Old 9th October 2021, 14:26   #501  |  Link
TDS
Formally known as .......
TDS's Avatar
Originally Posted by Dogway View Post
I found BM3D to be a bit soft on edges, I think because it does some spatial filtering (3D). For video I normally avoid denoising directly in spatial domain unless it's something very specific or masked. For guiding I think it's good, in my brief comparisons motion estimation was better than KNLMeansCL, but it usually hanged when trying higher radius.
@TDS: Post the error message so I can have a look, otherwise can't help. If you want a cleanup tip, just keep core filters and move out old ones or used sparsely, then try to update them to latest version, including AviSynth.
That's the plan....and I will post errors msg's too... it's just they vary from script to script.
Thanks
Long term RipBot264 user.
RipBot264 modded builds..
TDS is online now   Reply With Quote
Old 9th October 2021, 14:27   #502  |  Link
TDS
TDS's Avatar
TDS, you need this [in the 1st post, TextArea Cache ].:- https://forum.doom9.org/showthread.php?t=177066
Strange thing was, I had posted several replies to another user, but the one to Dogway failed
Old 10th October 2021, 01:25   #503  |  Link
TDS
TDS's Avatar
Hey Dogway, can you please reply to this post :-
https://forum.doom9.org/showpost.php...&postcount=491
It was delayed a day or so for some reason, and it's now been allowed
And another thing, now that MysteryX has mentioned multiple pre-filters, could that be done with your scripts ??
eg:-
video=SMDegrain(video,tr=6,thSAD=600,contrasharp=30,str=1.2,refinemotion=true,prefilter=4,prefilter=5)
Old 10th October 2021, 01:46   #504  |  Link
kedautinh12
Oh, hi oldman, TDS is your new account?
Old 10th October 2021, 01:49   #505  |  Link
kedautinh12
SMDegrain only support single prefilter. You need wait MysteryX port xclean to avs but you sure will complain about speed again
Old 10th October 2021, 02:13   #506  |  Link
Dogway
OK, now I see. Yes there's no 's' argument in ex_KNLMeansCL() I added it now (also wmode) and defaulted to be the same as 'a', and it gains some sharpness back. Anyway this doesn't trigger any error whatsoever...
You can use any prefilter on your own, the 'prefilter' argument is just a commodity, it's not an end-it-all solution, for advanced prefiltering you define it yourself like:
pre=fluxsmootht(3).removegrain(11)
SMDegrain(tr=6,thSAD=500,contrasharp=40,prefilter=pre,str=1.2,refinemotion=true)
The documentation is old but it's still useful for most of the settings, so have a look at it.
Also observe the presence of 'Str' the prefilter clip is still passed the normalization stage with ex_luma_rebuild() in this case.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 10th October 2021, 03:11   #507  |  Link
TDS
TDS's Avatar
Hmmm, close, we both use RipBot264, and "we" have been helping each other trying to improve RipBot as the dev seems to have lost his interest of late.
When he mentioned that he was going to take a break, I created an account to carry on.
I'm sure he will appear every so often.
You helped him a lot, so hopefully you can continue, for me ?
But it can be a bit tedious (TDS)
Old 10th October 2021, 03:19   #508  |  Link
kedautinh12
Ok, i will help you in my possibility
Old 10th October 2021, 05:45   #509  |  Link
TDS
TDS's Avatar
Thanks, but I really don't understand most of this stuff.
HOWEVER:-
#change contrasharp=true to contrasharp=(int) it errors on line 538 of SMDegrain333d
#adding lsb=true or false, wont even start Avsmeter
These didn't work for me.
#pre=fluxsmootht(3).removegrain(11)
#SMDegrain(tr=6,thSAD=500,contrasharp=30,prefilter=pre,str=1.2,refinemotion=true,lsb=true)
So, so far, so good, on the next script
Old 10th October 2021, 09:17   #510  |  Link
Dogway
lsb settings are deprecated. They are not in SMDegrain anymore, the error message should tell you.
Also:
Is not an error message it's the telephone game. If I had to guess you explicitly wrote "(int)" into the argument?
