Old 6th April 2010, 23:36   #1  |  Link
Leinad4Mind
Please, DeInterlace me!
Leinad4Mind's Avatar
LSharpAAF - AntiAliasing Combo
Another AntiAliasing Script. It's more a combo... a combination of all antialiasing I know.
And it has some Extras like FastLineDarkenMOD, Presharpening, Postsharpening and Postsmoothing.
It's very alike SharpAAMCmod...
It contains: Sangnom, EEDI2, maa, daa, ediaa, aaa, ssa, splinaa, supaa, naa, shaarp, aaf, nnedi, nnedi2 and antialiasing
Okay... I will post it... Here is the Code:
# LSharpAAF() by Leinad4Mind
# v1.50 updated in 2011-12-06
# Requirements: awarpsharp2; EEDI2.dll; FastLineDarkenMOD.avsi; LSFmod.v1.9.avsi; MaskTools.dll; mt_masktools-26.dll; mvtools.dll;
# nnedi2.dll; RemoveGrain*.dll; Repair*.dll; SangNom.dll; UnFilter.dll
# * HD; HDS; S; SSE2; SSE3; T; TSSE2; TSSE3
# All AA Scripts are in this script, so there are no need to download them separately; Except some of them that you can find in AnimeIVTC, as maa, daa.
# This is an Anti-Aliasing Combo with some Extras like FastLineDarkenMOD, Presharpening, Postsharpening and Postsmoothing
# Thanks to @ Didée, thetoof, Mystery Keeper, Soulhunter, MisterHatt, martino, mf, Akirasuto, SpikeSpiegel, ScharfisBrain, LaTo & Sagekilla
# Example: LSharpAAF(StrDrk=18, ShPre=100, ShPost=280, SmPost=80, aatype="ediaa")
# OR: LSharpAAF(18,100,280,80,"ediaa")
FUNCTION LSharpAAF(clip a, int "StrDrk", int "ShPre", int "ShPost", int "SmPost", bool "stabilize", int "tradius", bool "MT", int "aapel", int "aaov", int "aablk", string "aatype"){
StrDrk = default(StrDrk,38) #FastLineDarkenMOD
ShPre = default(ShPre,18) #Presharpening
ShPost = default(ShPost,300) #Postsharpening
SmPost = default(SmPost,100) #Postsmoothing
stabilize= default(stabilize,false ) # Use post stabilization with Motion Compensation
tradius	= default(tradius,2) # 2 = MDegrain2 / 3 = MDegrain3
MT=default(MT,false) # Use josey_wells' branch of MVTools
aapel	= default(aapel,1) # accuracy of the motion estimation
# \ (Value can only be 1, 2 or 4. 1 means a precision to the pixel. 2 means a precision to half a pixel, 4 means a precision to quarter a pixel, produced by spatial interpolation (better but slower).)
aaov	= default ( aaov,(a.width>1100) ? 8 : 4 ) # block overlap value (horizontal). Must be even and less than block size. (Higher = more precise & slower)
aablk	= default ( aablk,(a.width>1100) ? 16 : 8 ) # Size of a block (horizontal). It's either 4, 8 or 16 ( default is 8 ). Larger blocks are less sensitive to noise, are faster, but also less accurate.
aatype = default(aatype,"EEDI2") # Use EEDI2() ; EEDI3() ; Sangnom() ; maa() ; daa() ; ediaa() ; aaa() ; saa() ; splinaa() ; supaa() ; naa() ; shaarp() ; aaf() ; laa() ; nnedi() ; nnedi2() ; nnedi3() ; antialiasing() ; nediaa() ; naa3mod(); for anti-aliasing.
