#19661 | Link |
Formally known as .......
Need more info !!!
This can be SO "TeDiouS".. Long term RipBot264 user. #1 Ryzen 7950X #2 Intel i9-13900KF #3 Ryzen 5950X #4 Ryzen 5900X #5 Ryzen 3950X |
#19662 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th October 2022 at 14:35. |
#19663 | Link | |
Aslo just something i noticed, perhaps just a coincidence (or a clue), but i changed from demux (TRUEHD / AC3) to core when selecting the audio it seems to be running fine... perhaps /restart-if-no-progress at work but i had this option set earlier also. i did multiple encodes (10+) to x265 with core audio and didn't need to restart any of them ![]() |
#19664 | Link |
not sure if it's the same issue or a Win server 2019 specific "security" issue but my issue when encoding server didn't start was that the process was waiting for another process to finish, i had to kill that process for encoding server to start, look in task mananger if you can see encoding server there and then go to details -> analyze wait chain.
#19665 | Link | |
#19666 | Link |
is there a way a pause button could be added? this would be useful when i want to put the computer to sleep for a bit. also had a conversion trashed as my laptop went to sleep when i pulled the power out to move it. i had the lid closed but had both when lid closed do nothing set and put computer to sleep both set to never.
#19667 | Link | |
see here :- and the posts afterwards. I VERY much doubt you will get a "Pause" button, the best way is to use Distributed Encoding, and if you accidently close the lid, or the power goes off, you will only lose what chunks were encoding at the time (more often than not). Also, if you want to stop the encode, you need to be watching the encoding window, and when a chunk(s) finishes, you manually stop it, and then Abort the job...98 times out of 100, it will start up, where it left off.
This can be SO "TeDiouS".. Long term RipBot264 user. #1 Ryzen 7950X #2 Intel i9-13900KF #3 Ryzen 5950X #4 Ryzen 5900X #5 Ryzen 3950X Last edited by TDS; 2nd November 2022 at 12:17. |
#19668 | Link | |
#19669 | Link |
I'm getting an eac3to v3.34 Demuxing error since the latest update.
eac3to v3.34 command line: "E:\Blue Ray Ripping\Tools\eac3to\eac3to.exe" "D:\Rip\BULLET_TRAIN" 1) 2: "C:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "C:\Temp\RipBot264temp\job1\audio_1_English.dtsma.w64" -down16 -dcadec 10: "C:\Temp\RipBot264temp\job1\10_subtitles_English_1080.sup" 11: "C:\Temp\RipBot264temp\job1\11_subtitles_English_1080.sup" 12: "C:\Temp\RipBot264temp\job1\12_subtitles_Chinese_1080.sup" 13: "C:\Temp\RipBot264temp\job1\13_subtitles_Chinese_1080.sup" 14: "C:\Temp\RipBot264temp\job1\14_subtitles_French_1080.sup" 15: "C:\Temp\RipBot264temp\job1\15_subtitles_Korean_1080.sup" 16: "C:\Temp\RipBot264temp\job1\16_subtitles_Portuguese_1080.sup" 17: "C:\Temp\RipBot264temp\job1\17_subtitles_Spanish_1080.sup" 18: "C:\Temp\RipBot264temp\job1\18_subtitles_Thai_1080.sup" 19: "C:\Temp\RipBot264temp\job1\19_subtitles_French_1080.sup" 20: "C:\Temp\RipBot264temp\job1\20_subtitles_English_1080.sup" 21: "C:\Temp\RipBot264temp\job1\21_subtitles_Chinese_1080.sup" 22: "C:\Temp\RipBot264temp\job1\22_subtitles_Korean_1080.sup" 23: "C:\Temp\RipBot264temp\job1\23_subtitles_Portuguese_1080.sup" 24: "C:\Temp\RipBot264temp\job1\24_subtitles_Spanish_1080.sup" 25: "C:\Temp\RipBot264temp\job1\25_subtitles_Thai_1080.sup" 1: "C:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="C:\Temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 7 audio tracks, 16 subtitle tracks, 2:06:32, 24p /1.001 1: Chapters, 17 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) 4: AC3, English, 5.1 channels, 384kbps, 48kHz, -8ms 5: DTS Master Audio, French, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 1509kbps, 48kHz) Last edited by gabbett1; 2nd November 2022 at 18:47. |
#19670 | Link | |
There hasn't been a significant update(s) since the end of August, and then eac3to wasn't in that round of updates. What version of RipBot are you using, Atak's, or Pauly Dunne's ??
