Old 26th March 2007, 12:35   #221  |  Link
Sirber
retired developer
Sirber's Avatar
Do you have 5.1 samples I could test on?
[edit]
Since I convert to WAVE, not sure the encoders can handle files larger than 4GB...
Detritus Software
Sirber is offline   Reply With Quote
Old 27th March 2007, 16:46   #222  |  Link
Eretria-chan
Maybe... maybe not. Requires NTFS too, or there's a 4 GB limit. But if you want a sample I still have one.
Eretria-chan is offline   Reply With Quote
Old 28th March 2007, 02:01   #223  |  Link
Sirber
retired developer
Sirber's Avatar
a sample would be great, then I'll make the encoder match the source for 5.1, 2.0 and 1.0
Detritus Software
Old 28th March 2007, 13:46   #224  |  Link
Eretria-chan
Sure, it's only 3 mins, but the whole file is 400 MB.
http://www.eluni.net/temp/Piratesoft...ELAY%200ms.ac3
AC3, Dolby Digital, 5.1
Old 28th March 2007, 15:35   #225  |  Link
Sirber
retired developer
Sirber's Avatar
I could make a dropdown with: Auto, Mono, Stereo, 5.1
@Eretria-chan
Do you have a sample, like in mkv, with audio (5.1) and video. Bencos isn't great with audio-only sources. 10 sec would be good. Thanks!
Detritus Software
Old 28th March 2007, 16:24   #226  |  Link
Eretria-chan
Hmmm. It's in AVI. But I'll mux the audio and cut a 10 sec sample.
http://www.eluni.net/temp/Pirates%202%20Sample.avi
22 MB. 11 seconds.
Old 28th March 2007, 16:30   #227  |  Link
Sirber
retired developer
Sirber's Avatar
AVI is fine too. Thanks!
Detritus Software
Old 28th March 2007, 16:48   #228  |  Link
Eretria-chan
Sample uploaded. Go ahead, grab it.
Old 28th March 2007, 16:52   #229  |  Link
Sirber
retired developer
Sirber's Avatar
Thanks, I'll grab it when I get home.
Detritus Software
Old 28th March 2007, 21:33   #230  |  Link
Eretria-chan
Say, how about actual profiles for different sources that sets "Source" and bitrate, eventually 5.1, audio, etc?
For Anime sources, it would typically be Bitrate 318, 32 kbps sound, stereo and Source Anime / Toons.
Then there could be Movie at 500 kbps for video, 32 kbps for audio and source Movie.
And maybe DVD Rip which would set bitrate to about 1500 kbps, 32 kbps for audio and source Movie / Anime or something. 1500 should be about good for almost flawless DVD quality encodes.
Right now I'm testing to see what bitrate I could use for a typical movie source (non-DVD). Which means poor quality usually. 500 kbps seems good, going to try 400 and lower too.
1000 kbps for DVD quality is pretty good, but not entirely DVD quality, but still very close.
Old 29th March 2007, 12:20   #231  |  Link
Sirber
retired developer
Sirber's Avatar
I think I'll let the channel count a user setting, no auto. If the user set 5.1 and a 128kbps, and in the filelist I hit a stereo file, I don't think it'S right that bencos chose the new bitrate to use.
I think it's a good idea to link Source and video bitrate. Isn't anime set to 268?
Detritus Software
Old 29th March 2007, 13:25   #232  |  Link
Eretria-chan
But if 5.1 is selected, Bencos must allow higher bitrates at least.
Yes. Yes, anime was originally 268, but I found that it sometimes smoothes out the intro of some movies a little too much. 318 produces almost perfect quality encodes, so... Well, I guess it's up to each and every one.
Old 29th March 2007, 13:56   #233  |  Link
Sirber
retired developer
Sirber's Avatar
Yes, 5.1 will have higher bitrates selection
Detritus Software
Old 29th March 2007, 23:04   #234  |  Link
Eretria-chan
Btw, maybe different levels of the profiles would be a good idea? Like, high, medium or low for anime content. Only, it would control the bitrate this time.
Obviously, when encoding DVDs, you need a lot more bitrate rather than encoding non-DVD sources, so I thought that might also be a good idea. Though a movie is a movie, depending on the quality of the source, different amounts of bitrate can be used to encode it, since all that bitrate would be a waste if the source is bad quality.
Old 1st April 2007, 10:57   #235  |  Link
Weltall
Weltall's Avatar
I would like to know if its possible to add a funcfion to BENCOS that calculates the hh:mm:ss total of episodes dragged to it. I use windows media player 10 to get the total time and megui's bitrate calculator to bitrate. If BENCOS could at least give me this total time, I could install windows media player 11 (which didn't give me the time in seconds :P). I don't know if it's possible to add a calculator, but that would be great. Something like: add 12 episodes, total time 4 hours, 39 minutes and 36 seconds; desired final size (I would give this): 596.4MB (49.7MBx12). Bitrate that should be used: XXX. :'( :'( Wonderful!!!
It's very hard to implement this, like in megui? I just think that would help a lot!!!
How do you do Stéphane, use a standard bitrate for every anime?
"After all, Love remains, burned into our memories. We all search for love. But some of us, after we found it, wish we hadn't."
Weltall is offline   Reply With Quote
Old 3rd April 2007, 18:36   #236  |  Link
Sirber
retired developer
Sirber's Avatar
@Eretria-chan
The "Source" menu will already mod the bitrate, once done.
@Weltall
I could add a bitrate calculator (as in RA4/5). I think to create the thing you'd like would require more time than what's been already spent on bencos.
As for me I always use standard bitrates. I have no problem with some filesize differences.
Detritus Software
Old 5th April 2007, 10:31   #237  |  Link
Weltall
Weltall's Avatar
Originally Posted by Sirber View Post
@Eretria-chan
@Weltall
RA5 calculator didn't give me right bitrate, thanks anyway. I think I'll stick with this process I'm familiar to
I have this size problems cause I always want to use a full dvd, I thought you could just do the same thing but you had a better solution to calculate.
I think the only thing missing now is an encode list recording after closing (maybe a save list like in RA5) and drag and drop
OK then, I'm just happy with it.
Old 5th April 2007, 11:55   #238  |  Link
Sirber
retired developer
Sirber's Avatar
wouldn't be hard to save the list.
will be hard for drag drop
Detritus Software
Old 5th April 2007, 23:43   #239  |  Link
Weltall
Weltall's Avatar
If I could save a list, I shouldn't need to drag and drop so much. The pain is have to select everything again after a system pane.
Old 6th April 2007, 00:11   #240  |  Link
Sirber
retired developer
Sirber's Avatar
Get a UPS and beer
List save / load should take more than 10 lines. I'll try to make it this weekend.
Detritus Software
aac, bencos, gui, webm, x264
