Old 1st September 2021, 18:28   #281  |  Link
Dogway
I'm yet to try fmtconv's Void & Cluster dithering, it's an ordered dither so maybe it compresses better than error diffusion, in my opinion it also distributes better so less banding.
Anyway my preference for the last years have been to (denoise), add grain and increase bitrate, I like texture in the images.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 2nd September 2021, 03:01   #282  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
I would like to ask a real dumb, noobie question about SMDegrain & pre-filter=4, KNLMeansCL, if I may.
How do you change the "strength" settings for KNLMeansCL ???, is it Line ***, or somewhere else ??
Example :-
#After_Prefetch_Denoise
LoadPlugin("%AVISYNTHPLUGINS%\KNLMeansCL\KNLMeansCL.dll")
video=KNLMeansCL(video,d=1, a=2, s=4, h=2, device_type="GPU", device_id=0)
And while I'm at it, does BM3D have optional settings within SMDegrain ??
TIA
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 2nd September 2021, 03:10   #283  |  Link
kedautinh12
Here for document of KNLMeansCL
http://avisynth.nl/index.php/KNLMeansCL
BM3D don't have optional settings in SMDegrain. If you want change settings suitable for you. Can change here
https://github.com/Dogway/Avisynth-S...2.7d.avsi#L159
Documents of BM3D:
http://avisynth.nl/index.php/BM3DCUDA
Old 2nd September 2021, 03:29   #284  |  Link
Julek
Julek's Avatar
Originally Posted by Dogway View Post
@Julek: Test now with updated ExTools. Also if you let me know what type of Adaptive Threshold you use I can give it another stab. "Adaptive" is a generic family, some use integral other not. In your case it seemed to also use an edge mask. Here is a list of most kind of thresholds I could find.
Adaptive Mean
Adaptive Median
Adaptive Gaussian
Otsu Thresholding
Maximum Entropy Thresholding
Mixture Model Thresholding
Binary Clustering
Metric
Moment-Preserving Thresholding
Inner-class Variance
Pun Thresholding
Niblack Thresholding
Bernsen Thresholding
Abutaleb Thresholding
Sauvola Thresholding
Phansalkar Thresholding
PirahanSiah Adaptive Single thresholding based on PSNR ( www.pirahansiah.com )
Lloyd Thresholding
Ridler-Calvard Thresholding // Iterative Selection Thresholding
Johannsen Entropy Thresholding
Yen, Chang Thresholding
Sahoo, Wilkins, Yeager Thresholding // Renyi's Entropy Thresholding
Triangle Thresholding
Kittler-Illingworth Thresholding // Minimum Error Thresholding
Kapur, Sahoo, Wong Thresholding
Here what I use:
https://docs.opencv.org/4.5.1/d7/d4d...esholding.html
cv.ADAPTIVE_THRESH_MEAN_C and cv.ADAPTIVE_THRESH_GAUSSIAN_C, using OpenCV + VS is already quite fast, so I don't know if via Expr would be faster.
Julek is offline   Reply With Quote
Old 2nd September 2021, 09:26   #285  |  Link
Pauly Dunne
Grumpy Old Man.
Documents of BM3D:
Thanks again, I thought it might be a "line" in SMDegrain somewhere
Not sure what's happened, but I am now getting x264 errors, and I can't seem to diagnose them :-
y4m [error]: bad sequence header magic
x264 [error]: could not open input file `-'
Old 2nd September 2021, 09:56   #286  |  Link
kedautinh12
Maybe your name of video file contain special characters or characters don't belong to English alphabet. Others your source video (L-SMASH) can't open that video format
Old 2nd September 2021, 10:25   #287  |  Link
Pauly Dunne
Grumpy Old Man.
Yes, I wonder if it is the "name", thanks for the prompt.
Now that you've mentioned L-Smash....
I was going to post a comment on what ppl thought the best decoder was out of FFMS2 or L-Smash ???
What do you think is the "best" (non GPU based) ?
