Old 3rd June 2011, 23:27   #21  |  Link
A VERY minor mod to InfoF.h, the Info.h companion for printing
formatted text, no real need to change it but here it is anyway.
These are the lines as they were:
	const unsigned char *se, *ss;			        // unsigned
	for(ss=(unsigned char*)s; *ss; ss=se) {		        // while, some to do
		int n;
		for(se=ss; n = *se, n>=' ' && n <= 223; ++se);	// Find end+1 of printable
		int len = se - ss;				// Len of printable
		if (len) {					// Some to print
			DrawStringPlanar(dst,x,y,(const char*)ss,len);
And here is the entire mod:
void  __stdcall DrawFStringPlanar(PVideoFrame &dst,int x,int y,const char *s,bool pix = true)
{ // Draw formatted string at pixel or character coords, pix == false = character coords
	if(pix == false) {x *= 10;	y *= 20;}		// To Chars
	int in_x = x;						// REM x for '\r'
	const unsigned char *se=(unsigned char*)s;	        // unsigned
	while(*se) {						// while, some to do
		int n;
		for(s=(char*)se; n = *se, n>=' ' && n <= 223; ++se);	// Find end+1 of printable
		int len = (char*)se - s;			// Len of printable
			DrawStringPlanar(dst,x,y,s,len);	// do the biz
			x += len * 10;				// update x coord
		} else {				        // Ctrl code OR nonsense;
			if(n == '\n') {
				x = 0; y+=20;			// Newline, down 1, LHS
			} else if (n == '\r') {
				x = in_x; y +=20;		// Newline Special, Down 1, orig x coord
			} else if(n == '\b') {
				x -= 10;			// Backward Space
			} else if (n == '\f') {
				x += 10;			// Forward Space
			} else if (n == '\t') {
				x+= ((4*10)-(x%(4*10)));	// H-Tab (step 4)
			++se;	// skip ctrl code (and unknowns, outer loop detects nul sentinel)
void  __stdcall DrawFStrPlanar(PVideoFrame &dst,int x,int y,const char *s)
{	// Formatted Print @ character coords
	DrawFStringPlanar(dst,x,y,s,false);
The mod just saves a bit of swapping about of pointers.
The above code is for the Planar rendering function only,
amend the other 3 also.
EDIT:- shall within minutes of this edit, add (above modified) "InfoF.H"
to the 1st post for those that might want to try the companion header that
allows formatted print at both pixel and character coords via the standard
Info.h, (of course no color control is possible). Just include the
InfoF.h header after Info.h and call the InfoF.h functions when
either character or formatted print is required.
Last edited by StainlessS; 5th June 2011 at 19:54. Reason: Adding Infoh.h to 1st post.
Old 12th June 2011, 07:44   #22  |  Link
Is there any chance that a moderator could at some stage, approve the
2nd attachment in the first post, if there seems to be a problem, I could
always delete it, (or save me the bother and do it yourselves).
About 7 days waiting now. ta.
Old 12th June 2011, 12:05   #23  |  Link
Wilbert
Done.
Old 20th April 2013, 19:18   #24  |  Link
DDigitTest.dll & DDigitTest26.dll with source, update, see 1st post.
Complied for Avisynth v2.6.
YV411 looks pretty awful with color (as expected).
Old 5th June 2013, 03:43   #25  |  Link
v1.05, DDigitTest.dll & DDigitTest26.dll with source, update, see 1st post.
Implemented additional 16 Greyscale print colors.
YV411, optionally prints only luma channel and ignores chroma. (looks better).
Old 10th July 2013, 19:10   #26  |  Link
DDigit v1.06 with DDigitTest.dll and DDigitTest26.dll with source, update. See 1st post.
Old 30th March 2015, 16:34   #27  |  Link
DDigitTest (DDigit test dll) v2.6 dll recompiled with Avisynth Version 6 Header.
See 1st post.
No version number increment, uses same version No as DDigit (v1.06).
EDIT: A Few screens from DDigitTest (with a few Info.H screens)
DDigit MONOLITHIC Renderer at YV24
Names
One Pixel At a Time Col
Off Screen
One Pixel At a Time Mono
Color Codes
Vertical
One Pixel At a Time Diag
Full Character Set (Identical for Info.H)
Info.H Renderer Tests @ YV24 (with synthesized InfoF.H support)
Info.H Off Screen
Info.H One Pixel At a Time
Info.H One Pixel At a Time Diag
Info.H Control Codes
EDIT: Above images seem to be all broken, sorry.
EDIT: Fixed.
Old 2nd January 2019, 18:14   #28  |  Link
DDigit demo DDigitTest dll's for avs v2.58, v2.60/+, x86 and x64. Requires VS 2008 CPP Runtimes.
See 1st post.
EDIT: Cannot rename the thread title when thread reaches a certain age.
plugin, sdk, text
