Old 7th January 2024, 02:41   #2841  |  Link
Dogway
@Blankmedia: I'll have a look at the first issue, I don't see any nand there though
For the second one you should input the results of clipstats in 8-bit into ex_levels manually
Then ex_levels won't try to read scene ranges
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 11th January 2024, 23:05   #2842  |  Link
Fjord
ex_CAS(), CAS() --> CASP() in LSFplus mix/ex ?
LSFplus v6.0 ex references ex_CAS() on lines 767-770. ex_CAS() existed in SharpenersPack until it was renamed to CASP() in SharpenersPack v4.0 (mix).
LSFplus v6.0 mix references CAS() in the same places (lines 763-766), but CAS() does not appear to be defined anywhere.
Shouldn't these references to ex_CAS() and CAS() in LSFplus be replaced with calls to CASP() from the current SharpenersPack v5.1? Or do ex_CAS() and CAS() exist in some other plugin or script that I need to import?
Fjord is offline   Reply With Quote
Old 18th February 2024, 14:59   #2843  |  Link
rgr
What else am I missing to try QTGMC+? I updated nnedi3.dll to 0.9.6.43, but I still have this message.
[avisynth @ 000001f3668c01c0] Script error: nnedi3wrap does not have a named argument "dh"
(C:/Program Files (x86)/AviSynth+/plugins64+/QTGMC+.avsi, line 1171)
(C:/Program Files (x86)/AviSynth+/plugins64+/QTGMC+.avsi, line 965)
rgr is offline   Reply With Quote
Old 18th February 2024, 15:57   #2844  |  Link
Boulder
Pig on the wing
Boulder's Avatar
There are possible fixes in this GitHub issue: https://github.com/Dogway/Avisynth-Scripts/issues/69
Old 18th February 2024, 16:37   #2845  |  Link
rgr
Explained.
Somehow I downloaded QTGMC+ today and an older version was downloaded.
Old 19th February 2024, 20:36   #2846  |  Link
Dogway
Thanks, fixed now, uploading. Indeed I forgot to update the call to CASP(). As for LSFPlus Mix, CAS is a plugin, now I added a version to imply it's an external dependency.
I uploaded also some of the updates for the last few months. Mainly ResizersPack, adding the 'sc' (SceneChange) argument so I can disable it in FillMissing stand alone function, to force RIFE to interpolate even if it's a big change.
TransformPack also saw some more additions, like TM_Daniele() tonemapper which I dig in, S-Log2, and in Main a few more gamuts.
Explained.
Yes, I was going to suggest to update. I guess it works now.
Old 20th February 2024, 00:19   #2847  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
@Dogway,
FYI,
I was just checking out the updates you've recently done, and in the Ex & Mix mods, LSFplus has some mismatched, erroneous details & dates.
FTLOY is offline   Reply With Quote
Old 20th February 2024, 00:41   #2848  |  Link
Dogway
Originally Posted by FTLOY View Post
@Dogway,
FYI,
Thanks, fixed now.
Old 20th February 2024, 02:13   #2849  |  Link
FTLOY
FTLOY's Avatar
Originally Posted by Dogway View Post
Thanks, fixed now.
You're welcome, and thanks for the updates, it's been a "minute".
Old 20th February 2024, 06:31   #2850  |  Link
kedautinh12
ExTools and Stabilization Tools Pack still outdate in the info
Old 21st February 2024, 11:05   #2851  |  Link
madey83
Posts: n/a
hello,
i have silly question: Which prefilter from these below is weaker:
2 = strong median/gauss blur
3 = very strong median/gauss blur (IQMV -Variable Inter Quartile Median- filter)
4 = spatio-temporal median/gauss filter (IQMST)
and in what sources type would be better to use one from these?
Old 23rd February 2024, 23:49   #2852  |  Link
simple_simon
@Dogway, would you consider incorporating a grain function in Gradfun3plus that is similiar to the one in Gradfun2dbmod that only adds grain to areas of that frame that have been debanded?