Old 2nd September 2021, 10:56   #288  |  Link
kedautinh12
Don't have best Video Source plugin, choose video source plugin base your video format
Old 2nd September 2021, 11:08   #289  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks, I will try it too.
It would be nice to have 2 parameters in SMDegrain where you can decide the internal engine bitdepth and the output one.
@turment on Telegram
Old 2nd September 2021, 19:50   #290  |  Link
Dogway
I have always been reticent of adding too many options if they are not well justified, the reason, humans don't deal well when faced with too many options, they stress out and paralyze (FOBO).
FOBO (Fear of Better Options) is a subjective, first-person emotion of indecision, regret and frustration which is associated with being unable to identify a path of action due to an abundance of options.
I think that ConvertBits() is well and nice in its own, visible on the uppermost layer of the script so you can follow the bitdepth conversion flow.
Old 3rd September 2021, 06:24   #291  |  Link
Pauly Dunne
Grumpy Old Man.
Well, I have tried a lot of different things to diagnose this, but it seems to be on only 4 servers that I use for the Distributed Encoding function of RipBot.
So they are simply connected via a LAN, and don't need the complete program to encode (very clever, actually), and yet other pc's on the LAN don't have the problem,
So I think my only recourse is a fresh setup of Windows.
Update:- It turned out that I needed to update these:-VC_redist.x86.exe & VC_redist.x64.exe
There must be some subtle change in Dog's ExTools & SMDegrain.
Old 3rd September 2021, 09:37   #292  |  Link
tormento
Acid fr0g
tormento's Avatar
I have tried Void & Cluster and I can't really see lot of improvements over x264 internal Sierra dithering. Perhaps I need to touch knobs that I don't really know, such as pattern size and so.
Old 3rd September 2021, 12:34   #293  |  Link
Dogway
Well, there's another option, to use SmoothGrad() it uses Dither Tools, maybe there's an equivalent in fmtconv but haven't checked. In any case I have plans of porting it to ExTools from VS ports in a new pack called yugefunc.avsi
Old 3rd September 2021, 12:46   #294  |  Link
@Pauly Dunne [or anyone else]
Here is abbodi1406 vcredist AIO (All In One) version 52, 1st Aug 2021.
[27MB]:- https://github.com/abbodi1406/vcredist/releases
All runtimes from 2005 to current for x86 and x64 combined, all un-necessary stuff stripped out and much smaller than M$ download of all separately.
Good idea to keep the link, updated fairly frequently [about once per month, when M$ makes updates].
Old 3rd September 2021, 14:56   #295  |  Link
Pauly Dunne
Grumpy Old Man.
Nice, StainlessS, can't remember where I found mine, but it's the latest build 14.30.30423.0.
Also need to mention I think it's wise to install both x86 & x64, as I had a fairly recent build of x64, installed, but rather old x86, but after installing, everything works again
Old 3rd September 2021, 15:47   #296  |  Link
real.finder
SmoothGrad still missing, along with Dither_box_filter16 and dither_bilateral16 https://forum.doom9.org/showpost.php...postcount=1131
See My Avisynth Stuff
Old 3rd September 2021, 19:59   #297  |  Link
Dogway
Dither_box_filter16 is ex_boxblur(mode="mean"), for Dither_bilateral16() we have ex_bilateral() or vsTBilateral(), I still need to port LimitFilter and SmoothGrad.
Old 4th September 2021, 11:05   #298  |  Link
kedautinh12
Here for new ver of mvsfunc. If you want port something from vs. Check here:
https://github.com/AmusementClub/mvsfunc
Old 4th September 2021, 11:13   #299  |  Link
real.finder
ex_bilateral give same output as Dither_bilateral16?
LimitFilter = https://github.com/realfinder/AVS-St...ared.avsi#L476
Old 4th September 2021, 12:38   #300  |  Link
real.finder
#ex_boxblur(5,mode="mean")
Dither_convert_8_to_16().Dither_box_filter16(5).DitherPost()
but I can see that they are not similar
avisynth, dogway, filters, hbd, packs
