Old 1st February 2024, 08:27   #1541  |  Link
ReinerSchweinlin
Does OPENCL work on your system? In most cases, it is installed together with the GPU driver.
DOwnload GPU-Z to see if OPEN CL is installed
Take something like mandelbuler or an older geekbench version to see if OPEN CL actually works.
Which GPU are you using ?
Old 1st February 2024, 09:05   #1542  |  Link
kedautinh12
Originally Posted by Katie Boundary View Post
It's not that. I already have the MSVC++ 2005, 2010, 2012, 2013, and 2015-2022 runtimes in both 32 and 64-bit.
You need check in avsmeter
Old 1st February 2024, 16:58   #1543  |  Link
Katie Boundary
Katie Boundary's Avatar
Some Intel integrated BS
EDIT: Intel HD 3000, which is the same as my desktop. But KNLmeansCL works on the desktop.
GPU-Z reports that it is not installed... weird.
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 1st February 2024, 19:42   #1544  |  Link
https://registry.khronos.org/OpenCL/...docs/man/html/
OpenCL Runtime
    Runtime API's
        Buffer Objects
            clEnqueueFillBuffer
clEnqueueFillBuffer is missing before version 1.2.
Maybe update Graphics driver, if available.
EDIT: Related, be careful:- https://forum.videohelp.com/threads/...c-on-windows-7
EDIT: Google Search:- https://www.google.co.uk/search?q=cl...2opencl.dll%22
Old 1st February 2024, 20:19   #1545  |  Link
Katie Boundary
Okay, I figured out what's going on. Sandy Bridges just don't support OpenCL. My desktop can run KNLmeansCL mecause it has a discrete graphics card, and my previous laptop could do it because it had a Broadwell or Haswell chip.
Old 5th February 2024, 07:34   #1546  |  Link
tormento
Acid fr0g
tormento's Avatar
That's a pity that the development of this plugin stopped.
@turment on Telegram
Old 5th February 2024, 15:05   #1547  |  Link
Selur
Selur's Avatar
I totall agree.
Old 6th February 2024, 23:55   #1548  |  Link
ChaosKing
Btw there is a faster drop in replacement for KNLMeansCL but written for cuda, only for vapoursynth https://github.com/AmusementClub/vs-nlm-cuda
Old 7th February 2024, 17:24   #1549  |  Link
tormento
Acid fr0g
tormento's Avatar
DGDenoise from DGToolsNV is actually a NLMeans denoiser.
Old 11th February 2024, 09:50   #1550  |  Link
tebasuna51
tebasuna51's Avatar
Posts after that moved to new thread CUDASynth filters (DGdecode, DGdenoise, DGHDRtoSDR)
Old 12th February 2024, 16:52   #1551  |  Link
ReinerSchweinlin
"Invalid Thread specified....."
Old 13th February 2024, 14:35   #1552  |  Link
ReinerSchweinlin
thank you
Old 18th July 2024, 10:22   #1553  |  Link
tormento
Acid fr0g
tormento's Avatar
@pinterf
Have a look here.
Thank you.
Old 20th July 2024, 09:01   #1554  |  Link
anton_foy
Any possibility to rewrite this for Avs+?
anton_foy is offline   Reply With Quote
Old 20th July 2024, 22:21   #1555  |  Link
ChaosKing
You have to ask the author of the plugin :-)
Old 21st July 2024, 01:31   #1556  |  Link
kedautinh12
WolframRhodium said "no more avisynth ported"
Old 22nd July 2024, 01:34   #1557  |  Link
anton_foy
Too bad, it is really fast and has so much better temporal stability compared to knlmeansCL.
Old 22nd July 2024, 09:18   #1558  |  Link
tormento
Acid fr0g
tormento's Avatar
You tried newer DGDenoise?
Old 22nd July 2024, 09:40   #1559  |  Link
anton_foy
Yes and I get smearing/ghosting-like artifacts from the temporal setting even on low values.
Old 22nd July 2024, 10:08   #1560  |  Link
tormento
Acid fr0g
tormento's Avatar
Tried to disable chroma? Anyway report the issue to the writer of the plugin.