#19671 | Link |
If you use distributed encoding, I suggest that you do not install the latest windows 11 patch KB5018496 and maybe the October .net KB5018341. This just came down on all my boxes and I am having issues again where a encoding server will start an encode chunk, immediately say it completed it, then the same server will start another chunk and continue on. In the distributed encoding window on the client. that server will have a blank area where it would normally say encoded xxxc frames at whatever fps. So the encode never finishes up with that chunk missing. The only way to get past it is to abort the encode and then start it back right away. Before these updates I recently have done hundreds of hours of encoding with absolutely Zero issues.
Sometime it will just encode that 1 missing frame but most of the time it starts the whole process over from scratch. It is now doing this on at least 50% of my encodes, so it pretty much kills any unattended encoding for now. When I get some time I am going to roll back and do some troubleshooting to A. confirm it is that patch, and then B. see if I can figure out what the heck is going on |
#19672 | Link | |
I have both those updates, but unfortunately, I haven't done any encodes since.... It will be interesting to hear what you discover, and I will report back, after I've done some encodes.
#19673 | Link |
Removed all the updates since last week when everything was working OK on the client and all 8 servers. No change, still doing it. Next step was I restored my client to a full backup from last week before the updates and also half my servers to start. Started up a distributed encode with the restored client and only the restored servers and it still did it near the end of the encode.
I can't think of anything else it could be at the moment. None of the restored machines had any updates that snuck in after the restore. Update: Pretty sure something in the ripbot folder got screwed up somehow. Last thing I did was kill my Ripbot folder, download a fresh copy, and put my settings back in. Encoded about 8 hours now with only 1 glitch which I am going to call just an anomaly. After I get done with this latest round I'll start one by one putting the Windows11 updates back on and start testing . Last edited by rlev11; 4th November 2022 at 22:45. |
#19674 | Link |
feature wanted: lock size "dual layer BD size".
it already has single layer as a setting but i would like dual layer for larger films that need more space/bitrate. or if someone can tell me the number to put in here that will fill a dual layer BDR. ive tried finding it on the net and get all sorts of different answers. |
#19675 | Link |
#19676 | Link | |
Anyway, as you can see, Atak has pointed you to some info, but in the drop down, you could simply type in double of the default, eg:- 47600 (twice the 23800, shown), you could probably go a little bit more.
#19677 | Link |
Feature Request - AAC 7.1 448K
Hi Atak,
I kind of remember a long time ago that AAC 7.1 was problematic with some decoders and that is why 5.1 was the standard. I convert my 4K discs (thank goodness for optical media!) for home streaming that includes the full Dolby TrueHD+atmos 7.1 (or DTS:X), and I also make a streaming 2K version that uses AAC 5.1 from the TrueHD 7.1 track. This morning I needed a quick AAC track from Top Gun Mavrick and I ran FFMPEG to convert the TrueHD track expecting to get a 5.1 track as the output. Low and behold, I had a 7.1 track. I tested it by playing it through my system and it turned out all the channels were behaving correctly. Atak, can you please add an audio option for 7.1 AAC at 448K option for sources that have 7.1 or more channels. I'm going to write a script to batch extract and convert the 7.1 track from my 4K home encodes and mux it into my 2K encodes. |
#19678 | Link |
Sorry I was away for a bit. Ripbot downloaded an update when I started it. I think I'm using Atak's version, but honestly I wasn't aware there were different ones. I'm currently running version 1.26.2. My system is running Windows 7.
#19679 | Link |
Hey,
I think that was a bit of a dig at me...I'm sure you know what I meant !!! I don't really know why you keep asking for additions, you know it'll never happen ![]() May I suggest you try this, and see if it suits your needs :- https://forum.doom9.org/showthread.php?t=181206 I did a TrueHD to AAC 7.1 conversion with that app, and here's a comparison :- Code:
Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 3 h 2 min Bit rate mode : Variable Bit rate : 3 403 kb/s Maximum bit rate : 5 616 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Stream size : 4.34 GiB (6%) Title : TrueHD Atmos 7.1 Language : English Default : Yes Forced : No Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE Code:
Audio Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Format version : Version 4 Codec ID : 2 Bit rate mode : Variable Channel(s) : 8 channels Channel layout : C L R Ls Rs Lw Rw LFE Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 1.44 GiB (100%)
This can be SO "TeDiouS".. Long term RipBot264 user. #1 Ryzen 7950X #2 Intel i9-13900KF #3 Ryzen 5950X #4 Ryzen 5900X #5 Ryzen 3950X Last edited by TDS; 5th November 2022 at 04:37. |
#19680 | Link | |
And also, as you got an update you are clearly using Atak's version !!! I can highly recommend Pauly's, I have been using it almost as long as it's been available, SO many more options !!! https://forum.doom9.org/showthread.p...91#post1974691