a=a.AssumeTFF()
w=width(a)
h=height(a)
m=mt_logic(a.DEdgeMask(0,255,0,255,"5 10 5 0 0 0 -5 -10 -5", divisor=4,Y=3,U=3,V=3)
 \         ,a.DEdgeMask(0,255,0,255,"5 0 -5 10 0 -10 5 0 -5", divisor=4,Y=3,U=3,V=3)
 \       ,"max").mt_lut("x 128 / 0.86 ^ 255 *")
preaa=(ShPre==0 && StrDrk==0) ? a : (ShPre==0) ? a.fastlinedarkenmod(thinning=0, strength=StrDrk) : (StrDrk==0) ? a.lsfmod(defaults="slow",preblur="ON",strength=ShPre)
\ : a.fastlinedarkenmod(thinning=0, strength=StrDrk).lsfmod(defaults="slow",preblur="ON",strength=ShPre)
aa=(aatype=="EEDI2") ? preaa.TurnLeft().EEDI2().TurnRight().EEDI2().spline36resize(w,h,0.5,-0.5,2*w+.001,2*h+.001)
\ : (aatype=="EEDI3") ? preaa.TurnLeft().EEDI3().TurnRight().EEDI3().spline36resize(w,h)
\ : (aatype=="Sangnom") ? preaa.spline64resize(w*2,h*2).TurnLeft().SangNom(aa=255).TurnRight().SangNom(aa=255).spline36resize(w,h)
\ : (aatype=="maa") ? preaa.maa() : (aatype=="daa") ? preaa.daa() : (aatype=="ediaa") ? preaa.ediaa() : (aatype=="aaa") ? preaa.aaa()
\ : (aatype=="saa") ? preaa.SAA() : (aatype=="splinaa") ? preaa.splinaa() : (aatype=="supaa") ? preaa.supaa() : (aatype=="naa") ? preaa.naa()
\ : (aatype=="shaarp") ? preaa.shaarp() : (aatype=="aaf") ? preaa.aaf(aam=-0.7,rep=true) : (aatype=="laa") ? preaa.laa(96, 10, true, 2.0)
\ : (aatype=="nnedi") ? preaa.NNEDI(dh=true,field=1).TurnRight().NNEDI(dh=true,field=1).TurnLeft().Spline36Resize(w,h)
\ : (aatype=="nnedi2") ? preaa.NNEDI2(dh=true,field=1,nsize=2,qual=2).TurnRight().NNEDI2(dh=true,field=1,nsize=2,qual=2).TurnLeft().Spline36Resize(w,h,0.5,-0.5,2*w+.001,2*h+.001)
\ : (aatype=="nnedi3") ? preaa.NNEDI3(dh=true,field=1,nsize=2,qual=2).TurnRight().NNEDI3(dh=true,field=1,nsize=2,qual=2).TurnLeft().Spline36Resize(w, h)
\ : (aatype=="antialiasing") ? preaa.antialiasing()
\ : blankclip(pixel_type="YV12").subtitle("Please use Sangnom, EEDI2, EEDI3, maa, daa, ediaa, aaa, ssa, splinaa, supaa, naa, shaarp, aaf, laa,
 nnedi, nnedi2, nnedi3, or antialiasing for aatype")
postsh=(ShPost==0 && SmPost==0) ? aa : aa.LimitedSharpenFaster(edgemode=1,strength=ShPost,overshoot=1,soft=SmPost)
merged=mt_merge(a,postsh,m,Y=3,U=3,V=3)
sD=mt_makediff(a,merged)
asuper= a.MSuper(pel=aapel)
sDsuper  = sD.MSuper(pel=aapel, levels=1)
fv1 = tradius>=1 ? asuper.MAnalyse(isb=false,delta=1,overlap=aaov,blksize=aablk) : nop()
bv1 = tradius>=1 ? asuper.MAnalyse(isb=true, delta=1,overlap=aaov,blksize=aablk) : nop()
fv2 = tradius>=2 ? asuper.MAnalyse(isb=false,delta=2,overlap=aaov,blksize=aablk) : nop()
bv2 = tradius>=2 ? asuper.MAnalyse(isb=true, delta=2,overlap=aaov,blksize=aablk) : nop()
fv3 = tradius==3 ? asuper.MAnalyse(isb=false,delta=3,overlap=aaov,blksize=aablk) : nop()
bv3 = tradius==3 ? asuper.MAnalyse(isb=true, delta=3,overlap=aaov,blksize=aablk) : nop()
_thSAD = 600
_idx = 13
mbv1 = a.MVAnalyse(isb=true, delta=1,idx=_idx)
mbv2 = a.MVAnalyse(isb=true, delta=2,idx=_idx)
mfv2 = a.MVAnalyse(isb=false,delta=2,idx=_idx)
mfv1 = a.MVAnalyse(isb=false,delta=1,idx=_idx)
allv = (MT==false) ? a : a.MVAnalyseMulti(refframes=tradius,idx=_idx)
sDD = (MT) ? sD.MVDegrainMulti(allv,idx=14) : sD.MVDegrain2(mbv1,mfv1,mbv2,mfv2,idx=14)
sDD2 = tradius==1 ? sDD.MDegrain1(sDsuper,bv1,fv1,thSAD=_thSAD) : tradius==2 ? sDD.MDegrain2(sDsuper,bv1,fv1,bv2,fv2,thSAD=_thSAD)
\ : sDD.MDegrain3(sDsuper,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=_thSAD)
reduc = 0.4
sDD2 = mt_lutxy(sD,sDD2,"x 128 - abs y 128 - abs < x y ?").mergeluma(sDD2,1.0-reduc)
return stabilize ? a.mt_makediff(sDD2,U=2,V=2) : merged
#Simple Anti-aliasing by Soulhunter
FUNCTION saa(Clip Clp,Int"SS",Bool"CP") {
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
CP = Default(CP,True)
Clp = Clp.IsYV12() ? Clp : Clp.ConvertToYV12()
Clp.PointResize(OX*SS,OY*SS).SangNom().TurnRight()
\ .SangNom().TurnLeft().BilinearResize(OX,OY)
CP ? Last : MergeChroma(Clp)
Return(Last) }
#Normal Anti-aliasing by Didée
FUNCTION antialiasing(clip orig,int "th_luma",int "th_croma",string "type",int "aath") {
