Old 9th August 2021, 22:12   #8301  |  Link
benwaggoner
Originally Posted by quietvoid View Post
If you're interested in ARM, there is ongoing work for an arm64 port.
You can find all the patches: https://mailman.videolan.org/piperma...st/013370.html
The full patch is also at the end of that message.
Not sure anyone has compiled them into a build yet..
My fellow Amazonian Sebastian Pop has been doing a whole lot to get ARM performance up! I'll ask him if he has any aggregate numbers for those improvements.
Ben Waggoner
My Compression Book
Old 12th August 2021, 17:12   #8302  |  Link
Barough
Barough's Avatar
x265 v3.5+12-0983cffc5 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.3.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/master
Old 14th August 2021, 09:41   #8303  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
With all those versions out there and all that talk about things being broken or gotten worse in never versions, I'm really struggling what version I should go for with archival purposes in mind.
With DJ ATOM's 3.5+20 version (I still don't understand where the +20 comes from anyway) I've noticed very rare and random encoding errors on Ryzen 5950x. Those errors show as a single, (sometimes 2-3 consecutive) frame(s) being almost completely grey.
Worst part is those frames are not really broken and perfectly decodeable which makes them very hard to spot. Usually I let ffmpeg just run through an encoded video stream to spot any decoding errors.
Here I have to watch the entire video closely to check if the encode is flawless or not. Needless to say that's quite a tedious task.
LeXXuz is offline   Reply With Quote
Old 14th August 2021, 11:27   #8304  |  Link
DJATOM
DJATOM's Avatar
That +20 is refers to my patches.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 14th August 2021, 12:43   #8305  |  Link
filler56789
SuperVirus
filler56789's Avatar
My suggestion: get version 3.3+10 from http://msystem.waw.pl/x265/ ,
OR perhaps versions 3.3+1 /+4 /+7 /+12 /+24 /+27 from the x265.exe thread at Videohelp:
https://forum.videohelp.com/threads/...E-mingw-builds
filler56789 is offline   Reply With Quote
Old 15th August 2021, 11:27   #8306  |  Link
LeXXuz
LeXXuz's Avatar
Ah. Thanks for the explanation.
I'll try my luck with that one.
Old 16th August 2021, 23:50   #8307  |  Link
benwaggoner
Is there something specific to your GPU about those errors?
Ben Waggoner
My Compression Book
Old 17th August 2021, 00:07   #8308  |  Link
rwill
Have you tried decoding the stream with a software decoder like the one in ffmpeg ( maybe ffplay ) or the reference software decoder ( ldecode, HM ) to check if its not some decoder side problem ?
Old 17th August 2021, 00:41   #8309  |  Link
DJATOM
DJATOM's Avatar
On my observation rtx 2070's decoder has rare glitches with bframes > 6. Maybe it's also option specific issue...
Me on GitHub
Old 17th August 2021, 18:25   #8310  |  Link
benwaggoner
I've played a whole lot of --bframes 8 content on a Quadro 6000 (basically a 2080 with extra VRAM) without any issues.
Ben Waggoner
My Compression Book
Old 17th August 2021, 23:32   #8311  |  Link
LeXXuz
LeXXuz's Avatar
Hm. Fair point. I forgot to check if this may be decoder related. I already deleted those faulty encodes and encoded those files again with a different version. They look okay now.
If I have time I will try to reproduce that error and check if it's decoder related.
Old 18th August 2021, 09:13   #8312  |  Link
rwill
It could be a muxer problem too, for example if keyframes are marked as inter and non-keyframes are marked as random access points...
Sometimes I get strange decode errors with VLC too but when I seek to a position prior to the garbage frames and try to reproduce the problems the frames come out ok, sometimes.
Old 18th August 2021, 09:19   #8313  |  Link
LigH
LigH's Avatar
Modern decoders should know to seek to IDR frames only, one would assume...
New German Gleitz board
Old 18th August 2021, 16:01   #8314  |  Link
rwill
Well decoders can discard bitstream data until they encounter an IDR but this prevents the case where there are no IDR/CRA/BLA pictures and Intra Refresh is done with constrained Intra encoding like for live communication applications.
The player is relying, in most cases, on what is signaled in the container which contains the bitstream and starts feeding from a point which is marked as a keyframe there.
Old 19th August 2021, 09:21   #8315  |  Link
LigH
LigH's Avatar
Thanks for this alternative point of view, @rwill ... video encoding can be more complex than expected when you find a use case where usually optimal techniques don't work perfectly.
Old 25th August 2021, 15:24   #8316  |  Link
charliebaby
charliebaby's Avatar
x265 Update
x265 3.5.0.13 GCC 11.20
LINK : https://www.mediafire.com/file/bzeag...2-AVX2.7z/file
charliebaby is offline   Reply With Quote
Old 2nd September 2021, 11:10   #8317  |  Link
tormento
Acid fr0g
tormento's Avatar
Is AVX2 mandatory? A Sandy Bridge compile would be nice
@turment on Telegram
Old 16th September 2021, 16:58   #8318  |  Link
Barough
Barough's Avatar
x265 v3.5+15-4bf31dc15 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.3.0)
Old 18th September 2021, 11:09   #8319  |  Link
LeXXuz
LeXXuz's Avatar
How much is fixed in 3.5+15 and how much is broken this time?
Old 18th September 2021, 19:43   #8320  |  Link
DJATOM
DJATOM's Avatar
Latest commits almost did nothing for x86 builds, so not much differs from 3.5 release...
Me on GitHub
