Old 5th January 2010, 16:41   #1  |  Link
killer_sai
CRF Error!
1.When i used x264 unrestricted 1pass constant quality HQ profile in Megui...
this is my cmds
program --profile high --level 5.1 --preset fast --thread-input --deblock -1:-1 --bframes 3 --b-adapt 2 --b-pyramid --b-bias 0 --scenecut 40 --ref 5 --rc-lookahead 40 --no-mbtree --aq-mode 1 --aq-strength 1.0 --merange 16 --me umh --subme 6 --partitions all --trellis 2 --psy-rd 1.0:0 --output "output" "input"
an error occurs in rc-lookahead!
2.i want to edit that Cmd line how Can I
killer_sai is offline   Reply With Quote
Old 5th January 2010, 16:49   #2  |  Link
desta
If I'm not mistaken(?), rc-lookahead is part of mbtree, which you've turned off.
desta is offline   Reply With Quote
Old 5th January 2010, 18:20   #3  |  Link
sneaker_ger
Which version of x264 and MeGUI are you using? "--b-pyramid" without any parameter ("none", "strict", "normal") doesn't work with the newest builds at all. I'd suggest you to first update MeGUI to the newer patched builds, as the original developers have abandoned the program. If you set "--b-pyramid" correctly after updating MeGUI it should work.
crf, crf error