# "th_luma" & "th_croma" are the edge detection thres.: lower values=more edges filtered
# "type" is the matrix used for edge detection: with "sobel" (default) only the
# hi-contrast edges, where artefacts are more noticeable, are filtered. If you want
# to test other matrices, read the MaskTools Guide for more info.
# "aath" = anti-aliasing strenght (default should be fine)
th_luma = Default(th_luma, 20)
th_croma = Default(th_croma, 20)
type = Default(type, "sobel")
aath = Default(aath, 48)
ox = orig.width
oy = orig.height
dx = orig.width * 2
dy = orig.height * 2
clp = orig.IsYV12() ? orig : orig.ConvertToYV12()
a=clp
b=clp.Lanczos4Resize(dx,dy).TurnLeft().SangNom(aa=aath).TurnRight().SangNom(aa=aath) \
.LanczosResize(ox,oy)
c=clp.EdgeMask(th_luma,th_luma,th_croma,th_croma,type)
MaskedMerge(a,b,c) }
# Written by MisterHatt, based off of Soulhunter's SAA() and martino's excellent MAA(), and is slightly
# faster at times for some reason or another. These functions work by generally supersampling, usually with
# nnedi2, and then running a deinterlacer (sangnom and nnedi2 respectively) to get rid of most jaggies.
# I have no idea how destructive these are on whatever random thing people care to throw them at.
# For large supersamples, avs2yuv bitches for no real reason and requires assumeframebased() in your script.
# Requires nnedi2, sangnom, o9k hours of your life.
FUNCTION splinaa(Clip Clp,Int"SS",Bool"CP") {
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
\  .SangNom().TurnLeft().Spline36Resize(OX,OY)
Return(Last) }
FUNCTION supaa(Clip Clp,Int"SS",Bool"CP") {
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
Clp.nnedi2_rpow2(rfactor=SS,cshift="spline36resize",qual=3).SangNom().TurnRight()
Return(Last) }
FUNCTION naa(Clip Clp,Int"SS",Bool"CP") {
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
Clp.nnedi3_rpow2(rfactor=SS,cshift="spline36resize",qual=2).nnedi3(nns=2).TurnRight().nnedi3(nns=2).TurnLeft().Spline36Resize(OX,OY)
Return(Last) }
FUNCTION shaarp(clip input, int "mask", int "type") {
mask = Default(mask,1)
type = Default(type,1)
Assert(mask == 1 || mask == 2, "Please use mask = 1 or 2")
Assert(type == 1 || type == 2, "Please use type = 1 or 2")
aa_clip = (type == 1) ? input.spline36Resize(width(input)*2,height(input)*2) : input.nnedi2_rpow2(rfactor=2,qual=3)
aa_clip = aa_clip.TurnLeft().nnedi2().TurnRight().nnedi2().spline36Resize(width(input),height(input)).MergeChroma(input)
mask = (mask==1) ? input.mt_edge("sobel",7,7,5,5).mt_inflate() : input.mt_edge("roberts",0,4,0,4).mt_inflate()
return mt_merge(input,aa_clip,mask) }
function aaf(clip input, float "aam", int "aay", "aax", bool "rep")
input =	input.isYV12() ? input : input.converttoyv12()
aam	= default(aam, -0.6)
aar	= aam<0 ? (aam-1)*0.25 : (aam+1)*0.25
aay	= default(aay, 28)
aax	= default(aax, aay)
rep	= default(rep, true)
sx	= width(input)
sy	= height(input)
aa	= aar<0 ? input.LanczosResize(sx,int(sy*abs(aar))*4) :
	\	aar==0.5 ? input.Pointresize(sx*2, sy*2) :
	\	input.LanczosResize(int(sx*abs(aar)*4),int(sy*abs(aar))*4)
aa	= aay>0 ? aa.SangNom(aa=aax) : input
