13th January 2022, 00:00 | #9202 | Link |
Thanks for the tip, the script in indeed loaded and called. It's unfortunately not a definitive solution, instead of just some chars I have to manually add a full line, and it doesn't completely work since it seems my script depends on some DLL (masktools ?) and even if I put my old DLL in the plugin folder it doesn't work...
Isn't there an option to retrieve the folder used by avisynth for the plugins? EDIT: in my previous PC, I just had to add the scriptname() at the end of the AVS script to call it, and the .avsi was in the Program Files (x86)\AviSynth\plugins folder EDIT2: OK I managed to edit the .avsi file to load the required DLLs after finding them and putting them in a plugin folder, now the scripts seems to be working fine. But I still wish to be able to call the script via the simple scriptname() function without "import"... the included MeGUI AVS has some dll in the subfolders, why can't I use this folder to put my AVSI file in it and load it without the import function? Is there a registry key to modify to specify the plugin folder automatically? Last edited by LeMoi; 13th January 2022 at 09:03. |
13th January 2022, 09:33 | #9203 | Link |
Banana User
@LeMoi
Install Avisynth and copy plugins there.
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
13th January 2022, 11:21 | #9204 | Link |
In order to know the requirements for an AviSynth install and the registry plugins folders maybe you can read the post Universal Avisynth Installer by Groucho2004.
14th January 2022, 09:32 | #9206 | Link | |
20th January 2022, 15:44 | #9208 | Link |
If you're still around, there's a link below for a function designed to allow MeGUI to use any resizer, not just the standard Avisynth ones, and it's been so long since I've used it myself (I rarely upscale) I forgot it includes a template for upscaling with nnedi3_rpow2.
There's sample Avisynth templates included you can load into MeGUI (File/Import Presets), or you can create your own, and you have to load the AnyResizerMeGUI script to use them (or if you have Avisynth installed put it in the Avisynth plugins folder so it auto-loads) and then you can use other resizers as you would the ones included with MeGUI. The quick instructions are, create an Avusynth template in MeGUI that by default looks something like this: <input> <deinterlace> <crop> <denoise> <resize> And replace the resize line so it looks like this, changing YourPreferredResizer to the name or your preferred resizer. <input> <deinterlace> <crop> <denoise> Eval("YourPreferredResizer("+AnyResizerMeGUI(Last,"<resize>")+",Kernel="+"""ResizerMeGUI("<resize>")"""+")") There's an example here for creating a template to upscale with nnedi3_rpow2. AnyResizerMeGUI & CropResizeMeGUI |
28th September 2022, 11:10 | #9211 | Link | ||
int mode = 0 Controls double rate vs same rate output, and whether or not the spatial interlacing check is performed. 0 : Same rate, do spatial check 1 : Double rate, do spatial check 2 : Same rate, no spatial check 3 : Double rate, no spatial check
15th November 2022, 08:48 | #9213 | Link |
Problems with MeGUI
I get an Error:
[Error] Log -[Information] Versions --[Information] MeGUI: 2913 x64 --[Information] MeGUI Debug Data: available --[Information] Update Check: stable update server --[Information] System Information ---[Information] Operating System: Windows 10 Pro 2009 x64 (10.0.22621.819) ---[Information] .NET Framework: 4.0 (4.0.0.0) ---[Information] .NET Framework: 4.8 (4.8.09032) ---[Information] Redistributables ----[Information] Microsoft Visual C++ 2010 x86: 10.0.30319 ----[Information] Microsoft Visual C++ 2015 x86: 14.0.24215 ---[Information] DPI: 100% (96/96) ---[Information] Monitor 1 ----[Information] Resolution: 1920x1080 ----[Information] Primary Screen: True --[Information] Component Information ---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013) ---[Information] Haali DSS2: (14-04-2013) ---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) ---[Information] MediaInfo: 18.05.0.0 (08-05-2018) ---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011) ---[Information] 7z: 9.20 (18-11-2010) --[Information] AviSynth Information ---[Information] AviSynth Wrapper ----[Information] Version: 1.0.2847.0 ----[Information] Date: 06-05-2018 ----[Information] Interface: 3 ---[Information] AviSynth ----[Information] AviSynth Status: ignored as portable build is forced ---[Information] AviSynth portable ----[Information] File Version: 0.1 ----[Information] File Date: 20-12-2018 ----[Information] File Name: AviSynth+ 0.1 (r2772, MT, x86_64) ----[Information] File Path: c:\program files\megui\avisynth.dll ----[Information] AviSynth Version: AviSynth+ 0.1 (r2772, MT, x86_64) ----[Information] AviSynth+: true ----[Information] AviSynth MT: true ----[Information] AviSynth Status: active -[Information] Update detection --[Information] [15.11.2022 08:41:42] Using cached update config and server: http://megui.tmebi.de/stable/ --[Information] [15.11.2022 08:41:42] No package requires an update --[Information] [15.11.2022 08:41:42] redist files copied: 2017_x64 -[Information] FileIndexer --[Information] [15.11.2022 08:42:49] MediaInfo ---[Information] File: E:\SOPTEST\Video.h264 ---[Information] General ----[Information] Format: AVC ----[Information] FileSize: 10918268154 ---[Information] Video ----[Information] Format: AVC ----[Information] FormatInfo: Advanced Video Codec ----[Information] Width: 1920 ----[Information] Height: 1080 ----[Information] FrameRate: 23.976 ----[Information] ScanType: Progressive ----[Information] Bits Depth: 8 ----[Information] AspectRatio: 1.778 ----[Information] AspectRatioString: 16:9 ----[Information] PixelAspectRatio: 1.000 -[Error] Log for job1 (idx, Video.h264 -> Video.dgi) --[Information] [15.11.2022 08:43:05] Started handling job --[Information] [15.11.2022 08:43:05] Preprocessing --[Information] [15.11.2022 08:43:05] Job command line: "C:\Program Files\MeGUI\tools\dgindexim\dgindexim.exe" -i "E:\SOPTEST\Video.h264" -o "E:\SOPTEST\Video.dgi" -h --[Information] [15.11.2022 08:43:05] Process started --[Information] [15.11.2022 08:43:05] Standard output stream ---[Information] [15.11.2022 08:43:05] Invalid license! --[Information] [15.11.2022 08:43:05] Standard error stream --[Error] [15.11.2022 08:43:05] Process exits with error: 2 --[Information] [15.11.2022 08:43:05] Job completed Do you need more information? What can I do? |
22nd November 2022, 17:50 | #9215 | Link |
VP9 in WebM (MKV) should be readable via indexing source filters like FFMS2 or L-SMASH Works. If not, let's inspect the source file and the error messages and logs, where available.
24th November 2022, 11:06 | #9217 | Link | |
And Tools -> Update all the soft many DGtools don't need now license, if still need license buy it or use other indexer.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 24th November 2022 at 11:14. |
24th November 2022, 17:50 | #9218 | Link | |
From earlier in thread
24th November 2022, 23:53 | #9219 | Link |
Strange file.
The original appears to be VP9 and FLAC in MP4. General Format: MPEG-4 Video Codec: vp09 Audio Format: fLaC It gets converted to MKV, using mkvmerge. General Format: Matroska Video Format: V_QUICKTIME Codec: V_QUICKTIME Audio Format: A_QUICKTIME I would say, no surprise it can't handle a format it can't detect. But no clue why it has no specific codec/format identifier in the remultiplexed copy. |
29th December 2022, 10:47 | #9220 | Link |
Maintain HDR
Hi guys,
I'm trying to take a 4K HDR file and crop it while maintaining HDR metadata. What do I need to type in the command line in x265 to do that? Every time I try to crop and re-encode it removes the HDR metadata. |
megui |
