#21 | Link |
Posts: n/a
I don't think anyone has analyzed a stream yet to know exactly. I assume it's some form of custom signaling or metadata that their players can read and is ignored by others. There's no way it can be multiple encodes when the other point of these discs are to increase the average bitrate.
#22 | Link | |
Posts: n/a
To add from here:
#23 | Link | |
![]() Join Date: Jan 2006
The only obvious way I see for them to do what they're doing would be to have a stock Rec. 709 encode and then some kind of enhancement later that added the (relatively small delta) of xvYCC data. Since it's mostly in chroma, that wouldn't be that many samples and they can be quantized quite coarsely. Perhaps using something like Scalable Video coding. I'd think the PS3 would likely have the horsepower to do something like this. I am now very intrigued by this! Also, other than Sony BD players, are there any known devices capable of xvYCC playout? It seems support is way more common in TV than it is in any way to play back the content. Can decoders internal to the TVs do the right thing with xvYCC bitstream? |
#24 | Link |
Avisynth Developer
From what I understand Sony use the 1-15 and 241-254 chroma values to represent higher saturation colours. When you do the normal YUV->RGB translation you can end up with normalised colour values less then 0.0 or greater than 1.0, normal decoders clamp these values, advanced decoders map these values into a wider gamut colour space. The luma range is still 16-235.
#25 | Link | |
#26 | Link |
Avisynth Developer
The out of gamut high saturation colours considered here would have been clamped in normal processing anyway, either by the source camera and/or the display device. The system just gives the opportunity to not clamp the very saturated colours when a high gamut source and display are available.
#27 | Link | |
#28 | Link |
Avisynth Developer
Yes, intuitively I agree there should be some sort of saturation posterization effect but how do you characterise and witness it.
We are talking about saturation getting clamped here, not luminance or hue. And saturation restriction happens with our simple trichromatic eyes. The clamping happens in the YUV to RGB translation where you end up with normalised RGB values less then 0.0 or greater than 1.0 I tried an experiment using Limiter(0, 255, 31, 226) to knock another 15 off the normal chroma range and I cannot see any difference, which just probably means I do not have samples that sufficiently use the high saturation part of the existing gamut and/or a display that is not already more saturation challenged than the clamp. I guess an extreme test case might involve some pure monochromatic light sources like sodium lamps, lasers, etc and a display version of the same. But our eyes cannot see spectrally pure colours as spectrally pure. |
#29 | Link | |
#30 | Link |
When I compared the new "Mastered in 4K" BD of the 2002 Spider-Man movie to the old disc, I found that there were more instances of >240 chroma on the previous release than the xvYCC one.
It would be nice if they included some test content to verify the effects of the gamut expansion on your TV. There is a hidden video file but it's just a long, slow pan across a still image with no apparent usefulness. |
#31 | Link | |
Are there any discs that are known for particularly good use of xvYCC? Or even noticeable use? |
#32 | Link | |
Life's clearer in 4K UHD
I would like to know if there's anybody on this forum who has a 'xvYCC supporting' Sony Blu-ray player and TV? Because without these two supporting devices, nobody is going to 'see' any noticeable difference!
#33 | Link |
Well, I've made myself a Rec. 2020 H.264 High 10 encode via x264!
Anyone have any idea what players actually know about Rec. 2020? I've got a Quadro K4000 plugged into a Dell U3011 30-bit display via DisplayPort, so I can render out 10-bit images via both DirectX and OpenGL. Dell claims it has a 120% gamut range based on the CIE1976 (83%) and CIE1931 (72%) test standards. But what should be able to do the right thing here? |
#35 | Link |
Since the topic also mentions greater color depth, I would like to point out the Panasonic "Master Grade Video Coding". There are not a lot of infos about it, but seems that the hint is to use the bluray MVC structure to use the base view as the standard image, and the dependent view for increase the bit depth of the video. Panasonic players with MGVC support should be able to 'merge' the MVC and outputs a 2D video with up to 12bit informations. Also, this method allows to fully use the 60 Mbps of the bluray 3D specs.
Here some explanation (JP) |
#38 | Link |
Also, what's the proper --colormatrix setting for 10-bit Rec. 2020 (without expanded luma range)?
Using --colorprim bt2020 --transfer bt2020-10 are obvious, but I can't find any documentation on the difference between bt2020c and bt2020nc |
#39 | Link | |
bt2020nc = non-constant luminance So for your example, bt2020nc would be correct. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