I'm trying to deband some digital animation footage but the debanding doesn't survive encoding with x264 even at crf=18. I've tried using your Filmgrainplus after Gradfun3plus but that gives the whole image a grainy look that I don't want with digital animation. I just need enough grain in the debanded areas to prevent the encoder from reintroducing the banding.
simple_simon is offline   Reply With Quote
Old 24th February 2024, 18:06   #2853  |  Link
rgr
But I had just downloaded QTGMC+ for the first time an hour earlier. I don't know why I downloaded the version "QTGMC 3.89 + mod by Dogway 2022, based on 3.382s". It will remain a secret.
At 10 bit depth it looks 20% faster. Great job
Old 24th February 2024, 18:17   #2854  |  Link
rgr
I just downloaded FillMissing (version with " Add 'sc=false' to RIFEwrap to force MI by Dogway on Feb 18, 2024")
and I get:
Avisynth open failure: Script error: RIFEwrap does not have a named argument "sc" (C:/Program Files (x86)/AviSynth+/plugins64+/FillMissing.aysi, line 50)
Edit: ResizersPack I also downloaded the old version. But after updating I get:
Avisynth open failure: Script error RIFEwrap does not have a named argument "gpu_id" (C:/Program Files (x86)/AviSynth+/plugins64+/FillMissing.aysi, line 50)
Edit 2:After correcting the typo on line 50 (gpu_id -> gpuid)
"Avisynth open failure: RIFE: gpu_thread must be between 1 and 2 (inclusive) (C:/Program Files (x86)/AviSynth+/plugins64+/ResizersPack.aysi, line 667) (C:/Program Files (x86)/AviSynth+/plugins64+/FillMissing.aysi, line 50) "
On line 667, gpu_thread can take the values 2 or 4. Do I have a different version of RIFE?
Old 24th February 2024, 18:22   #2855  |  Link
kedautinh12
Did you update ResizerPack?
https://github.com/Dogway/Avisynth-S...izersPack.avsi
You need update all dependencies of fill missing to latest version
https://github.com/Dogway/Avisynth-S...ssing.avsi#L17
Old 25th February 2024, 08:59   #2856  |  Link
kedautinh12
and I get:
I think you need waiting for Dogway to fix it
Old 26th February 2024, 06:30   #2857  |  Link
kedautinh12
I got this error when tried SMDerain's latest ver:
My script:
LWLibavVideoSource("C:\Users\ADMIN\Downloads\LR_11.avi")
SMDegrain(6, 400, prefilter=6, ContraSharp=true, RefineMotion=true, plane=4, limits=false, DCTFlicker=false, gpuid=1)
Sample
Old 26th February 2024, 11:30   #2858  |  Link
@K,
AVI Codec is "LAGS", Lagarith.
LWLibavVideoSource loads as RGBP (Planar RGB 8bit), try convert to YV12. (KNLMeansCL seems to require YUV).
I cant test, my setup KNLMeansCL requires BM3D_CUDA which I dont have. I seem to also have old version SMDegrain.
EDIT: My ver$ Smdegrain call to KnlMeansCL uses,
        nlckl   = Eval("  nlc.KNLMeansCL(D=d, A=a, h=h, s=s, device_type=device_type, device_id=deviceid, rclip=nlrc,  wmode=wmode, wref=wref, channels=UV" + knlm_params + ")")
which I presume produces the KnlMeansCL "Must Use 'RGB' with RGB colorspace", error.
Old 7th March 2024, 11:55   #2859  |  Link
tormento
Acid fr0g
tormento's Avatar
@Dogway
Just remembering you to look at the new DGDenoise
The syntax changed so the script is now broken.
@turment on Telegram
Old 9th March 2024, 18:22   #2860  |  Link
tormento
Acid fr0g
tormento's Avatar
I can sort out what do OPP and UV (and its values) in:
ex_BM3D(clip a, float "sigma", int "radius", string "preset", bool "OPP", int "UV", bool "tv_range", int "gpuid")
Any idea? I have tried to look at the avsi but can't understand the conditions.
And why do
ex_BM3D(preset="Light") or ex_BM3D(preset="light")
or
ex_BM3D(preset="Normal") or ex_BM3D(preset="normal")
sometimes spit out "Wrong preset" error?
avisynth, dogway, filters, hbd, packs