aa	= aar<0 && aax>0 ? aa.LanczosResize(int(sx*abs(aar))*4,sy) : aa
aa	= aax>0 ? aa.turnright().SangNom(aa=aax).Turnleft() : aa
aa	= aa.LanczosResize(sx,sy)
return rep==true ? aa.repair(input,18) : aa
### LaTo Antialiasing Script v2
### Need: asharp.dll & sangnom.dll
function LAA(clip input, int "strength", int "threshold", bool "sharp", float "ss") {
strength = default(strength, 96)
threshold = default(threshold, 10)
sharp = default(sharp, true)
ss = default(ss, 2.0)
aastr = int(strength) /2
asthr = float(strength) /100
ox = input.width
oy = input.height
ox2 = round(ox*ss/8)*8
oy2 = round(oy*ss/8)*8
process = input.spline36resize(ox2,oy2).turnleft().sangnom(aastr).turnright().sangnom(aastr)
process = ( sharp == true ) ? process.asharp(asthr,0,0).spline36resize(ox,oy) : process.spline36resize(ox,oy)
mask = mt_average(input,process,u=1,v=1).mt_edge(thy1=threshold,thy2=threshold,u=1,v=1)
output = mt_merge(input,process,mask,u=2,v=2)
return ( output )
function NediAA(clip c)
{   c.nnedi3(field=-2)
    merge(selecteven(),selectodd())  }
FUNCTION naa3mod(Clip Clp,Bool "CP")
OX = Clp.Width()
OY = Clp.Height()
Clpnn1 = Clp.nnedi3(1, dh=true,nsize=2,qual=2,U=CP,V=CP).nnedi3(0,nsize=2,qual=2,U=CP,V=CP)
Clpy1 = Clpnn1.Spline36Resize(OX,OY,0,-0.5,OX,OY*2)
Clps1 = CP ? Clpy1.MergeChroma(Clpnn1.Spline36Resize(OX,OY,0,-1,OX,OY*2)) : Clpy1.MergeChroma(Clp)
Clpnn2 = Clps1.turnright().nnedi3(1, dh=true,nsize=2,qual=2,U=CP,V=CP).nnedi3(0,nsize=2,qual=2,U=CP,V=CP)
Clpy2 = Clpnn2.Spline36Resize(OY,OX,0,-0.5,OY,OX*2)
CP ? Clpy2.MergeChroma(Clpnn2.Spline36Resize(OY,OX,0,-1,OY,OX*2)).turnleft() : Clpy2.turnleft().MergeChroma(Clp)
Return(Last)
Here is all the require dll or extra functions: http://www.megaupload.com/?d=HQ7NLMW0
If u want to test it. Or improve the code, you're welcome
Leinad4Mind is offline   Reply With Quote
Old 6th April 2010, 23:43   #2  |  Link
Frank K Abbott
So this is an all-in-one anti-aliasing solution script? And how does it compare to other anti-aliasing methods that have been out?
Frank K Abbott is offline   Reply With Quote
Old 6th April 2010, 23:49   #3  |  Link
Leinad4Mind
Well, it has 5 new methods: splinaa, supaa, naa, shaarp and aaf. And it's too an denoiser. You can apply sharpening and it has the LSFMod included to sharp and a line darkening to darken the lines as u wish.
And this AIO includes SAA by soulhunter and others antialiasing by didée that can be lost in some pages of doom9. So, this is good for everyone to not forget about the good AA we already have.
And I think it can be helpful. Because an AIO is always good. xD
Best Regards.
Old 7th April 2010, 16:25   #4  |  Link
markanini
Cool, all AA functions/filters in place.
markanini is offline   Reply With Quote
Old 8th April 2010, 03:05   #5  |  Link
osgZach
Damn, if only we could get x64 version of all the required plugins
osgZach is offline   Reply With Quote
Old 19th April 2010, 10:39   #6  |  Link
thanhtu5013
@Leinad4Mind.
I made my script and it works on VirtualDub and MeGui but unfortunately there has no effects in my video...
There has still a lot of aliasing...
Watch my screens.
