Old 14th June 2007, 16:58   #381  |  Link
lucassp
It works ok with the new DLL!
lucassp is offline
Old 14th June 2007, 18:50   #382  |  Link
canTsTop
canTsTop's Avatar
I have updated the alpha 6 package with a new build of libavcodec.dll. I simply took ffdshow_tryouts and built the beta 2 branch in release mode.
Please advise if you still have problems with this DLL.
To those people who are using the DLL from ffdshow: Do you mean the real ffdshow or ffdshow_tryouts? If the former please give me a link to the project.
still not working for me
i using ffdshow from here http://sourceforge.net/project/showf...roup_id=173941
(Nightly builds by clsid, generic builds)
canTsTop is offline
Old 15th June 2007, 09:48   #383  |  Link
G_M_C
Still havent been able to test, i'll make it a priority for tonight
But could you provide us with an example 264-stream canTsTop, cause maybe it is something else ?
G_M_C is offline
Old 15th June 2007, 13:53   #384  |  Link
He said it crashes with the test files included in the early alphas.
Guest is offline
Old 15th June 2007, 16:12   #385  |  Link
G_M_C
Welll, i'm sorry to say that i get exactly the same error ("Couldn't load ....."). Even tried to register the DLL, wich didnt work.
Looked in my event logs, and there were errors in it (3 per time i tried to start DGAVCIndex). I wont put them here, because i do not think you be any wiser (i run a Dutch version of Win XP pro the errors etc. are all in Dutch and i dont know if you understand Dutch). Maybe CanTsTop has an English version ?
G_M_C is offline
Old 15th June 2007, 17:18   #386  |  Link
@G_M_C
Does this popup come right away when opening DGAVCIndex?
Just for grins, please extract alpha 6 into a folder "c:\dg". and try running it from there. I'm wondering if there is a path problem.
If that doesn't work I will provide you with a debug DGAVCIndex so we can get to the bottom of this.
Can't you translate the error log events for me?
Guest is offline
Old 15th June 2007, 17:58   #387  |  Link
canTsTop
canTsTop's Avatar
not working in "c:\dg"
FreeCommander - Contents of folder:  C:\dg 2007.06.15 19:57
Date      Time   Attrib       Bytes         File name
C:\dg
2007.06.01 21:13:40 A-----            143.360  DGAVCDecode.dll
2007.06.01 21:12:40 A-----            499.712  DGAVCIndex.exe
2007.06.14 08:22:34 A-----          1.585.152  libavcodec.dll
2007.06.01 21:19:34 A-----              1.165  Readme.txt
2007.02.17 20:46:32 A-----         12.168.444  test.264
                                   14.397.833  5 Files
Summary of C:\dg
  Directories =                  1
  Files       =                  5
  Bytes       =         14.397.833
canTsTop is offline
Old 15th June 2007, 19:02   #388  |  Link
crapz0rs
Works fine here on a skyhd h264 cap
crapz0rs is offline
Old 15th June 2007, 19:27   #389  |  Link
Originally Posted by canTsTop View Post
not working
That's no help to me. What exactly goes wrong and when?
Guest is offline
Old 15th June 2007, 19:48   #390  |  Link
canTsTop
canTsTop's Avatar
DGAVCIndex crashes when i open video
canTsTop is offline
Old 15th June 2007, 19:51   #391  |  Link
G_M_C
Hi Neuro2,
It gives the "couldn't load ...."-error right upon startup. Looks like the app is calling the DLL, and Windows cant load it. Ill'do a search on google and see if i can find the translation of the event-log errors.
To be complete, before you get into it; I use a rather old version of Win XP Pro, SP1. I never bothered keeping that system up-to-date, because i just use it mainly in "stand-allone-mode". So there's no dot-net and other "fancy" stuff on it etc.
I just pump a huge amount of data in from my main PC through the managed switch. After that i disconnect the patch cable, boot up that system in "stand-allone-mode" with bare minimum on drivers w/o virus-scanner & firewall to do its encode-work and burn the DVD. So i dont have any need for most of the SP2 patchwork, just makes things even slower (and video-stuff isn't fast to begin with )
G_M_C is offline
Old 15th June 2007, 20:27   #392  |  Link
Do you have the Studio 2005 runtime installed as linked above?
http://forum.doom9.org/showthread.ph...59#post1013559
Guest is offline
Old 15th June 2007, 20:47   #393  |  Link
G_M_C
I should have, but i'll make shure and (re)install the packages you linked to, and try again.
Might be tomorrow (GMT+1) that i'm able to report back, cause i've got friends over atm. But i'll keep you posted as best i can !
G_M_C is offline
Old 16th June 2007, 22:09   #394  |  Link
klinika
Could someone check the new & old alpha 6 with files with cqm's? I wanna verify it's not my system, they seem to get borked here. Alpha 5 works without a hitch.
klinika is offline
Old 17th June 2007, 01:24   #395  |  Link
Warren
Neuron: based on all the problems with the redist not being present why not add a check into the main program to check for the dlls and pop up a box with the url to the redist if they're not found?
Warren is offline
Old 18th June 2007, 13:32   #396  |  Link
bob0r
Pain and suffering
bob0r's Avatar
@neuron2
H.264 MBAFF decoding is partly supported (as in just the bits pengvado likes a bit... )
Here I have a sample:
http://x264.nl/ateme.luxe.tv.hd.eute...e.ts.sample.ts
Which is MBAFF + Spatial Direct Mode..... This is a sample of Ateme, which with any luck, will be on more satellite channels soon.
Might you add support for full MBAFF decoding too?
bob0r is offline
Old 18th June 2007, 15:25   #397  |  Link
Inventive Software
Turkey Machine
@neuron: Lots of queries since you replied, but this is a rather key one... which part of the program uses VC2005 redists? As in, is it in the program .exe, or in the DLLs it uses?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 18th June 2007, 16:00   #398  |  Link
DGAVCIndex.exe requires it.
libavcodec.dll requires it when built via ffdshow_tryouts code. When built with MSYS/MINGW then not.
DGAVCDecode.dll I can't remember and I'm at work so can't check.
Guest is offline
Old 19th June 2007, 10:51   #399  |  Link
Inventive Software
Turkey Machine
Woah, hang on... ffdshow-tryouts IIRC recommend that you build libavcodec.dll and libmplayer.dll with MinGW anyway.... odd that it should require it when built with VS2005.
Old 19th June 2007, 13:29   #400  |  Link
I never heard that. What is your source?
Guest is offline
