1.5.2 (build 3788) beta and with production build MPC-BE.1.5.1, both x64 versions. Neither appears to honor the flag "Prefer external subtitles over embedded subtitles". I haven't tested this with the x86 versions. Quote:
Regards EDIT: My apologies, the issue appears to be confined to the 1.5.2 (build 3788) beta. With production build MPC-BE.1.5.1 the flag "Prefer external subtitles over embedded subtitles" appears to be honored if set a preferred language at "Options -> Playback -> Default track preference; Sub eng. The issue may be related to a different way of selecting subtitle streams in the beta. Regards Last edited by raymondjpg; 21st August 2018 at 11:43. |
21st August 2018, 11:34 | #5572 | Link | |||
It must be a setting somewhere since it works for me
21st August 2018, 11:48 | #5573 | Link |
Just now check loading external subtitles with "Prefer external subtitles over embedded subtitles", using internal subtitle renderer. When options check - always loading external subtitles by default, uncheck - loading internal subtitles.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
21st August 2018, 12:07 | #5574 | Link |
I did add an edit on my last post:
EDIT: My apologies, the issue appears to be confined to the 1.5.2 (build 3788) beta. With production build MPC-BE.1.5.1 the flag "Prefer external subtitles over embedded subtitles" appears to be honored if set a preferred language at "Options -> Playback -> Default track preference; Sub eng. The issue may be related to a different way of selecting subtitle streams in the beta. Regards |
21st August 2018, 14:33 | #5575 | Link |
No worries, but I also use the latest beta (I don't recall the build number now).
21st August 2018, 18:45 | #5576 | Link | |
Lav Splitter (0.72.0) settings (I think these're the default ones): - audio: none - subs: none - sub selection mode: default - Blu-Ray Subs: x enable auto forced sub streams - Demuxer settings: x demux sub-streams separately
22nd August 2018, 00:17 | #5577 | Link | |
1. If you have an external subtitle file, temporarily rename it. 2. Play the video, and using the right click on the screen, see which of the available subtitle streams is selected. That would be the situation that would apply if no external subtitle were available. The player would select one of the internal streams. 3. Rename the external subtitle file exactly the same as the video file, and play again. 4. When you right click on the screen, do you still see the same internal subtitle stream selected that you saw at step 2? I do, with 3788 x64, and that is what I mean by the player not honoring the flag "Prefer external subtitles over embedded subtitles". If I use production version MPC-BE.1.5.1.x64, then at step 3 the flag "Prefer external subtitles over embedded subtitles" is honored. The external subtitle file is selected in preference to the internal streams. I am not complaining. I suspect that the difference in behavior is due to the different ways in which the subtitle streams are selected in the production and beta versions. In the beta version, once a stream is selected on right click, be it internal or external, that stream is always selected as long as that file is remembered in the .ini file, regardless of the flag "Prefer external subtitles over embedded subtitles". In some ways that ability to select the subtitle stream (not in the latest production version) may be beneficial for some users. I prefer to always have the "Prefer external subtitles over embedded subtitles" flag honored, so I have gone back to using the production version MPC-BE.1.5.1.x64 for now. Regards Last edited by raymondjpg; 22nd August 2018 at 01:37. |
22nd August 2018, 03:56 | #5578 | Link |
cosmic entity
just a quick question
i tried Nvidia DSR on my 900p monitor. So in the end i have an 1200p monitor. Anyway, in my tests, the picture looked slightly better (sharper) then without DSR. My question would be, is this an good idea? Or should i just use teh scalers built into MPC BE? like bicubic or catmull-rom? Or is this DSR stuff in terms of video playback just an bad idea ? greetz |
22nd August 2018, 09:39 | #5579 | Link | |
I also upgraded to b3788, so we are on the same page
There's an Advanced submenu under Subtitles: did you check Force sub only option? That's the only thing I can think of.
22nd August 2018, 10:37 | #5580 | Link | |
I don't have the forced sub option checked in the advanced submenu under Subtitles. I am attaching a screenshot of what I see when I select the subtitle popup menu. Even if I put an external subtitle file, properly named, in the same directory, the same internal subtitle is still selected i.e. the external subtitle is not preferred. If it doesn't happen with you, I don't know why. Probably not worth pursuing any more. EDIT: Looks like the behavior I was seeing is related to the use of an ini file. Without an ini file, the Prefer external subtitle flag is honored. If an ini file is present, then the last selected subtitle is used, and the Prefer external subtitle flag is not honored. As I use ini files to conveniently remember player settings, and sometimes transfer those settings to another pc, I will probably continue to use them. Problem solved I think. Last edited by raymondjpg; 22nd August 2018 at 12:54. Reason: Additional Info |