- Original AVI :
http://img697.imageshack.us/img697/1...enoriginal.png
- My script :
http://img21.imageshack.us/img21/636...nretouched.png
My code:
AVISOURCE("C:\GTA IV_ENB Series 0.079 SORA  - 02 - It'S Your Call_1080p.avi")
FUNCTION LSharpAAF(clip orig, int "StrDrk", int "ShPre", int "ShPost", int "SmPost", string "aatype"){
ShPre = default(ShPre,80) #Presharpening
aatype = default(aatype,"EEDI2") # Use EEDI2() or Sangnom() or maa() or daa() or ediaa() or aaa() or saa() or splinaa() or supaa() or naa() or shaarp() or nnedi() or nnedi2() or antialiasing() for anti-aliasing.
a=orig.AssumeTFF()
w=width(a)
h=height(a)
m=logic(a.DEdgeMask(0,255,0,255,"5 10 5 0 0 0 -5 -10 -5", divisor=4,Y=3,U=3,V=3)
 \         ,"max").greyscale().levels(0,0.8,128,0,255,false)
b=a.fastlinedarkenmod(thinning=0, strength=StrDrk)
 b=(aatype=="EEDI2") ? b.TurnLeft().EEDI2().TurnRight().EEDI2().spline64resize(w,h,0.5,-0.5,2*w+.001,2*h+.001) : (aatype=="Sangnom") ? b.spline36resize(w*2,h*2).TurnLeft().SangNom(aa=255).TurnRight().SangNom(aa=255).spline36resize(w,h) : (aatype=="maa") ? b.maa() : (aatype=="daa") ? b.daa() : (aatype=="ediaa") ? b.ediaa() : (aatype=="aaa") ? b.aaa() : (aatype=="saa") ? b.SAA() : (aatype=="splinaa") ? b.splinaa() : (aatype=="supaa") ? b.supaa() : (aatype=="naa") ? b.naa() : (aatype=="shaarp") ? b.shaarp() : (aatype=="nnedi") ? b.NNEDI(dh=true,field=1).TurnRight().NNEDI(dh=true,field=1).TurnLeft().Spline36Resize(w,h) : (aatype=="nnedi2") ? b.nnedi2(dh=true,field=1) : (aatype=="antialiasing") ? b.antialiasing() : blankclip(pixel_type="YV12").subtitle("Please use Sangnom, EEDI2, maa, daa, ediaa, aaa, ssa, splinaa, supaa, naa, shaarp, nnedi, nnedi2 or antialiasing for aatype")
b=b.LSFMod(edgemode=1,strength=ShPost,overshoot=1,soft=SmPost)
mt_merge(a,b,m,Y=3,U=3,V=3)
sD=mt_makediff(a,last)
bv1 = a.MVAnalyse(isb=true, delta=1,idx=13)
bv2 = a.MVAnalyse(isb=true, delta=2,idx=13)
fv2 = a.MVAnalyse(isb=false,delta=2,idx=13)
fv1 = a.MVAnalyse(isb=false,delta=1,idx=13)
sDD = sD.MVDegrain2(bv1,fv1,bv2,fv2,idx=14)
reduc = 0.4
sDD = mt_lutxy(sD,sDD,"x 128 - abs y 128 - abs < x y ?").mergeluma(sDD,1.0-reduc)
a.mt_makediff(sDD,U=2,V=2)
return last
FUNCTION ediaa(clip a) {
return a.EEDI2(field=1).TurnRight().EEDI2(field=1).TurnLeft().spline36resize(a.width,a.height,-0.5,-0.5) }
FUNCTION daa(clip c) {
nn	= c.nnedi2(field=-2)
dbl   	= mt_average(selecteven(nn),selectodd(nn),U=3,V=3)
dblD 	= mt_makediff(c,dbl,U=3,V=3)
shrpD 	= mt_makediff(dbl,dbl.removegrain((width(c)>1100) ? 20 : 11),U=3,V=3)
DD 	= shrpD.repair(dblD,13)
return dbl.mt_adddiff(DD,U=3,V=3) }
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
Return(Last) }
FUNCTION maa(clip input, int "mask") {
mask = input.mt_edge("sobel",7,7,5,5).mt_inflate()
aa_clip=input.spline36Resize(width(input)*2,height(input)*2).TurnLeft().SangNom().TurnRight().SangNom().spline36Resize(width(input),height(input)).MergeChroma(input)
FUNCTION AAA(clip clp, int "Xres", int "Yres", int "Xshrp", int "Yshrp",
 \ 	 int "US", int "DS", bool "chroma")
         clp = clp.isYV12() ? clp : clp.ConvertToYV12()
         ox = clp.width
         oy = clp.height
         Xres  = default(Xres,  ox)
         Yres  = default(Yres,  oy)
         us  = default(us, 1)
	 ds = default(ds, 2)
         Xshrp = default(Xshrp, 15)
         Yshrp = default(Yshrp, 15)
	 chroma = default(chroma, false)
         us==0 ? clp.PointResize(ox*2,oy*2) : clp.LanczosResize(ox*2,oy*2)
         TurnLeft()
         SangNom()
         TurnRight()
         SangNom()
         ds==0 ? BilinearResize(Xres,Yres) :
 \	 ds==1 ? BicubicResize(Xres,Yres) :
 \	 LanczosResize(Xres,Yres)
         Unfilter(Xshrp,Yshrp)
         chroma ? MergeChroma(clp.Lanczosresize(Xres,Yres)) : last }
ox = orig.width
oy = orig.height
dx = orig.width * 2
a=clp
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
Return(Last) }
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
Return(Last) }
OX = Clp.Width
OY = Clp.Height
SS = Default(SS,2)
Clp.nnedi2_rpow2(rfactor=SS,cshift="spline36resize",qual=3).nnedi2(qual=3).TurnRight()
\  .nnedi2(qual=3).TurnLeft().Spline36Resize(OX,OY)
Return(Last) }
thanhtu5013 is offline   Reply With Quote
Old 19th April 2010, 11:16   #7  |  Link
Didée
Medicine doesn't help when it's just lying in the shelf. You need to ingest it.
