Old 20th March 2023, 11:53   #1  |  Link
Myislandsoftware
MyIslandVideo a software for encoding with HandBrakeCli and FFMPeg
MyIslandVideo is a software that will help you to create media very easily with statistical tools.
The tools used are the following
HandBrake Cli
FFMpeg
You will have the possibility to modify the code if needed, otherwise the templates available allow you to encode from 8k to 360p with the different formats H264, HEVC, AV1
My site is the following
http://MyIslandSoftware.net
Myislandsoftware is offline   Reply With Quote
8k-4k, encoder, ffmpeg, handbrake, hevc
