10th March 2018, 05:09 | #5161 | Link |
BetA13
The screenshot is a very bad feature. We will not return it. If you need a quality maping channels, use ffdshow or AC3Filter.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
10th March 2018, 09:42 | #5163 | Link | |
It should also be remembered that AYUV support in the drivers is implemented worse than NV12, YV12 or YUY2. Perhaps this also affects.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 10th March 2018 at 12:57. |
11th March 2018, 16:28 | #5165 | Link | |
https://drive.google.com/file/d/1k5Q...ew?usp=sharing |
11th March 2018, 17:53 | #5166 | Link |
cosmic entity
with this setting i hear the front LR also in the Back LR, Center also goes to back LR. This way i can watch movies in stereo and 5.1 without disturbing my neighbours and i can hear what people talk..i hate it when voice only comes trough the center.. i know i know, those settings arent the best, but they are working for me
im connected via analog, Front LR, Center/LFE, Back LR. Its like an TEUFEL system.. edit: i just looked at your picture, wich is kinda hard when i BLOCK google The setting you showed is not working like i wanted to. so this does not work for me, only way is to re map the channels? if these are teh right words for it... im going to try ffdshow or ac3filter as external filter and see if it works.. Greetz Last edited by BetA13; 11th March 2018 at 17:57. |
11th March 2018, 18:16 | #5167 | Link | |
11th March 2018, 18:41 | #5168 | Link |
cosmic entity
add/copy the front Left, Right and center -to- Rear Left and Right...wich is what i did on that screen..
edit: tested ac3filter and ffdshow, they didnt do what i wanted so back to mpchc Last edited by BetA13; 11th March 2018 at 19:18. |
11th March 2018, 19:37 | #5169 | Link |
@BetA13
These filters do it all, and even more and better. ffdshow Audio Processor->Mixer->Custom matrix AC3Filter->Mixer->Mixing matrix
11th March 2018, 22:30 | #5170 | Link |
Update for translation of Chinese traditional/simplified and Dutch
https://www.sendspace.com/file/1402fa |
16th March 2018, 13:58 | #5172 | Link |
Same problem I had awhile back with no fix. I had to reinstall everything a while back and since then my subtitles are different. Using Mpc-BE, lav filters and madvr. The subtitles are just plain white with blackoutlines, they used to be yellow before. Currently they appear to be set to blue in the subtitle properties of mpc-be but no matter what they are just white.
Avatar used to be the fancy avatar style subtitles and now they are just this plain white boarded with black subtitle. |
18th March 2018, 00:33 | #5176 | Link |
Open file in MKVToolnixGUI. Go "Output" tab. Split: "By parts based on timestamps". Enter e.g. "00:05:30-00:06:00" to cut from 5min30s to 6min00s. Click "Start muxing" and upload file to a hoster like e.g. MediaFire, Google Drive, MEGA, etc.
18th March 2018, 00:35 | #5177 | Link |
If subtitles are "fancy Avatar style" like in Cinema they are probably in some kind of bitmap format (like a photo). If they are now in a different style you probably have a different subtitle track or (external) subtitle file selected. Changing style of bitmaps requires OCR as first step (can MPC-BE do that?).
18th March 2018, 00:40 | #5178 | Link |
On the Blu-rays, only the "forced" (alien) subtitles used the fancy font to distinguish them from normal subtitles. But its quite likely that sneaker_ger is right and you just have text subtitles now.
