Old 26th March 2024, 17:20   #441  |  Link
wswartzendruber
hlg-tools Maintainer
wswartzendruber's Avatar
I was thinking about something several days ago and had a realization. With SDR, indoor and outdoor scenes tend to have small variance in where reference white would be. But with HDR, there is a lot more variance between these scenes. With the BBC putting reference white at 75% HLG, and then by viewing this on a SDR display, we effectively have these dimmer indoor scenes "pushed up" towards 75% and the brighter outdoor scenes "pushed down" towards the same level. This seems to go a long way in making HLG look "like it should" despite the greater variance in HDR's levels of indoor vs. outdoor scenes.
As best I can tell, the 75% HLG level for reference white was a BBC innovation, as NHK's original specification called for 50%. Another way to put this is that the NHK seems to have viewed HLG as a hack to have basic monitoring work on existing 10-bit equipment while the BBC wanted HLG to "just work" on existing 10-bit consumer devices.
wswartzendruber is offline   Reply With Quote
Old 3rd April 2024, 20:37   #442  |  Link
wswartzendruber
I've got Planet Earth II showing up on 4K Blu-ray today.
For those who don't know, this is what was used to show the world HLG for the first time in 2017 using the BBC's iPlayer app.
As I understand it, the content was natively graded in HLG and then for this disc, converted directly to PQ. So hopefully, reference white is parked neatly at 203 nits and MaxCLL is right at 1,000 nits.
Old 3rd April 2024, 21:51   #443  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
uuuuuh David Attenborough, a national legend!
I love the BBC documentaries in HLG, they're always perfect and his voice is so calm.
Yep, the only things I still don't like about the BBC iPlayer are:
A) No 5.1 support
B) No HLG support on the web version
The first one is a bit sad 'cause lots of programs are actually made in 5.1 and yet they're just sent out as stereo (as a long-time subwoofer owner, I care about this).
The second is really sad 'cause you can see the glorious UHD HLG contents if and only if you're using the BBC iPlayer App AND your Smart TV is supported. On one side, I understand that this means that they rigorously test each and every device the app works on (and I'm not joking here, when I met Andrew, one of the guys from the BBC, he said that they absolutely positively test them all to make sure they perform correctly), but on the other side it's a bit sad 'cause it means that whenever it comes to generic things they can't test like the web version they limit the features to the very bare minimum set of what they know is gonna work...
Old 2nd May 2024, 11:16   #444  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by Kailebsford View Post
Currently, I'm employing brute force to minutely decrease C until the conversion to RGB falls within the 0.0-1.0 range. Using this approach, I've produced an experimental BT.2020-to-BT.709 LUT, which I've forwarded to FranceBB for assessment.
No, you did no, you useless AI powered bot.
William did, William created it.
Man, I'm starting to miss the old spammers that used to register, post a link and get banned. With AI it's now harder to spot those stuff...
Anyway, I've reported the account, it will be banned soon.
Old 2nd May 2024, 21:22   #445  |  Link
wswartzendruber
If I respond to the bot, does that count as talking to myself like a crazy person? ��
Old 21st May 2024, 04:52   #446  |  Link
wswartzendruber
Here's a comparison between the OKLCH LUT and VLC on Windows:
