Old 3rd January 2015, 14:23   #1  |  Link
Burb
Burb's Avatar
AvsPmod Avisynth loading error
Hello, I have a probleme with AvsPmod:
When runnig a simple script, FFVideoSource + Crop I get this error:
After searching a bit I noticed that I get this error only when cropping vertical lines. With "left" and "right" parameter to 0 no error.
I tried to desinstall and reinstall Avisynth and Avspmod but it didn't change anything.
Any idea ?
Thanks
Burb is offline   Reply With Quote
Old 3rd January 2015, 16:13   #2  |  Link
Groucho2004
Download and run this tool.
1. File -> Save info
2. Tools -> Plugin Info -> Save plugin info report
3. Post both logs and any error messages you might get.
Old 3rd January 2015, 19:48   #3  |  Link
Burb
Burb's Avatar
Thanks for your help.
AvisynthInfo.txt: http://pastebin.com/5zqMSsJE
AvisynthPluginInfo.txt: http://pastebin.com/cKwEhsCQ
Screenshots of errors:
http://i.imgur.com/vRGDgUA.png
http://i.imgur.com/N4u05Of.png
http://i.imgur.com/Bx0NB9r.png
http://i.imgur.com/EWdIL31.png
http://i.imgur.com/W1ivbtR.png
http://i.imgur.com/pklGraZ.png
(I reinstalled Microsoft Visual C++ 2005 (x86) but error messages still appear)
Old 3rd January 2015, 20:04   #4  |  Link
Groucho2004
Just a few hints for now:
- Install Avisynth 2.6
- Empty your plugin folder and add only the plugins/source filters you really need.
Old 3rd January 2015, 20:12   #5  |  Link
Burb
Burb's Avatar
It work !
I installed Avisynth 2.6 and it work perfectely.
Thank you very much.
avisynth, avspmod, cropping, error
