Old 5th June 2009, 04:02   #1  |  Link
880
Apple's DVD Studio HD-DVDs?
Apple has a playback software, DVD Player.app, that will play HD-DVDs. But it will only play HD-DVDs created with DVD Studio Pro.
Originally Posted by Apple
Key Updates include:
-Additional support for playing DSP 4 authored HD DVD folders from DVD discs and hard drives.
So what makes DVD Studio Pro special? Limited codecs? Limited interactivity?
I.E. How can I create a HD-DVD that is compatible with Apple?
880 is offline   Reply With Quote
Old 5th June 2009, 08:30   #2  |  Link
Ghitulescu
Ghitulescu's Avatar
Maybe there is a sort of copy-protection, since you'll not have access to keys. So DSP4 will create most probably a sort of "consumer" HD-DVD.
How to create a DVD that will play in a Boing JumboJet?
Old 5th June 2009, 09:16   #3  |  Link
setarip_old
setarip_old's Avatar
@880
Hi!
According to Wikipedia DVD Studio Pro (now incorporated in Final Cut Pro):
Final Cut Pro supports nearly all High Definition formats (HDV, DVCPRO HD, AVCHD, and uncompressed HD)
setarip_old is offline   Reply With Quote
apple, hd-dvd, mac
