Old 3rd April 2023, 06:42   #1  |  Link
JimmyBarnes
the Interrogator
JimmyBarnes's Avatar
SUP from bluray won't convert
This file https://bit.ly/3Uj8xix is supposed to be PGS but BDSup2Sub gives "Index 0 out of bounds".
Any clues?
JimmyBarnes is offline   Reply With Quote
Old 6th April 2023, 10:41   #2  |  Link
TDS
Formally known as .......
TDS's Avatar
Any clues?
Hey Jimmy,
I just tried this with Subtitle Edit 3.6.2, and it throws up an error stating that the file does not contain any subtitles, or contains errors, try demuxing again...
So either try demuxing it again, or see if you can download the subtitles for whatever you trying to view.
Cheers
This can be Very "TeDiouS"..
Long term RipBot264 user.
Ryzen 9 7950X
Intel i9-13900KF
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 9 3950X
Link to RB v1.27.0
TDS is offline   Reply With Quote
Old 6th April 2023, 13:52   #3  |  Link
cubicibo
The stream has PG delimiters but all segment types are non-standard. The first segment cannot even be parsed as any of the 5 known segment either. So it is probably not Blu-Ray PGS at all, or it is heavily corrupted.
cubicibo is offline   Reply With Quote
Old 22nd April 2023, 00:08   #4  |  Link
JimmyBarnes
the Interrogator
Thanx TDS and cubicibo for trying to help
