Old 12th December 2019, 15:53   #301  |  Link
redbtn
redbtn's Avatar
Originally Posted by cretindesalpes View Post
Here it is. fmtconv r22
Thank you!
Can I ask why spline64 and spline taps=4 doesn't produce the same result?
redbtn is offline   Reply With Quote
Old 13th December 2019, 09:15   #302  |  Link
cretindesalpes
cretindesalpes's Avatar
This is because the splineNN algorithms are hardcoded plain cubic splines (see here for details), while the spline + taps are natural cubic splines, as implemented by Wilbert in SplineResize 0.2.
dither 1.27.2 for AviSynth | avstp 1.0.3 for AviSynth development | fmtconv r22 for Vapoursynth | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 15th December 2019, 21:25   #303  |  Link
Pat357
I have some problems building fmtconv for x64 using Mingw64.
Created an issue on your git : https://github.com/EleonoreMizo/fmtconv/issues/14
After applying the patch I attached at the issue https://github.com/EleonoreMizo/fmtc...fmtc.patch.txt , the building works ok, but I'm not sure my patch doesn't mess up anything.....
Pat357 is offline   Reply With Quote
Old 19th December 2019, 14:23   #304  |  Link
cretindesalpes
Thank you, the patch was correct. I did several other modifications. Please check the git repository.
Old 25th January 2020, 19:33   #305  |  Link
dev-null
One of the primary issues I run into, when building myself a VapourSynth setup for my outdated OS X system (10.10), was a broken/ non working build of "fmtconv".
I fetched the r22 release and build it with clang ("clang-700.1.81", as included in XCode 7.2, last available for Yosemite). It compiled w/o a hitch, just had the known linking problem with a missing libatomic (the GCC thingy). Removing the respective -latomic flag fixed that. But calling any "fmtc" stuff from a VapourSynth script made vspipe never return. It was busy looping a single thread @ ~100% CPU usage. A build of the older r21 release works fine. Also a build of r22 with gcc 9.2 works fine too (no -latomic linking problem this way either.) So there's some sort of change in r22 that makes older clang mess up the build.
Interestingly I can't build the current master version from git with old clang nor gcc 9.2. The compilation fails rather similarly on stuff in src/conc/Interlocked.hpp. Here's the gcc9.2 output: https://pastebin.com/3NWWBJKW . Sadly I can't wrap my brain around this C++ stuff, so I have no idea what it wants to do there and how I could fix it. Also interesting is that this Interlocked stuff seems to be the stuff where the broken r22 clang build has trouble with. That's according to a process sample taken with Activity Monitor: it seems to hang around some of those "OSAtomicCompareAndSwap" functions in the stack trace.
Just reporting. Maybe someone has run into the same issue and knows details why it happens exactly: compiler bug, fmtconv's code broken, etc.? Anyway… to make it short: if you got busy-looping issues with fmtc[onv] stuff on an outdated Mac OS X system, try a build of the lib with gcc-9.2!
dev-null is offline   Reply With Quote
