Old 4th September 2021, 13:04   #301  |  Link
Dogway
Originally Posted by real.finder View Post
#ex_boxblur(5,mode="mean")
Dither_convert_8_to_16().Dither_box_filter16(5).DitherPost()
but I can see that they are not similar
They are the same, the only difference is that Dither_box_filter16 is frequency domain based so it's faster for higher sigma, when above 5 in ex_boxblur().
a=Dither_convert_8_to_16().Dither_box_filter16(5).DitherPost()
ex_boxblur(4,mode="mean")
ex_makediff(a, aug=true, UV=128)
So if the question is if we need a DFT box filter, probably the answer is yes, same with binomial blur. Of course with HBD support and asymmetric blur option. I would also vouch for porting CTM (Constant Time Median) from VapourSynth, so doing a 5x5 or 7x7 median isn't as slow as it is now.
ex_bilateral() gives same output as vsTBilateral(), speed is similar as well. Dither_bilateral16() employs shortcuts to speed up the process but in my opinion the output doesn't look nice.
Excerpt from docs.
"Actually, this implementation is an approximation of a bilateral filter, like many other image processing tools do. The spatial weighting is not a gaussian curve but a box, and the value weighting is a trapezoid."
Thanks for LimitFilter link, I will have a look when I got time, I've been busy porting *.mp4 sharpeners
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 4th September 2021, 13:11   #302  |  Link
real.finder
so Dither_box_filter16(x) = ex_boxblur(x-1, mode="mean")
https://github.com/pinterf/MedianBlur2
but there are people who like the Dither_bilateral16 more than others
See My Avisynth Stuff
Old 4th September 2021, 13:36   #303  |  Link
Dogway
MedianBlur2 didn't perform well on my benchmarks, something is going on there, occasionally it would perform "fine" but must of the time it crawls so I don't know.
I will try to post comparison shots for ex_bilateral() and Dither_bilateral16() when I got some time.
Old 4th September 2021, 15:27   #304  |  Link
Dogway
Here's the comparison (brighten to see better):
Converttostacked().Dither_bilateral16(radius=2,thr=10,flat=1.0,u=1,v=1).Convertfromstacked()
ex_bilateral(1)
As you can see Dither_bilateral16() output is very dirty/grainy, and artifacts similar to combing.
By the way, updated SharpenersPack with new sharpeners; SSSharp, ReCon, blah, MedSharp, ex_unsharp and SharpenComplex2
Old 4th September 2021, 17:16   #305  |  Link
real.finder
ex_bilateral(1)
I think it depends on the settings and the source
here a friend words
Old 5th September 2021, 10:26   #306  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by Pauly Dunne View Post
Well, I have tried a lot of different things to diagnose this, but it seems to be on only 4 servers that I use for the Distributed Encoding function of RipBot.
So they are simply connected via a LAN, and don't need the complete program to encode (very clever, actually), and yet other pc's on the LAN don't have the problem,
So I think my only recourse is a fresh setup of Windows.
Update:- It turned out that I needed to update these:-VC_redist.x86.exe & VC_redist.x64.exe
There must be some subtle change in Dog's ExTools & SMDegrain.
I've finally figured out what the problem is....
Even tho it was good to update VC, it's an OpenCL problem when using KNLMeansCL, as a pre-filter in Doggy's SMDegrain !!!
The pc's that have this error haven't got a compatible GPU, and I'm not sure if you can get a "driver" for older Xeon Intel CPU's for OpenCL Support.
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 5th September 2021, 11:11   #307  |  Link
kedautinh12
Wait a minute, i remember you said you had Ryzen cpu??
Old 5th September 2021, 12:41   #308  |  Link
Pauly Dunne
Grumpy Old Man.
Good memory, I actually have 2
I also have a few I7 Intels, some E5 Xeons, And a LOT of older X series Xeons.
And the older Xeons have no "proper" Gpu's....
Its a RipBot264 Distributed Encoding set up...
Old 5th September 2021, 12:57   #309  |  Link
kedautinh12
Rich oldman. When you want discard any old amd ryzen 5000 series, can you give me
Old 5th September 2021, 21:23   #310  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Be kind, ask for grannys. These are good too ;-)
Emulgator is online now   Reply With Quote
Old 6th September 2021, 07:15   #311  |  Link
Pauly Dunne
Grumpy Old Man.