Wrong:
1.) Have a clip
2.) Define a function
some_clip
function foo(clip c, param p) { blablabla }
This does nothing. The "function" statement does only create a function. After a function has been defined, it still has to be used.
Correct:
1.) Define a function
2.) Have a clip
3.) Use function on the clip
some_clip
foo()
Old 19th April 2010, 11:25   #8  |  Link
thanhtu5013
OK.
I understand what you say Didée.
So I have to import the script of Leinad4Mind at first.
then adding my video source (AVISOURCE("C:\...")).
But the last step I don't understand...
I have really to write "foo()" at last ?
Old 19th April 2010, 12:06   #9  |  Link
Didée
No. "Foo" is frequently used as a placeholder for "[use whatever name does fit here]".
So, instead of "foo()", you would call
either
LSharpAAF()
or
ediaa()
or
daa()
or
saa()
or
AAA()
or
antialias()
or
splinaa()
or
supaa()
or
naa()
or
shaarp()
Old 19th April 2010, 13:14   #10  |  Link
thanhtu5013
Thanks a lot Didée.
I tried all functions. Every of them works except "antialias()".
"ediaa()" & "saa()" give me the best results.
Unfortunately, I still have a bit of aliasing.
Does it possible to make antialiasing filter works stronger ?
( Maybe it could make my video blurrer but anyway I want to try and I'll take a decision later. )
Sorry if I ask stupid questions.
I'm a noobs with Avisynth.
Old 19th April 2010, 15:45   #11  |  Link
Great Dragon
Great Dragon's Avatar
thanhtu5013, why don't you try an in-game AA option? I'm sure it's more powerful that AA-scripts for Avisynth.
Leinad4Mind, is it any benefits to SharpAAMCmod?
Great Dragon is offline   Reply With Quote
Old 19th April 2010, 15:46   #12  |  Link
cretindesalpes
cretindesalpes's Avatar
You can run it multiple times. For example, in the following script you can select the strength for horizontal and vertical antialiasing. Set strh and strv between 0 and 3, over this value there is not much improvement and it generates artifacts.
