Old 22nd February 2022, 16:16   #101  |  Link
GPhil
Everything works like a charm now, thank you very much!
GPhil is offline   Reply With Quote
Old 23rd February 2022, 20:57   #102  |  Link
GPhil
Another question from me as a HDR newbie: is it normal that the tool only gets 4000+ frames from the HDR10+ content while there are almost 200000 frames in the whole video? Or is there an error in some file?
Old 23rd February 2022, 22:09   #103  |  Link
quietvoid
See https://github.com/quietvoid/hdr10pl...ent-1011125971
If it's reencoded with x265, look for "dhdr10-opt" in the encoding settings.
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 25th February 2022, 14:29   #104  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
-v0.40
*Support for HEVC RAW streams in DDVT Demuxer.
*Support for HEVC RAW streams in DDVT Remover.
*Fixed DV remove Bug in DDVT Remover.
*New Context Menus (create them with DDVT Options).
-QfG- is offline   Reply With Quote
Old 25th February 2022, 19:58   #105  |  Link
zzreel
Originally Posted by -QfG- View Post
-v0.40
Dude, you're the man. Now if only you can add Atmos to JOC conversion lol
zzreel is offline   Reply With Quote
Old 25th February 2022, 22:50   #106  |  Link
von Suppé
von Suppé's Avatar
Thanks for continuously working on improvements of your scripts, -QfG-. Highly appreciated.
Old 26th February 2022, 19:30   #107  |  Link
speedy
What does this mean?
speedy is offline   Reply With Quote
Old 26th February 2022, 23:41   #108  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
-v0.40a
*Fixed number bug in Demuxer.
*Fixed Frameinfo RPU bug.
It's a joke.
Old 27th February 2022, 06:56   #109  |  Link
zzreel
Sorry lol It *is* a joke.
JOC is Joint Object Coding, which is Dolby Atmos in the E-AC3 format. It's what's used in streaming services' versions of Dolby Vision content, especially. Bluray releases use the TrueHD format. It would be awesome if we could convert TrueHD Atmos to E-AC3 JOC for a compressed audio format, but it's not something anyone's figured out yet.
This is pretty interesting tho: https://learning.dolby.com/hc/en-us/...livery-Codecs-
Old 27th February 2022, 08:33   #110  |  Link
von Suppé
von Suppé's Avatar
E-AC3 can be found on (UHD)BD also, where the build-up differs from the 'streaming' version.
Old 27th February 2022, 22:42   #111  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
-v0.40b
*Fixed major Bug by demuxing Profile7 files.
Old 28th February 2022, 17:39   #112  |  Link
zzreel
What exactly is the difference for "content mapping version" 2.9 vs 4.0 during HDR10+ conversion to DV?
What's a case where it matters - or is one superior to the other? Or maybe more importantly, how can we tell if the source is 2.9 or 4.0 to match it? I'm not seeing this listed in MediaInfo.
From what I've gathered, I'm assuming 4.0 is better, but I have no idea if HDR10+ metadate carries anything that goes into 4.0 or if it's just 2.9 metadata. (especially since 2.9 is default in this tool?)
Old 28th February 2022, 18:08   #113  |  Link
quietvoid
It doesn't make a difference for HDR10+ conversion only.
It only matters if you want to add extra metadata.
There's no easy way to check other than looking at the RPU and looking for "cmv40_metadata" in "vdr_dm_data".
Old 5th March 2022, 18:22   #114  |  Link
rco133
Hi.
I am new to this DV stuff, so I might be doing something wrong.
I have demuxed the main m2ts file from UHD disk, and am wondering about the output from the demuxer, when I run it on the EL file.
Video Info = [Resolution = 1920x1080] [Codec = HEVC-10Bit-YUV-4:2:0] [Frames = n.a.] [FPS = 23.976]
HDR Info = [Dolby Vision, Version 1.0, dvhe.07.03, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible]
Shouldn't it report "dvhe.07.06" as this is a UHD bluray disk?
If I open the disc in makemkv is says "dvhe.07.06".
Is "dvhe.07.03" even a valid profile? Seems like 03 is "Reserved".
But as I am new at this, I might be mixing up things totally :-)
Thanks in advance.
rco133
rco133 is offline   Reply With Quote
Old 5th March 2022, 19:08   #115  |  Link
nevcairiel
dvhe.07.03 means profile 7, level 3 - which is perfectly valid. This is likely because you are looking at the EL stream, which is only 1920x1080, hence the video only being level 3, and not level 6 like the main UHD stream.
Old 6th March 2022, 10:34   #116  |  Link
rco133
Thanks for the pointer.
As I wrote I am quite new to this DV stuff, and reading the DolbyVisionProfilesLevels made me come to that conclusion :-)
rco133
Old 11th March 2022, 17:59   #117  |  Link
Albano
@-QfG-
Thanks for sharing but how to run your tool.
Albano is offline   Reply With Quote
Old 12th March 2022, 08:44   #118  |  Link
von Suppé
von Suppé's Avatar
Read this post and one down: https://forum.doom9.org/showthread.p...04#post1961404
Old 12th March 2022, 10:14   #119  |  Link
von Suppé
von Suppé's Avatar
Hi -QfG-
Will elementary streams for the DDVT remover be supported some time?
Old 12th March 2022, 20:43   #120  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Originally Posted by von Suppé View Post
Hi -QfG-
In the next update.
-v0.40c
*RAW Stream Support for all Scripts.
*Turn off Autodetect Borders Feature for RAW Streams.
*DV and HDR10+ Metadata can now replaced in Stream.