By the way I'm going to update SMDegrain with a fair amount of changes, nothing critical all bugfixes and improvements.
mfilter is also fixed for defined CClip inputs. Recursion now works again for medianT when tr<=2, and added a few Asserts for it. The 's' argument is added to ex_KNLMeansCL(), and passed to the prefilter which has been tuned for a bit more sharpness. ex_retinex() blacks now have been clipped instead of scaled, this respects the original intent better, also it's faster. New setting which I wanted to add since 7 years ago, 'LFR', it will restore low frequency details, specially useful for TemporalSoften, check the images below.
smdegrain(tr=2,mode="temporalsoften",blksize=32,thSAD=900,LFR=5,contrasharp=false,refinemotion=true)
smdegrain(tr=2,mode="temporalsoften",blksize=32,thSAD=300,LFR=false,mfilter=ex_boxblur(5,mode="weighted",UV=3),contrasharp=true,refinemotion=true)
source
before
after low frequency restore
Old 10th October 2021, 09:42   #511  |  Link
TDS
TDS's Avatar
So sorry 'bout that, I was actually going to write "a number" but thought int would describe that.
#change contrasharp=true to contrasharp=(a number) it errors on line 538 of SMDegrain333d
I very much doubt that I will be able to use 2 SMDegrain lines like that.
Old 10th October 2021, 10:04   #512  |  Link
Dogway
Why don't you post the error message or the SMDegrain call? I can't interpret what you interpret of those. Post concise information so I can give you precise answers.
SMDegrain v3.3.4d is released now. Currently LFR requires ExTools v6.1 which is unreleased because I want to solve the optimized median of 48 inputs. I might release it without it if I get stuck.
Old 10th October 2021, 11:20   #513  |  Link
TDS
TDS's Avatar
OK, I thought I was explaining it as best I could, but in the future I will post the "call", then try to explain the error....not sure if I can copy the error msg.
Will get latest SMDegrain, and see how it goes.
Currently I have everything working sweet, after the "clean up" so that was worth it.
One other question:-
Can the values in red, be easily changed, or does it need to be done somewhere else ??
(prefilter== 4) ? inputP.ex_KNLMeansCL(a=2,s=2,d=1,h=7.0,wmode=0,chroma=chroma,device_type="GPU",device_id=device_id) : \
(prefilter== 5) ? inputP.ex_BM3D(sigma=5,radius=1,CUDA=true,UV=Chr,fulls=fs)
Old 10th October 2021, 11:52   #514  |  Link
Dogway
You can do like this:
pre=ex_KNLMeansCL(a=2,s=2,d=1,h=7.0,wmode=0)
SMDegrain(tr=3,thSAD=300,contrasharp=30,prefilter=pre,refinemotion=true)
Old 10th October 2021, 12:08   #515  |  Link
TDS
TDS's Avatar
I'm pretty sure I cannot use a script like that...see here for an example of what my scripts need to look like (ignore the build numbers, etc)
https://forum.doom9.org/showpost.php...&postcount=398
Old 10th October 2021, 12:45   #516  |  Link
Dogway
Why not? elaborate please.
Old 10th October 2021, 13:06   #517  |  Link
TDS
TDS's Avatar
Several reasons...
The way that scripts are written for/in RipBot264.
My lack of experience & understanding of how to write / adapt scripts.
I have tried a couple of multi line scripts like that, and it just doesn't work
Old 10th October 2021, 13:16   #518  |  Link
Dogway
Write in the RipBot264 thread on how you can adapt the above call to be read by RipBot264... I don't use any interface personally.
Old 10th October 2021, 13:23   #519  |  Link
Boulder
Pig on the wing
Boulder's Avatar
That LFR might be useful as a generic function - do you have plans to put it in ExTools? There are often cases where a high thsad is a must but it smooths the flat, low-frequency surfaces a bit too much.
Old 10th October 2021, 13:57   #520  |  Link
TDS
TDS's Avatar
I will give that a try, but I don't expect much.
That is why I'm here.
So how do you test your scripts ?
avisynth, dogway, filters, hbd, packs