# santiag v1.6
# Simple antialiasing
# This program is free software. It comes without any warranty, to
# the extent permitted by applicable law. You can redistribute it
# and/or modify it under the terms of the Do What The Fuck You Want
# To Public License, Version 2, as published by Sam Hocevar. See
# http://sam.zoy.org/wtfpl/COPYING for more details.
# type = "nnedi3", "eedi2", "eedi3" or "sangnom"
# "eedi3" requires v0.9.2 or later
# "sangnom" requires sangnom2
Function santiag (clip c, int "strh", int "strv", string "type", int "nns", int "aa", int "aac", int "threads", int "nsize", int "vcheck", int "fw", int "fh", bool "halfres", string "scaler_post", int "maskt", string "typeh", string "typev")
	strh        = Default (strh,                       1)
	strv        = Default (strv,                       1)
	type        = Default (type,                "nnedi3")
	typeh       = Default (typeh,                   type)
	typev       = Default (typev,                   type)
	halfres     = Default (halfres,                false)
	scaler_post = Default (scaler_post, "Spline36Resize")
	c
	w   = Width ()
	h   = Height ()
	fwh = (strv < 0) ? fw : w
	fhh = (strv < 0) ? fh : h
	(strh >= 0) ?             santiag_dir (strh, typeh, halfres, scaler_post, nns=nns, aa=aa, aac=aac, threads=threads, nsize=nsize, vcheck=vcheck, maskt=maskt, fw=fwh, fh=fhh)              : last
	(strv >= 0) ? TurnLeft ().santiag_dir (strv, typev, halfres, scaler_post, nns=nns, aa=aa, aac=aac, threads=threads, nsize=nsize, vcheck=vcheck, maskt=maskt, fw=fh,  fh=fw ).TurnRight () : last
	fwx = Default (fw, w)
	fhx = Default (fh, h)
	(strh < 0 && strv < 0) ? Eval (scaler_post + " (fwx, fhx)") : last
Function santiag_dir (clip c, int strength, string type, bool halfres, string scaler_post, int "nns", int "aa", int "aac", int "threads", int "nsize", int "vcheck", int "maskt", int "fw", int "fh")
	c
	w = Width ()
	h = Height ()
	fw = Default (fw, w)
	fh = Default (fh, h)
	multi = (IsYUV () && ! IsYV12 ())
	c_y = (multi             ) ?         ConvertToYV12 () : last
	c_u = (multi && ! IsY8 ()) ? UToY ().ConvertToYV12 () : last
	c_v = (multi && ! IsY8 ()) ? VToY ().ConvertToYV12 () : last
	c_y =                        c_y.santiag_stronger (strength, type, halfres, multi, nns=nns, aa=aa, aac=aac, threads=threads, nsize=nsize, vcheck=vcheck, maskt=maskt)
	c_u = (multi && ! IsY8 ()) ? c_u.santiag_stronger (strength, type, halfres, true , nns=nns, aa=aa, aac=aac, threads=threads, nsize=nsize, vcheck=vcheck, maskt=maskt) : c_u
	c_v = (multi && ! IsY8 ()) ? c_v.santiag_stronger (strength, type, halfres, true , nns=nns, aa=aa, aac=aac, threads=threads, nsize=nsize, vcheck=vcheck, maskt=maskt) : c_v
	  (multi && ! IsY8 ()) ? YToUV (c_u, c_v, c_y)
\	: IsY8 ()              ? c_y.ConvertToY8 ()
\	:                        c_y
	Eval (scaler_post + " (fw, fh, src_left=0, src_top=(halfres)?0:0.5, src_width=Width (), src_height=Height ())")
Function santiag_stronger (clip c, int strength, string type, bool halfres, bool lumaonly, int "nns", int "aa", int "aac", int "threads", int "nsize", int "vcheck", int "maskt")
	strength = (strength < 0) ? 0 : strength
	field = strength % 2
	dh = (strength <= 0 && ! halfres)
	(strength > 0) ? c.santiag_stronger (strength - 1, type, halfres, lumaonly, nns=nns, aa=aa, aac=aac, threads=threads, nsize=nsize, vcheck=vcheck, maskt=maskt) : c
	  (type == "nnedi3" ) ? santiag_nnedi3  (dh, field, lumaonly, nns=nns, threads=threads, nsize=nsize)
\	: (type == "eedi2"  ) ? santiag_eedi2   (dh, field)
\	: (type == "eedi3"  ) ? santiag_eedi3   (dh, field, lumaonly, nns=nns, threads=threads, nsize=nsize, vcheck=vcheck, maskt=maskt)
\	: (type == "sangnom") ? santiag_sangnom (dh, field, aa=aa, aac=aac)
\	: Assert (false, "Santiag: unexpected value for type.")