You welcome
I'll see you @ the other Forum.
Old 6th September 2021, 23:12   #312  |  Link
Dogway
ExTools updated to v5.4
-ex_vinverse() - small optimization
-ex_blur() - 'bifit' arg to toggle between gaussian or binomial distribution
-ex_guidedblur(), ex_ANguidedblur() - moved to yugefunc.avsi
-ex_GaussianBlur() - New. Optimized true gaussian blur approximation for high sigma
-ex_luts() - bugfix when using two clips. 'exprf' arg to append code to the end.
-ex_shape() - add anisotropy for shapes (except 'cross')
-sel_med() - more medians, fill up to n=49
Just updated ExTools to v5.4, required for my recent updates (from today updates, and before for SharpenersPack). This feels like the last version although I will fix any reported bugs or add things if it feels convenient, but my update rate on ExTools will be much slower from now on.
I also uploaded today v1.0 of SharpenersPack, because it feels very solid. There are possible additions like Oyster, qUINT Sharp, NLM Sharp and other kind of sharpeners, but for now it will stay like this.
Also updated SMDegrain to refine ex_retinex() with the new ex_GaussianBlur() function.
Now I will focus on yugefunc and port worthy functions from VapourSynth, I added a list in the header for the filters I wish to port.
I will also have a look at QTGMC to optimize it more, port Didée's LTSMC, remake ex_vibrance() and whatever arises.
Old 7th September 2021, 00:57   #313  |  Link
Pauly Dunne
Grumpy Old Man.
Busy, busy, busy...I'm having a hard time just keeping up
Edit :- Unfortunately, since changing up to SMDegrain 3.2.8, I'm getting another Line 161 error...go back to 3.2.7, it's good , when using BM3D in CPU mode.
On further investigation, the difference was :-
function ex_BM3D(clip a, float "sigma", int "radius", int "UV") {
rgb = isRGB(a)
isy = isy(a)
bi = BitsPerComponent(a)
s = Default(sigma, 3)
r = Default(radius, 1)
UV = Default(UV, rgb ? 3 : 1)
ch = !(isy || UV!=3)
ch ? ConverttoYUV444(a,chromaresample="spline16") : a
ConvertBits(bits=32, fulls=fs)
BM3D_CPU(sigma=[s,ch?s/2:0,ch?s/2:0], radius=r, chroma=ch)
BM3D_VAggregate(radius=r)
if (bi < 32) {
ConvertBits(bits=16, dither=-1, fulls=fs)
ConvertBits(bits=bi, dither= 1, fulls=fs)
ch ? MatchColorFormat(a) : mergechroma(a) }
full=fs was the only change I could see, so whatever that's for, didn't work for me.
Also note other change in "red" (thanks to kedautinh12)
Old 7th September 2021, 11:36   #314  |  Link
tormento
Acid fr0g
tormento's Avatar
Updated to last BM3D of a few days ago?
@turment on Telegram
Old 7th September 2021, 11:41   #315  |  Link
tormento
Acid fr0g
tormento's Avatar
Is Zs_RF_Shared still required to use SMDegrain?
Old 7th September 2021, 12:55   #316  |  Link
Pauly Dunne
Grumpy Old Man.
I only have a problem when using it in CPU mode..
Old 7th September 2021, 15:33   #317  |  Link
Dogway
@Pauly Dunne: Thanks for the report! I updated SMDegrain, last minute changes are never good. Also added CPU mode but it's not callable from SMDegrain args, just change to CUDA=false in line 159.
@tormento: I think it's needed only for sh_GetUserGlobalIMTint(), but when I used it it didn't report my threads. I still don't know how AviSynth doesn't have a thread reporting internal function...
Old 7th September 2021, 17:28   #318  |  Link
real.finder
there are https://forum.doom9.org/showthread.p...53#post1925253 but seems no one use it
Old 7th September 2021, 18:37   #319  |  Link
Dogway
Can avstp report cores/thread as string?
Here an image for ex_shapes(), still need to work out cross anisotropy (EDIT: fixed):
Old 8th September 2021, 05:08   #320  |  Link
real.finder
don't think so, I didn't mean avstp but https://forum.doom9.org/showthread.p...21#post1777021 and https://forum.doom9.org/showthread.p...46#post1778346
avisynth, dogway, filters, hbd, packs
