Old 19th September 2008, 14:12   #1  |  Link
Dan Miller
Batch ISO creation
I'm hoping this is the right forum for this, please move it if there is a better one...
I have a drive filled with DVD file structure folders (Main folder = Movie Title, Subfolder = VIDEO_TS). I need ISOs (playable, not necessarily for burning, in other words, layer breaks aren't necessary) for all of them.
As far as I can see, IMGBURN and/or MAGICISO could do it, but one at a time. I cry when I think of that. I have 200+ movies on this drive.
Thoughts?
Dan Miller is offline   Reply With Quote
Old 19th September 2008, 20:40   #2  |  Link
pc_speak
Old Batch Hacker
I only just now retested this on two DVD folders. YMMV.
http://www.mediafire.com/?o9jex1vlxgb
The contents of the ZIP go into the root folder of your videos. Your 'Main Folder'
-V in the batch file = Volume Identifier - max 32 characters.
So all folder names need to be, including spaces, less than 33 characters. (I have not tested this.)
Assuming a folder\file structure:
GWTW\VIDEO_TS\
3_Gorges\VIDEO_TS\
HOLIDAY_IRELAND\VIDEO_TS\
One Flew Over The Cuckoo's Nest\VIDEO_TS\
make_iso.cmd
mkisofs.doc
mkisofs.exe
mkisofs.txt
readme.1st
Double click on make_iso.cmd
pc_speak is offline   Reply With Quote
Old 20th September 2008, 01:52   #3  |  Link
Dan Miller
GWTW\VIDEO_TS\
3_Gorges\VIDEO_TS\
make_iso.cmd
mkisofs.doc
mkisofs.exe
mkisofs.txt
readme.1st
Tried it and I see a dos window come up for a few seconds and go away... Nothing happens. Is there a way to log it?
Thanks
Old 20th September 2008, 04:17   #4  |  Link
pc_speak
Old Batch Hacker
Open the batch file with notepad. Add the BOLD line to pause it.
cls
for /F "delims=" %%A in ('dir /ad/b') do "mkisofs.exe" -dvd-video -V "%%A" -o "%%~nA.iso" "%%A"
pause
Old 20th September 2008, 06:37   #5  |  Link
pc_speak
Old Batch Hacker
Hi.
Better solution. I'm making it permanent for myself.
cls
for /F "delims=" %%A in ('dir /ad/b') do "mkisofs.exe" -log-file mkiso_log.txt -dvd-video -V "%%A" -o "%%~nA.iso" "%%A"
Use both techniques. Too much knowledge can't hurt.
Old 20th September 2008, 13:50   #6  |  Link
Dan Miller
OK... I did the pause thing.
I have the files from the zip sitting in D:\Shares\Video\DVD (I'm using WHS). This is the folder just above the subfolders which are the rips themselves.
WHen I double click, it launches to c:\windows.
So, it is trying to make an ISO out of each of the subfolders under c:\windows, and since the MKISOFS.exe file isn't sitting in that directory, it is returning an unknown command message.
Thoughts?
Old 21st September 2008, 01:02   #7  |  Link
pc_speak
Old Batch Hacker
I'm not too sure what's happening. So I set up my directory structure to match yours. (XP Pro)
Let's try with absolute path names. Create tmp.cmd with these two lines of code in it and double click on it.
The 1st line of code echoes the command lines to list.txt. (Post the first line from list.txt and I can see what's trying to happen.)
The 2nd line takes out the echo to list.txt and tries to execute mkisofs.exe as per usual, using absolute paths.
for /F "delims=" %%A in ('dir D:\Shares\Video\DVD /ad/b') do echo D:\Shares\Video\DVD\mkisofs.exe -log-file "D:\Shares\Video\DVD\%%~nA.log" -dvd-video -V %%A -o "%%~dpnA.iso" "%%~fA" >> list.txt
for /F "delims=" %%A in ('dir D:\Shares\Video\DVD /ad/b') do D:\Shares\Video\DVD\mkisofs.exe -log-file "D:\Shares\Video\DVD\%%~nA.log" -dvd-video -V %%A -o "%%~dpnA.iso" "%%~fA"
This is my list.txt
D:\Shares\Video\DVD\mkisofs.exe -log-file "D:\Shares\Video\DVD\IRELAND_HOLIDAY.log" -dvd-video -V IRELAND_HOLIDAY -o "D:\Shares\Video\DVD\IRELAND_HOLIDAY.iso" "D:\Shares\Video\DVD\IRELAND_HOLIDAY"
D:\Shares\Video\DVD\mkisofs.exe -log-file "D:\Shares\Video\DVD\The_3_Gorges.log" -dvd-video -V The_3_Gorges -o "D:\Shares\Video\DVD\The_3_Gorges.iso" "D:\Shares\Video\DVD\The_3_Gorges"
Isn't this fun?
Last edited by pc_speak; 21st September 2008 at 01:46. Reason: Forgot quotation marks for long filenames with spaces
Old 21st September 2008, 02:01   #8  |  Link
RunningSkittle
Skittle
RunningSkittle's Avatar
set dir=""
set dest=""
Would be useful in this kind of script
RunningSkittle is offline   Reply With Quote
Old 21st September 2008, 02:52   #9  |  Link
RunningSkittle
Skittle
My attempt, same commands i guess
@echo off
color 0a
title makeiso
set dir="c:\test"
set dest=c:\iso
set makeiso="c:\test\mkisofs.exe"
mkdir %dest%
for /d %%a in (%dir%\*) do echo %makeiso% -log-file "%dest%\%%~na-log.txt" -dvd-video -V "%%a" -o "%dest%\%%~na.iso" "%%a" >> "%dest%\cli-log.txt"
for /d %%a in (%dir%\*) do %makeiso% -log-file "%dest%\%%~na-log.txt" -dvd-video -V "%%a" -o "%dest%\%%~na.iso" "%%a"
pause
:end
It seemed silly to rely on parsing to enumerate directory names
Old 21st September 2008, 10:02   #10  |  Link
Chetwood
Chetwood's Avatar
Well, if you guys should need Layer Breaks everntually and do come up with a solution please let me know. I've suggested ImgBurn to automatically select a layer break from the index but LUK has so far only added this
* Added: Saving a project file now writes the previously selected LB info from the 'Create Layer Break' window. This can then be used when loading the IBB via CLI so the user isn't prompted to pick a LB, thus allowing for batch builds.
which does let you build ISOs by command line but still requires you to open each folder in advance to set the layer break.
MultiMakeMKV: MakeMKV batch processing (Win)
MultiShrink
: DVD Shrink batch processing
Offizieller ‹bersetzer von DVD Shrink deutsch
Chetwood is offline   Reply With Quote
Old 21st September 2008, 16:16   #11  |  Link
Dan Miller
Can you give me an example of the cammand line syntax to do the batch build?
Old 21st September 2008, 16:55   #12  |  Link
Chetwood
Chetwood's Avatar
Haven't tried myself yet due to the lack of said function. Just check the readme.txt or the ImgBurn forums. While you're over there try to rally up enough people to support my suggestion from March 2008 which would allow for completely automated batch building once implemented.
MultiShrink
dvd backup, iso creation
[IMG] code is Off