Function santiag_nnedi3 (clip c, bool dh, int field, bool lumaonly, int "nns", int "threads", int "nsize")
	c.nnedi3 (dh=dh, field=field, nns=nns, threads=threads, nsize=nsize, u=!lumaonly, v=!lumaonly)
Function santiag_eedi2 (clip c, bool dh, int field)
	c
	w = Width ()
	h = Height ()
	(dh) ? last : PointResize (w, h / 2, 0, 1-field, w, h)
	eedi2 (field=field)
# maskt = 24
Function santiag_eedi3 (clip c, bool dh, int field, bool lumaonly, int "nns", int "threads", int "nsize", int "vcheck", int "maskt")
	chroma = (lumaonly) ? 1 : 3
	sclip = c.santiag_nnedi3 (dh, field, lumaonly, nns=nns, threads=threads, nsize=nsize)
	mclip_flag = (Defined (maskt) && maskt > 0)
	mclip = (mclip_flag && dh) ? sclip.BicubicResize (c.Width (), c.Height (), src_top=0.5-field) : sclip
	mclip = (mclip_flag)
\	?	mclip.mt_edge (mode="1 2 1 0 0 0 -1 -2 -1 1", thY1=0, thY2=255, u=chroma, v=chroma)
\			.mt_binarize (threshold=maskt, y=3, u=chroma, v=chroma)
\			.mt_expand (y=3, u=chroma, v=chroma)
\	:	santiag_undef ()
	c.eedi3 (dh=dh, field=field, threads=threads, vcheck=vcheck, sclip=sclip, mclip=mclip, u=!lumaonly, v=!lumaonly)
Function santiag_sangnom (clip c, bool dh, int field, int "aa", int "aac")
	c
	w = Width ()
	h = Height ()
	(dh) ? Spline36Resize (w, h * 2, 0, -0.25, w, h) : last
	SangNom2 (order=field, aa=aa, aac=aac)
Function santiag_undef () { }
NNEDI3 is a CPU hog but gives excellent results. Replace it with NNEDI2 if it takes too long. Here is an example of santiag (3, 3) with the picture you linked on a previous message.
Last edited by cretindesalpes; 17th November 2015 at 10:14. Reason: Updated to v1.6 (Support for 4:4:4 colorspace)
cretindesalpes is offline   Reply With Quote
Old 19th April 2010, 15:57   #13  |  Link
2Bdecided
Very impressive.
Though the tree looks rather strange now.
Cheers,
David.
2Bdecided is offline   Reply With Quote
Old 19th April 2010, 16:02   #14  |  Link
markanini
Is it wise to believe that needi2 and eedi2 are the most effective for AA or could SangNom and unfilter serve as acomplement?
Here's an image I'm trying to improve:
http://homepages.ihug.co.nz/~online/...er/blpic-s.jpg
I want to resize x2 and AA.
With:
nnedi3_rpow2(rfactor=2,cshift="Spline36Resize",nsize=1,qual=1).nnedi3(nsize=1,qual=1).turnright().needi3(nsize=1,qual=1).turnleft()
I get:
http://img695.yfrog.com/img695/7528/blpics0422x0562.jpg
Old 19th April 2010, 16:03   #15  |  Link
thanhtu5013
Because if I activate AA when I'm capturing during my plays, the framerate fall a lot.
( Under 9-10 fps so it's not possible to make a video )
I prefer playing without and apply a one through AviSynth.
It's exactly what I need.
Congratulations ! You're my man !
Unfortunately, it doesn't work with me...
Maybe I made a mistake on my script or I don't have the required plugin.
Function santiag (clip c, int "strh", int "strv")
	c
	santiag_dir (strh)
	TurnLeft ()
	santiag_dir (strv)
	TurnRight ()
Function santiag_dir (clip c, int strength)
	c
	w = Width ()
	h = Height ()
	santiag_stronger (strength)
	Spline36Resize (w, h, 0, -0.5, w, h * 2)
Function santiag_stronger (clip c, int strength)
	c
	(strength <= 0)
\	?	NNEDI3 (dh=true, field=0)
\	:	santiag_stronger (strength - 1)
\	.	NNEDI3 (dh=false, field=(strength % 2))
ConvertToYV12
santiag()
Old 19th April 2010, 16:09   #16  |  Link
thanhtu5013
I've just watched on my AviSynth plugins folder. I have nnedi2.dll but I don't have nnedi3.dll...
Unfortuantely, I can't find it on the web.
Someone could send me it ?
Old 19th April 2010, 16:17   #17  |  Link
thanhtu5013
I've just tried with nnedi2.dll. It works nice.
I'm still seeking for nnedi3.dll
Old 19th April 2010, 16:47   #18  |  Link
cretindesalpes
NNEDI3 is here.
Old 19th April 2010, 17:31   #19  |  Link
markanini
I upped NNEDI3 qual and nszie parameters to 2 and prescrn=false and didnt get much better results:
Note the artifacts in the neck area of the guitar.
Old 19th April 2010, 18:42   #20  |  Link
thanhtu5013
I've just tried with Nnedi2... 0,74FPS.
With Nnedi3... Forget it !
Maybe in 2013, it will finish...
Anyway, I prefer personally Nnedi2 that blurring less the video than Nnedi3 and keeps mode details than Nnedi3.
Thanks to everyone.
Specially to cretindesalpes.
P.S: Your pseudo sounds french, you're french like me, right ?
antialiasing, fastlinedarken, lsf, lsharpaaf, sharpen
